Thx for the quick reply, much appreciated:)
I installed 1.9.3 and got following problem: When I want to enter the PleXBMC configuration menu, XBMC crashes.
In the addon settings? That’s very strange (as that’s all XBMC internal code), any error messages or anything in the xbmc.log file?
Yes in the addon settings. That’s what the log file says:
21:08:25 T:2685834560 M:299646976 NOTICE: -----------------------------------------------------------------------
21:08:25 T:2685834560 M:299634688 NOTICE: Starting XBMC, Platform: Mac OS X (10.7.0 i386). Built on Mar 9 2011 (Git:e9e9099)
21:08:25 T:2685834560 M:299634688 NOTICE: special://xbmc/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
21:08:25 T:2685834560 M:299634688 NOTICE: special://xbmcbin/ is mapped to: /Applications/XBMC.app/Contents/Resources/XBMC
21:08:25 T:2685834560 M:299634688 NOTICE: special://masterprofile/ is mapped to: /Users/Ivo/Library/Application Support/XBMC/userdata
21:08:25 T:2685834560 M:299634688 NOTICE: special://home/ is mapped to: /Users/Ivo/Library/Application Support/XBMC
21:08:25 T:2685834560 M:299634688 NOTICE: special://temp/ is mapped to: /Users/Ivo/.xbmc/temp
21:08:25 T:2685834560 M:299634688 NOTICE: The executable running is: /Applications/XBMC.app/Contents/MacOS/XBMC
21:08:25 T:2685834560 M:299634688 NOTICE: Log File is located: /Users/Ivo/Library/Logs/xbmc.log
21:08:25 T:2685834560 M:299634688 NOTICE: -----------------------------------------------------------------------
21:08:25 T:2685834560 M:299630592 NOTICE: Setup SDL
21:08:25 T:2685834560 M:299728896 NOTICE: load settings…
21:08:25 T:2685834560 M:299573248 ERROR: Unable to load libcrystalhd.dylib, reason: dlopen(libcrystalhd.dylib, 1): image not found
21:08:25 T:2685834560 M:299520000 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:08:25 T:2685834560 M:299520000 NOTICE: loading special://masterprofile/guisettings.xml
21:08:25 T:2685834560 M:299646976 NOTICE: Getting hardware information now…
21:08:25 T:2685834560 M:299638784 NOTICE: Checking resolution 12
21:08:25 T:2685834560 M:299454464 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:08:25 T:2685834560 M:299417600 NOTICE: Loaded playercorefactory configuration
21:08:25 T:2685834560 M:299417600 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:08:25 T:2685834560 M:299417600 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:08:25 T:2685834560 M:299413504 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
21:08:25 T:2685834560 M:299413504 NOTICE: Default DVD Player: dvdplayer
21:08:25 T:2685834560 M:299413504 NOTICE: Default Video Player: dvdplayer
21:08:25 T:2685834560 M:299413504 NOTICE: Default Audio Player: paplayer
21:08:25 T:2685834560 M:299409408 NOTICE: Loading media sources from special://masterprofile/sources.xml
21:08:27 T:2685834560 M:297603072 NOTICE: GL_VENDOR = NVIDIA Corporation
21:08:27 T:2685834560 M:297603072 NOTICE: GL_RENDERER = NVIDIA GeForce 9400 OpenGL Engine
21:08:27 T:2685834560 M:297603072 NOTICE: GL_VERSION = 2.1 NVIDIA-1.6.26
21:08:27 T:2685834560 M:297603072 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
21:08:27 T:2685834560 M:297603072 NOTICE: GL_EXTENSIONS = GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_ARB_framebuffer_object GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_depth_bounds_test GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_EXT_provoking_vertex GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_point_sprite GL_NV_blend_square GL_NV_fog_distance GL_NV_depth_clamp GL_NV_multisample_filter_hint GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_conditional_render GL_ATI_texture_mirror_once GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_EXT_texture_array GL_EXT_vertex_array_bgra GL_ARB_instanced_arrays GL_ARB_depth_buffer_float GL_EXT_packed_float GL_EXT_texture_shared_exponent
21:08:28 T:2685834560 M:299405312 NOTICE: start dvd mediatype detection
21:08:28 T:2685834560 M:299401216 NOTICE: initializing playlistplayer
