I’m using the Android version of Plexamp, which I love by the way, but I’m running into an issue that occurs when I start listening to an album over cellular and then get back on wifi. It says the codec is still Opus at 128. I have music quality over wifi set to maximum so I would expect this to switch to FLAC. I tried clearing cache within the application but no luck. I even tried going back on cellular and playing more songs to try to use up the cache but that didn’t work either. Any suggestions?
So what you might be seeing here is some cache-ahead. Depending on your settings, it’ll cache Opus ahead on cellular, and then when you get back on WiFi for at least a track or two you might see it still use Opus. If you’re getting back on WiFi and seeing it keep using Opus far after the fact (and it’s not pulling from downloaded content, e.g.) you can ship us a log and we can see why it’s specifically choosing Opus.
