PleXBMC client for XBMC
Not working for me on AT2
See below the error I get when I click on the APP
using plugin.video.plexbmc-v2.0b3 on ATV2 Frodo Beta 1
15:32:19 T:153190400 NOTICE: -->Python Interpreter Initialized<–
15:32:20 T:158502912 NOTICE: Metacontainers - Loading sqlite3 as DB engine
15:32:20 T:158502912 NOTICE: 1Channel: MySQL not enabled or not setup correctly
15:32:20 T:158502912 NOTICE: 1Channel: Loading sqlite3 as DB engine
15:32:20 T:158502912 NOTICE: Table movie_meta initialized
15:32:20 T:158502912 NOTICE: Table tvshow_meta initialized
15:32:20 T:158502912 NOTICE: Table season_meta initialized
15:32:20 T:158502912 NOTICE: Table episode_meta initialized
15:32:20 T:158502912 NOTICE: Table addons initialized
15:32:20 T:158502912 NOTICE: 1Channel: Building 1channel Database
15:32:20 T:158502912 NOTICE: 1Channel: {‘mode’: ‘UpdateSubscriptions’}
15:32:20 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:32:20 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
15:32:21 T:115224576 NOTICE: VideoInfoScanner: Starting scan …
15:32:30 T:153190400 NOTICE: -->Python Interpreter Initialized<–
15:32:30 T:115224576 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:09
15:32:30 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:32:30 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
Please enable debugging so I can actually see what goes wrong in xbmc :)
The posted sullotion works for me :)
Err - hello… Not sure what reception I’ll get here :blink:
It’s been a while, as I’ve been busy with work, ill, busy with 3 kids and then ill again…
That's not good. I know 3 kids ( I have 2 ) can make you sick though :P
Get all the rest you can get. Don't worry to much about PleXBMC to much. Frodo is still just beta 1 :P
Get well soon!
Cheers,
Joris
Ok enabled debugging in the PlexXBMC settings and I want to help
Where can I find that log after I click and it says
Script Failed pugin vide plexbmc
or is the same LOG as XBMC here is what that says
15:37:16 T:146505728 NOTICE: -->Python Interpreter Initialized<--
15:37:16 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:37:16 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
15:37:51 T:119832576 ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/plugin.program.repo.installer/
15:39:31 T:146505728 ERROR: Previous line repeats 1 times.
15:39:31 T:146505728 NOTICE: -->Python Interpreter Initialized<--
15:39:31 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:39:31 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
15:39:42 T:146505728 NOTICE: -->Python Interpreter Initialized<--
15:39:42 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:39:42 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
15:39:55 T:146505728 NOTICE: -->Python Interpreter Initialized<--
15:39:55 T:804773888 ERROR: GetDirectory - Error getting plugin://plugin.video.plexbmc/?content_type=video
15:39:55 T:804773888 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.plexbmc/?content_type=video) failed
15:40:21 T:119832576 ERROR: Texture manager unable to load file: /var/mobile/Library/Preferences/XBMC/addons/plugin.program.repo.installer/
Can you PM me your default.py and I can try that?
Yeah, i saw Frodo had gone to Beta and was a little concerned. I believe they are stopping/changing multi source plugins (video and audio).
One good thing is that Frodo has a change I put in to make starting/resuming video much cleaner (you can now request directly for media to restart at a particular position, rather than my cludgy work around of play/pause/seek/unpause). Code needed to do this is very straight forward (probably only a few lines)..
It's attached with this message.
Your log still seems incomplete though.
It should contain DEBUG: lines.
ok turned on debug for XBMC too sorry
http://www.xbmclogs.com/show.php?id=15186
Hope you can help me
I don't see python crashing in your logs, sorry...
can you pm me your default.py and I can try that
I thought I attached it before.
I'll try again.
Interesting, now with your py file it sits there tries to load and then crashes XBMC back to the ATV2 main screen
http://www.xbmclogs.com/show.php?id=15189
BTW I donwloaded the Plexbmc file from the first page I think beta 3
You should 2.0 BETA 4.
https://github.com/hippojay/plugin.video.plexbmc/downloads
And apply my changes to it. (see my previous post in this threads for some other fixes).
Cheers,
Joris
Thanks but nope still crashes XBMC to the ATV main screen
http://www.xbmclogs.com/show.php?id=15191
I am going to try a clean install and unistall PLEX
no luck even after clean install, put my user name and password in the settings and it crashes XBMC
http://www.xbmclogs.com/show.php?id=15193
Joris,
Confirmed your fix works for plexbmc plugin 2.0 beta 4. Works on all 4 of our xbmcbuntu boxes running Frodo beta 1. Thanks!
hippojay,
Love this plugin- it gives our family the best of both worlds being able to run cutting edge XBMC and still use Plex that we love and use like crazy on our mobile devices. Thanks!
Is that the params fix? If so that's good news and I'll add it - I've just set up an xbmcbuntu box to allow me to test against linux (it's the front room one, so gets a lot of usage)
I've compiled a few other fixes into the Eden branch, which I've loaded on my main box for testing. It's mainly a few fixes for issues reported (such as the subs loader not working on tv shows, and some odd screen metadata formatting). I'll put this up as Beta 5 at the weekend after I've tested a few of the main plugins (as I see AMT and youtube have stopped working for some reason). Core functionality seems to be ok, as I've been using the newer version pretty much every day without problem.
EDIT: looks like the youtube problem is a plex one, not a plexbmc one. AMT is broken because the API changed, just need to update it.
hippojay, thanks for your awesome plug-in. We use it almost everyday on different clients around the house. Thanks for taking the time to keep it working on Frodo as well.
Joris, thanks for your quick fix. I can confirm it worked on my Raspberry Pi, running Raspbmc RC5 (Raspian + XBMC Frodo Beta1 nightly, compiled Nov 20 + PleXBMC 2.0 Beta4). I will make the same changes on the Mac and AppleTV and report back if anything worth noting.
hippojay,
Yep the param_url fix that Joris posted on the previous page did the trick for Frodo beta 1. Looking forward to beta 5!
Works like a charm =)
Thank you.
Also great to see that Hippo is back in action.