21:08:28 T:2685834560 M:299364352 NOTICE: DONE initializing playlistplayer
21:08:30 T:2685834560 M:294703104 NOTICE: UpdateLibraries - Starting video library startup scan
21:08:30 T:2685834560 M:294629376 NOTICE: initialize done
21:08:30 T:2685834560 M:294621184 NOTICE: Running the application…
21:08:30 T:2955026432 M:295960576 NOTICE: VideoInfoScanner: Starting scan …
21:08:30 T:2685834560 M:296005632 NOTICE: Webserver: Starting…
21:08:30 T:2955026432 M:296005632 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
21:08:30 T:2685834560 M:295976960 NOTICE: WebServer: Started the webserver
21:08:30 T:2685834560 M:295960576 NOTICE: starting upnp server
21:08:30 T:2685834560 M:295809024 NOTICE: ES: Starting event server
21:08:30 T:2956091392 M:295788544 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:08:30 T:2956091392 M:295788544 NOTICE: UDP: Listening on port 9777
21:08:30 T:2685834560 M:295768064 NOTICE: starting zeroconf publishing
21:08:32 T:2958221312 M:298741760 NOTICE: -->Python Interpreter Initialized<–
21:08:33 T:2958221312 M:298479616 NOTICE: ===== PLEXBMC START =====
21:08:33 T:2958221312 M:298479616 NOTICE: PleXBMC -> running on (2, 4, 5, ‘final’, 0)
21:08:34 T:2958221312 M:297484288 NOTICE: PleXBMC -> Running addon ElementTree version
21:08:34 T:2958221312 M:297467904 NOTICE: PleXBMC -> Debug is turned off. Running silent
21:08:34 T:2958221312 M:297234432 NOTICE: ===== PLEXBMC STOP =====
Ok. Running a nightly (9th march). I’ll break out my copy to make sure, but it might be a build specific problem.
Edit: and on LION (10.7)!! I’ll check but it might be a combination of stuff outside my control.
Uhm no, I dont have Lion. :-S I use Snow Leopard 10.6.7, no idea why it shows 10.7. I also didn’t install any nightly on purpose. Is it safe to reinstall the XBMC on the homepage?
I get a script failure on the latest nightly build on ATV2, probably ATV2 build related though
Any chance of a log? Or error message?
Depends. If you are using XBMC for plex only, then an uninstall and a reinstall of 10.1 should be ok. But if you are using it for anything else, then it might be better to move to a later nightly build. The format of databases and stuff changes between 10.1 and the pre-11 builds.
So what do you recommend me if I’m using XBMC only for Plex and me intention is the get PleXBMC working properly, upgrade or downgrade? It’s still weird that it shows 10.7. since I’m 100% using 10.6.7.
Erm;
14:36:33 T:112504832 M:127242240 NOTICE: -----------------------------------------------------------------------
14:36:33 T:112504832 M:120381440 NOTICE: Starting XBMC, Platform: Mac OS X (11.0.0 AppleTV2,1). Built on Jun 18 2011 (Git:20110618-eedceeb)
14:36:33 T:112504832 M:120381440 NOTICE: special://xbmc/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
14:36:33 T:112504832 M:120381440 NOTICE: special://xbmcbin/ is mapped to: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome
14:36:33 T:112504832 M:120381440 NOTICE: special://masterprofile/ is mapped to: /var/mobile/Library/Preferences/XBMC/userdata
14:36:33 T:112504832 M:120381440 NOTICE: special://home/ is mapped to: /var/mobile/Library/Preferences/XBMC
14:36:33 T:112504832 M:120381440 NOTICE: special://temp/ is mapped to: /var/mobile/Library/Preferences/XBMC/temp
14:36:33 T:112504832 M:120381440 NOTICE: special://frameworks/ is mapped to: /var/stash/Applications/XBMC.frappliance/Frameworks
14:36:33 T:112504832 M:120381440 NOTICE: The executable running is: /var/stash/Applications/XBMC.frappliance/XBMC
14:36:33 T:112504832 M:120381440 NOTICE: Log File is located: /var/mobile/Library/Preferences/xbmc.log
14:36:33 T:112504832 M:120381440 NOTICE: -----------------------------------------------------------------------
14:36:33 T:112504832 M:120197120 NOTICE: load settings...
14:36:33 T:112504832 M:120197120 NOTICE: special://profile/ is mapped to: special://masterprofile/
14:36:33 T:112504832 M:120197120 NOTICE: loading special://masterprofile/guisettings.xml
14:36:34 T:112504832 M:119484416 NOTICE: Getting hardware information now...
