Hello!
plexamp on my samsung s21 keeps skipping some (or most or half) of my music that are in m4a container with fLaC codec. flac codec in flac container works perfectly.
i am not sure what causes the issue. though the codec is flac.
all tracks that were tested are 24 bits 96.0 kHz
these files are not corrupt as they play perfectly on all other non-android devices. i dont own a 2nd android phone to test.
also, i did play using the default music player, and it skips the same songs too. so the issue seems to be the phone not supporting, but why it only causes issue on certain music though everything is similar (some spec below)?
basically, i want plexamp to work as its my primary music player. is there a way for plex server to convert? or anything else?
Let me know if you need more information.
Edit: plex on android plays ALL songs seamlessly! inc the ones plexamp and samsung music skips on the same phone.
this one doesn’t play:
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : fLaC
Duration : 5 min 31 s
Bit rate mode : Variable
Bit rate : 2 503 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 96.0 kHz
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 98.9 MiB (100%)
this one plays perfectly
Format : FLAC
Codec ID : fLaC
Duration : 6 min 25 s
Bit rate : 1 434 kb/s
Sampling rate : 44.1 kHz
Bit depth : 24 bits
Stream size : 65.9 MiB (100%)
