can’t change the volume using the keybindings found in the FAQ… I can however flip my display’s image upside-down with them… CTRL ALT UP / DOWN …
Am I missing something?
They are working here, so I assume you have a device driver (Intel graphics adapter software is a hot candidate) or other 3rd party software which is hijacking this key combo.
Thanks for the quick reply – I’ll look to see.
Visualizations also are not working for me either … (kind off topic… I know), All I get is a blank window when I click the “Vis” button.