14:36:34 T:112504832 M:119484416 INFO: Using digital output
14:36:34 T:112504832 M:119484416 INFO: AC3 pass through is enabled
14:36:34 T:112504832 M:119484416 INFO: DTS pass through is enabled
14:36:34 T:112504832 M:121479168 INFO: AAC pass through is disabled
14:36:34 T:112504832 M:121479168 INFO: MP1 pass through is disabled
14:36:34 T:112504832 M:121479168 INFO: MP2 pass through is disabled
14:36:34 T:112504832 M:121479168 INFO: MP3 pass through is disabled
14:36:34 T:112504832 M:121479168 DEBUG: Error: Requested setting (videoscreen.screenmode) was not found. It must be case-sensitive
14:36:34 T:112504832 M:121479168 NOTICE: Checking resolution 12
14:36:34 T:112504832 M:121479168 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerCoreConfig::: created player DVDPlayer for core 1
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerCoreConfig::: created player oldmplayercore for core 1
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerCoreConfig::: created player PAPlayer for core 3
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
14:36:34 T:112504832 M:121466880 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
14:36:34 T:112504832 M:121466880 NOTICE: Loaded playercorefactory configuration
14:36:34 T:112504832 M:121466880 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
14:36:34 T:112504832 M:121466880 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
14:36:34 T:112504832 M:121466880 NOTICE: No settings file to load to load (special://xbmc/system/advancedsettings.xml)
14:36:34 T:112504832 M:121466880 NOTICE: No settings file to load to load (special://masterprofile/advancedsettings.xml)
14:36:34 T:112504832 M:121466880 NOTICE: Default DVD Player: dvdplayer
14:36:34 T:112504832 M:121466880 NOTICE: Default Video Player: dvdplayer
14:36:34 T:112504832 M:121466880 NOTICE: Default Audio Player: paplayer
14:36:34 T:112504832 M:121360384 NOTICE: Loading media sources from special://masterprofile/sources.xml
14:36:34 T:112504832 M:129155072 INFO: creating subdirectories
14:36:34 T:112504832 M:129155072 INFO: userdata folder: special://masterprofile/
14:36:34 T:112504832 M:129155072 INFO: recording folder:
14:36:34 T:112504832 M:129155072 INFO: screenshots folder:
14:36:34 T:112504832 M:129155072 INFO: thumbnails folder: special://masterprofile/Thumbnails
14:36:34 T:112504832 M:130850816 INFO: load language info file: special://xbmc/language/English/langinfo.xml
14:36:34 T:112504832 M:130863104 DEBUG: trying to set locale to en_US.UTF-8
14:36:34 T:112504832 M:130863104 INFO: global locale set to C
14:36:34 T:112504832 M:130863104 INFO: load language file:special://xbmc/language/English/strings.xml
14:36:34 T:112504832 M:130531328 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-arm-osx.so)
14:36:34 T:112504832 M:130531328 DEBUG: Loading: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/system/libcpluff-arm-osx.so
14:36:34 T:112504832 M:136343552 INFO: GLES: Maximum texture width: 2048
14:36:34 T:112504832 M:136343552 DEBUG: EGL_EXTENSIONS: GL_OES_depth_texture GL_OES_depth24 GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_shader_texture_lod GL_EXT_texture_filter_anisotropic GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
14:36:34 T:112504832 M:136343552 NOTICE: GL_VENDOR = Imagination Technologies
14:36:34 T:112504832 M:136343552 NOTICE: GL_RENDERER = PowerVR SGX 535
14:36:34 T:112504832 M:136343552 NOTICE: GL_VERSION = OpenGL ES 2.0 IMGSGX535-58.6
14:36:34 T:112504832 M:136343552 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.0
14:36:34 T:112504832 M:136343552 DEBUG: GLES: Extension Support Test - GL_NVX_gpu_memory_info NO
14:36:34 T:112504832 M:136343552 NOTICE: GL_EXTENSIONS = GL_OES_depth_texture GL_OES_depth24 GL_OES_fbo_render_mipmap GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_rgb8_rgba8 GL_OES_standard_derivatives GL_OES_texture_float GL_OES_texture_half_float GL_OES_vertex_array_object GL_EXT_blend_minmax GL_EXT_discard_framebuffer GL_EXT_read_format_bgra GL_EXT_shader_texture_lod GL_EXT_texture_filter_anisotropic GL_APPLE_framebuffer_multisample GL_APPLE_rgb_422 GL_APPLE_texture_format_BGRA8888 GL_APPLE_texture_max_level GL_IMG_read_format GL_IMG_texture_compression_pvrtc
14:36:34 T:112504832 M:136335360 DEBUG: GL: Vertex Shader compilation log:
