Plexamp's seek bar not rendering correctly when changing resolution on Android
Hello,
My Samsung Galaxy S22 Ultra has a feature to change its display resolution. However, doing so while keeping Plexamp open causes a rendering issue on the seekbar.
For example, let’s start from the native resolution.
Then, changing the resolution to half of native changes the seekbar visually.
However, it can still be interacted with the same way without any functionality issue, so I believe it’s a visual bug. Restarting the application fixes that.
It also goes the other way. For example, going from the less-than-native resolution back to the native one yields this result.
Edit: This scaling issue also happens with the circle indicating the amount of tracks left during a download.
Edit: Also with the equalizer diagram
Thank you!