14:36:34 T:112504832 M:136335360 DEBUG: GL: Vertex Shader compiled successfully
14:36:34 T:112504832 M:136335360 DEBUG: GL: Pixel Shader compilation log:
14:36:34 T:112504832 M:136335360 DEBUG: GL: Fragment Shader compiled successfully
14:36:34 T:112504832 M:136335360 DEBUG: GUI Shader [guishader_frag_default.glsl]- Initialise successful : 0x1e638db0
14:36:34 T:112504832 M:136331264 DEBUG: GL: Vertex Shader compilation log:
14:36:34 T:112504832 M:136331264 DEBUG: GL: Vertex Shader compiled successfully
14:36:34 T:112504832 M:136331264 DEBUG: GL: Pixel Shader compilation log:
14:36:34 T:112504832 M:136331264 DEBUG: GL: Fragment Shader compiled successfully
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_texture.glsl]- Initialise successful : 0x1e65ad50
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_multi.glsl]- Initialise successful : 0x1e65b370
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_fonts.glsl]- Initialise successful : 0x1e65f810
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_texture_noblend.glsl]- Initialise successful : 0x1e65e1c0
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_multi_blendcolor.glsl]- Initialise successful : 0x1e663be0
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_rgba.glsl]- Initialise successful : 0x1e662a70
14:36:34 T:112504832 M:136331264 DEBUG: GUI Shader [guishader_frag_rgba_blendcolor.glsl]- Initialise successful : 0x1e667ea0
14:36:34 T:112504832 M:136331264 INFO: GLES: Maximum texture width: 2048
14:36:34 T:112504832 M:136331264 INFO: load default splash image: /private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/media/Splash.png
14:36:34 T:112504832 M:134729728 INFO: load keymapping
14:36:34 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
14:36:34 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
14:36:34 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
14:36:34 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
14:36:34 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION(R)3.Controller.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/keyboard.nyxboard.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/mouse.xml
14:36:35 T:112504832 M:134717440 INFO: Loading special://xbmc/system/keymaps/remote.xml
14:36:35 T:112504832 M:134717440 INFO: GUI format 1280x720 1280x720
14:36:35 T:112504832 M:134717440 DEBUG: guilib: No algorithm for solving rendering passes
14:36:35 T:112504832 M:134717440 NOTICE: initializing playlistplayer
14:36:35 T:112504832 M:134717440 NOTICE: DONE initializing playlistplayer
14:36:35 T:112504832 M:134717440 INFO: DPMS: not supported on this platform
14:36:35 T:112504832 M:134557696 INFO: Unloading old skin ...
14:36:35 T:112504832 M:134713344 DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
14:36:35 T:112504832 M:135946240 INFO: load skin from:/var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc
14:36:35 T:112504832 M:135938048 INFO: Loading skin includes from /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc/720p/includes.xml
14:36:36 T:112504832 M:135188480 INFO: load fonts for skin...
14:36:36 T:112504832 M:135188480 INFO: Loading fonts from /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc/720p/Font.xml
14:36:36 T:112504832 M:134828032 INFO: load new skin...
14:36:36 T:112504832 M:134828032 INFO: Loading skin file: Home.xml
14:36:37 T:112504832 M:134070272 INFO: Loading user windows, path /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc/720p
14:36:37 T:112504832 M:134074368 DEBUG: Load Skin XML: 755.61ms
14:36:37 T:112504832 M:134074368 INFO: initialize new skin...
14:36:37 T:112504832 M:134074368 INFO: Loading skin file: DialogVolumeBar.xml
14:36:37 T:112504832 M:133980160 DEBUG: OpenBundle - Opened bundle /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc/media/Textures.xbt
14:36:37 T:112504832 M:133980160 INFO: Loading skin file: DialogSeekBar.xml
14:36:37 T:112504832 M:133980160 INFO: Loading skin file: DialogKaiToast.xml
14:36:37 T:112504832 M:133980160 INFO: Loading skin file: DialogMuteBug.xml
14:36:37 T:112504832 M:133980160 DEBUG: guilib: No algorithm for solving rendering passes
14:36:37 T:112504832 M:133976064 DEBUG: CGUIAudioManager::Initialize
14:36:37 T:112504832 M:133976064 DEBUG: Previous line repeats 1 times.
14:36:37 T:112504832 M:133976064 INFO: Loading /var/mobile/Library/Preferences/XBMC/addons/skin.confluence.plexbmc/sounds/sounds.xml
14:36:37 T:112504832 M:133976064 INFO: skin loaded...
14:36:37 T:112504832 M:133976064 DEBUG: Activating window ID: 12999
14:36:37 T:112504832 M:133976064 DEBUG: ------ Window Init (Startup.xml) ------
14:36:37 T:112504832 M:133976064 INFO: Loading skin file: Startup.xml
14:36:37 T:112504832 M:133976064 INFO: removing tempfiles
14:36:37 T:112504832 M:133971968 DEBUG: ADDON: Starting service addons.
14:36:37 T:112504832 M:133971968 NOTICE: initialize done
14:36:37 T:112504832 M:133971968 NOTICE: Running the application...
14:36:37 T:112504832 M:133971968 DEBUG: ExecuteXBMCAction : Translating SetFocus(10)
14:36:37 T:112504832 M:133971968 DEBUG: ExecuteXBMCAction : To SetFocus(10)
14:36:37 T:112504832 M:133971968 DEBUG: Process - no profile autoexec.py (/var/mobile/Library/Preferences/XBMC/userdata/autoexec.py) found, skipping
14:36:37 T:112504832 M:133971968 DEBUG: NetworkMessage - Starting network services
14:36:37 T:112504832 M:133971968 NOTICE: ES: Starting event server
14:36:37 T:113438720 M:133963776 DEBUG: Thread EventServer start, auto delete: 0
14:36:37 T:113438720 M:133963776 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
14:36:37 T:113438720 M:133963776 NOTICE: UDP: Listening on port 9777
14:36:38 T:112504832 M:133963776 INFO: JSONRPC Server: Successfully initialized
14:36:38 T:112504832 M:133963776 NOTICE: starting zeroconf publishing
14:36:38 T:112504832 M:133963776 DEBUG: CZeroconfOSX::doPublishService identifier: servers.eventserver type: _xbmc-events._udp name:XBMC Event Server port:9777
14:36:38 T:113971200 M:133959680 DEBUG: Thread JSONRPC::CTCPServer start, auto delete: 0
14:36:38 T:112504832 M:133959680 DEBUG: CZeroconfOSX::doPublishService identifier: servers.jsonrpc type: _xbmc-jsonrpc._tcp name:XBMC JSONRPC port:9090
14:36:38 T:112504832 M:133959680 DEBUG: CLastfmScrobbler: Clearing session.
14:36:38 T:112504832 M:133959680 DEBUG: CLibrefmScrobbler: Clearing session.
14:36:38 T:114503680 M:133922816 DEBUG: Thread CJobWorker start, auto delete: 1
14:36:38 T:112504832 M:133922816 DEBUG: ------ Window Init (Pointer.xml) ------
14:36:38 T:112504832 M:133922816 INFO: Loading skin file: Pointer.xml
14:36:38 T:112504832 M:133910528 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
14:36:38 T:112504832 M:133910528 INFO: GLES: Enabling VSYNC
14:36:38 T:112504832 M:133910528 INFO: GLES: Selected vsync mode 10
14:36:38 T:112504832 M:131874816 DEBUG: ExecuteXBMCAction : Translating ReplaceWindow(Home)
14:36:38 T:112504832 M:131874816 DEBUG: ExecuteXBMCAction : To ReplaceWindow(Home)
14:36:38 T:112504832 M:131874816 DEBUG: Activating window ID: 10000
14:36:38 T:112504832 M:131874816 DEBUG: ------ Window Deinit (Startup.xml) ------
14:36:38 T:112504832 M:131874816 DEBUG: ------ Window Init (Home.xml) ------
14:36:38 T:124895232 M:131825664 DEBUG: Thread CJobWorker start, auto delete: 1
14:36:38 T:124895232 M:131825664 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
14:36:38 T:124895232 M:131747840 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
14:36:38 T:124895232 M:131710976 DEBUG: GetRecentlyAddedAlbums query: select * from albumview order by idAlbum desc limit 10
14:36:38 T:125534208 M:131706880 DEBUG: Thread CJobWorker start, auto delete: 1
14:36:38 T:125534208 M:131706880 INFO: WEATHER: Downloading weather
14:36:38 T:125534208 M:131706880 DEBUG: SECTION:LoadDLL(libcurl.4.dylib)
14:36:38 T:125534208 M:131698688 DEBUG: Loading: /var/stash/Applications/XBMC.frappliance/Frameworks/libcurl.4.dylib
14:36:38 T:124895232 M:127582208 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
14:36:38 T:803790848 M:123703296 DEBUG: Thread CRssReader start, auto delete: 0
14:36:38 T:112504832 M:123539456 DEBUG: ExecuteXBMCAction : Translating XBMC.RunScript(plugin.video.plexbmc,skin)
14:36:38 T:112504832 M:123539456 DEBUG: ExecuteXBMCAction : To XBMC.RunScript(plugin.video.plexbmc,skin)
14:36:38 T:112504832 M:123539456 INFO: initializing python engine.
14:36:38 T:112504832 M:123539456 DEBUG: PYTHONHOME -> /var/stash/Applications/XBMC.frappliance/Frameworks/
14:36:38 T:112504832 M:123539456 DEBUG: PYTHONPATH -> /var/stash/Applications/XBMC.frappliance/Frameworks/
14:36:39 T:124895232 M:123265024 DEBUG: RunQuery took 19 ms for 10 items query: select * from movieview order by idMovie desc limit 10
14:36:39 T:125534208 M:125718528 DEBUG: FileCurl::Open(0x77b7d04) http://xoap.weather.com/weather/local/USNY0996?cc=*&unit=m&dayf=4&prod=xoap&link=xoap&par=1004124588&key=079f24145f208494
14:36:39 T:803790848 M:125714432 DEBUG: FileCurl::Open(0x2fe8dd04) http://feeds.feedburner.com/xbmc
14:36:39 T:125534208 M:125689856 INFO: easy_aquire - Created session to http://xoap.weather.com
14:36:39 T:803790848 M:125620224 INFO: easy_aquire - Created session to http://feeds.feedburner.com
14:36:39 T:112504832 M:125612032 DEBUG: new python thread created. id=1
14:36:39 T:112504832 M:125612032 DEBUG: ExecuteXBMCAction : Translating SetFocus(9000)
14:36:39 T:112504832 M:125612032 DEBUG: ExecuteXBMCAction : To SetFocus(9000)
14:36:39 T:132087808 M:125607936 DEBUG: Thread XBPyThread start, auto delete: 0
14:36:39 T:132087808 M:125607936 DEBUG: Python thread: start processing
14:36:39 T:803790848 M:123559936 DEBUG: Got rss feed: http://feeds.feedburner.com/xbmc
14:36:39 T:124895232 M:123658240 DEBUG: RunQuery took 5 ms for 0 items query: select * from episodeview order by idEpisode desc limit 10
14:36:39 T:803790848 M:124243968 DEBUG: RSS feed encoding: UTF-8
14:36:40 T:803790848 M:124243968 DEBUG: Parsed rss feed: http://feeds.feedburner.com/xbmc
14:36:40 T:803790848 M:124243968 DEBUG: Thread CRssReader 803790848 terminating
14:36:40 T:124895232 M:124243968 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
14:36:40 T:114503680 M:124252160 DEBUG: DoWork - took 1903 ms to load special://skin/backgrounds/videos.jpg
14:36:40 T:125534208 M:123965440 INFO: WEATHER: Weather download successful
14:36:40 T:125534208 M:123965440 DEBUG: GetZipList - Processing zip://special%3a%2f%2fxbmc%2fmedia%2fweather%2ezip/
14:36:40 T:112504832 M:123777024 DEBUG: ------ Window Deinit (Pointer.xml) ------
14:36:41 T:132087808 M:124076032 NOTICE: -->Python Interpreter Initialized<--
14:36:41 T:132087808 M:124076032 DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc/default.py
14:36:41 T:132087808 M:124076032 DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pysqlite/lib:/var/stash/Applications/XBMC.frappliance/Frameworks:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages:
14:36:41 T:132087808 M:124076032 DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc
14:36:41 T:132087808 M:124051456 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.plexbmc" dependent on version 1.0 of the xbmc.python api
14:36:51 T:132087808 M:123424768 ERROR: /var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc/default.py:2: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
import sys,os,datetime, time, sha, inspect
14:36:52 T:132087808 M:122650624 NOTICE: ===== PLEXBMC START =====
14:36:52 T:132087808 M:122650624 NOTICE: PleXBMC -> running on (2, 6, 5, 'final', 0)
14:36:53 T:132087808 M:122810368 NOTICE: PleXBMC -> Running with cElementTree on Python 2.5+
14:36:53 T:132087808 M:122818560 NOTICE: PleXBMC -> Debug is turned off. Running silent
14:36:54 T:132087808 M:122753024 INFO: -->Python script returned the following error<--
14:36:54 T:132087808 M:122753024 ERROR: Error Type:
14:36:54 T:132087808 M:122753024 ERROR: Error Contents: ('192.168.0.8:32400',)
14:36:54 T:132087808 M:122245120 ERROR: Traceback (most recent call last):
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc/default.py", line 3091, in
skin()
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.plexbmc/default.py", line 3038, in skin
WINDOW.setProperty("plexbmc.%d.server" % (serverCount) , mapping[server[1]])
KeyError: ('192.168.0.8:32400',)
14:36:54 T:132087808 M:122372096 INFO: -->End of Python script error report<--
14:36:54 T:112504832 M:122376192 INFO: Loading skin file: DialogKaiToast.xml
14:36:54 T:112504832 M:122376192 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
14:36:54 T:132087808 M:122142720 INFO: Python script stopped
14:36:54 T:132087808 M:122142720 DEBUG: Thread Python Thread 132087808 terminating
14:36:54 T:112504832 M:122142720 DEBUG: waiting for python thread 1 to stop
14:36:54 T:112504832 M:122150912 DEBUG: python thread 1 destructed
14:36:54 T:114503680 M:122155008 DEBUG: DoWork - took 653 ms to load special://skin/backgrounds/settings.jpg
14:36:58 T:112504832 M:118616064 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(ShutdownMenu)
14:36:58 T:112504832 M:118616064 DEBUG: ExecuteXBMCAction : To ActivateWindow(ShutdownMenu)
14:36:58 T:112504832 M:118611968 DEBUG: Activating window ID: 10111
14:36:58 T:112504832 M:118607872 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
14:36:58 T:112504832 M:118607872 INFO: Loading skin file: DialogButtonMenu.xml
14:36:58 T:112504832 M:118345728 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
14:36:58 T:112504832 M:118345728 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnQuit
14:36:58 T:124895232 M:118345728 DEBUG: Thread Jobworker 124895232 terminating (autodelete)
14:36:58 T:125534208 M:118349824 DEBUG: Thread Jobworker 125534208 terminating (autodelete)
14:36:58 T:114503680 M:118358016 DEBUG: Thread Jobworker 114503680 terminating (autodelete)
14:36:58 T:112504832 M:118362112 NOTICE: Storing total System Uptime
14:36:58 T:112504832 M:118362112 NOTICE: Saving settings
14:36:58 T:112504832 M:118362112 NOTICE: stop all
14:36:58 T:112504832 M:118362112 DEBUG: NetworkMessage - Signaling network services to stop
14:36:58 T:112504832 M:118362112 NOTICE: ES: Stopping event server
14:36:58 T:112504832 M:118362112 DEBUG: NetworkMessage - Waiting for network services to stop
14:36:58 T:112504832 M:118362112 NOTICE: stopping zeroconf publishing
14:36:59 T:113971200 M:118370304 DEBUG: Thread JSONRPC::CTCPServer 113971200 terminating
14:36:59 T:113438720 M:118370304 NOTICE: ES: UDP Event server stopped
14:36:59 T:113438720 M:118370304 DEBUG: Thread EventServer 113438720 terminating
14:36:59 T:112504832 M:118382592 NOTICE: stop sap announcement listener
14:36:59 T:112504832 M:118382592 NOTICE: clean cached files!
14:36:59 T:112504832 M:118382592 NOTICE: unload skin
14:36:59 T:112504832 M:118382592 INFO: Unloading old skin ...
14:36:59 T:112504832 M:118382592 DEBUG: ------ Window Deinit (Home.xml) ------
14:36:59 T:112504832 M:118374400 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
14:36:59 T:112504832 M:118370304 DEBUG: ------ Window Deinit (DialogButtonMenu.xml) ------
14:36:59 T:112504832 M:118370304 DEBUG: ------ Window Deinit (DialogMuteBug.xml) ------
14:36:59 T:112504832 M:118370304 DEBUG: Cleanup - Closed bundle
14:36:59 T:112504832 M:129830912 DEBUG: ADDON: Stopping service addons.
14:36:59 T:112504832 M:129830912 NOTICE: stop python
14:36:59 T:112504832 M:129830912 DEBUG: GUI Shader - Destroying Shader : 0x1e638d90
14:36:59 T:112504832 M:129826816 NOTICE: stopped
14:36:59 T:112504832 M:129826816 NOTICE: destroy
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e641780 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e63ef80 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e645e10 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e642420 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e63f5f0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e63e9f0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 0x1e63f630 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
14:36:59 T:112504832 M:129826816 NOTICE: unload sections
14:36:59 T:112504832 M:129826816 DEBUG: SECTION:UnloadAll(DLL: special://xbmcbin/system/libcpluff-arm-osx.so)
14:36:59 T:112504832 M:129826816 DEBUG: Unloading: libcpluff-arm-osx.so
14:36:59 T:112504832 M:129826816 DEBUG: SECTION:UnloadAll(DLL: libcurl.4.dylib)
14:36:59 T:112504832 M:129826816 DEBUG: Unloading: libcurl.4.dylib
14:36:59 T:112504832 M:129662976 DEBUG: object 0 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 1 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 2 --> 13 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 3 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 4 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 5 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 6 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 7 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 8 --> 0 instances
14:36:59 T:112504832 M:129662976 DEBUG: object 9 --> 0 instances
14:36:59 T:112504832 M:129654784 NOTICE: destroy
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
14:36:59 T:112504832 M:129654784 NOTICE: unload sections
14:36:59 T:112504832 M:129654784 DEBUG: object 0 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 1 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 2 --> 11 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 3 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 4 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 5 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 6 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 7 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 8 --> 0 instances
14:36:59 T:112504832 M:129654784 DEBUG: object 9 --> 0 instances
14:36:59 T:112504832 M:129654784 NOTICE: application stopped...
I just updated to 10.6.8. It still crashes but now my log file says that I’m using Kilrathi (10.8.0).
I also noticed two more things. When I go to all movies they show up Z-A now, before they were A-Z. Also I noticed that PleXBMC doesn’t change covers and fanarts when I change them at Plex. For example if I enter XBMC before Plex downloaded the cover and fanart it won’t ever show up at PleXBMC, even if Plex added them later.
hmm, not sure why reverse sorting is in place. I did notice it before, but that was on a later XMBC revision and a reinstall of 10.1 fixed it.
As for cover art, XBMC will have cached the [blank] image. It'll be another 24 hours that's rechecked and then it will be reloaded the next time after that.
I'll do some more testing on the settings page, but might be an idea to test a later build first.
Woops - sorry, just double checked the git commit reference and you are actually running 10.1 not a nightly build - which is even stranger. I'll double check this on my mac client, although I think I moved that to a nightly build (although moving between builds is easier on macs anyway)..
I just reinstalled 10.1 but no one of my issues got solved…
Then I downgraded to PleXBMC 1.9c (I dont have 1.9e anymore) and the Z-A issue was solved. I also can enter the configuration menu again. Then I upgraded to 1.9.3 again and all the issues showed up again.
Thanks for doing that investigation. Sorting was reintroduced to allow the use of the skip to a letter function in XBMC. No Idea why it’s sorting reverse.
At least I can go back and see what might have caused the problem with settings.
Found the settings bug - one of my conditional settings had a formula that looked for another setting location that didn’t exist. Fixed and will push out later tonight
Hi guys
Should this work with xbmc on the 1 gen ATV?
I have one stored away that i stopped using due to lack of plex support but this might bring it back to life for the guest bedroom
cheers
New version 1.9.3a pushed out to fix a couple of urgent issues:
- On some platforms, accessing settings would crash XBMC. This was an issue with my condition settings formula
- Skin would sometimes show a corrupted view of the plugin settings when access as Preferences -> PleXBMC settings
A new skin download (0.4.4) is required to complete the second fix.
Sorry those two slipped through - it seems different platforms have different ways of reacting to this. But it seems that ATV and OSX liked it least of all…
I've got an idea why this might be happening. Does you Plex Media Server have an assigned name (in the PMS settings)..
I have a fix for this issue, but want to make sure that this fixes, rather than hides the problem.
Are you able to run PleXBMC with debug turned on (PleXBMC settings -> debug -> enable debug) and either pastebin or PM the details. I only need the bits between the PLEXBMC START and PLEXBMC STOP entries, but if you can't see them, just send me the lot. As soon as I can confirm I'll roll out the fix.
