Plexbmc does not "see" the Plex Media library
When Starting it only shows (empty) channels section
I just started to play around with the Plexbmc on Pi ( OPenElec). At least the 2.0 Beta seems to work somehow but it does not show any content from the Plex Server
Server is up and running a plex client on Nexus7 works pretty well . . -
I could provide the xbmc.log
cheer
T
Hi again,
and some more details it looks like it struggles with IPv6 . . . if you see the bold stuff in the log below. It gets the IPv4 URL but then later tries to use parts of the IPV6 URL (???)
cheers
TS
snip
19:53:58 T:1189344352 NOTICE: ===== PLEXBMC START =====
19:53:58 T:1189344352 NOTICE: PleXBMC -> running on sys.version_info(major=2, minor=7, micro=3, releaselevel=‘final’, serial=0)
19:53:58 T:1189344352 NOTICE: PleXBMC -> running on 2.0b rev 1
19:53:58 T:1189344352 NOTICE: PleXBMC -> Running with cElementTree on Python 2.5+
19:53:58 T:1189344352 NOTICE: PleXBMC -> Flatten is: 0
19:53:58 T:1189344352 NOTICE: PleXBMC -> Settings streaming: 0
19:53:58 T:1189344352 NOTICE: PleXBMC -> Setting filter menus: false
19:53:58 T:1189344352 NOTICE: PleXBMC -> Setting debug to true
19:53:58 T:1189344352 NOTICE: PleXBMC -> Setting stream Control to : 0
19:53:58 T:1189344352 NOTICE: PleXBMC -> Running skin: skin.confluence
19:53:58 T:1189344352 NOTICE: PleXBMC -> Running watch view skin: xbmc
19:53:58 T:1189344352 NOTICE: PleXBMC -> Force DVD playback: false
19:53:58 T:1189344352 NOTICE: PleXBMC -> SMB IP Override: false
19:53:58 T:1189344352 NOTICE: PleXBMC -> Script argument is 0
19:53:58 T:1189344352 NOTICE: == ENTER: get_params ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> get_params: Parameter string: ?content_type=video
19:53:59 T:1189344352 NOTICE: PleXBMC -> get_params: Returning: {‘content_type’: ‘video’}
19:53:59 T:1189344352 NOTICE: PleXBMC -> Mode: -1
19:53:59 T:1189344352 NOTICE: PleXBMC -> URL: None
19:53:59 T:1189344352 NOTICE: PleXBMC -> Name:
19:53:59 T:1189344352 NOTICE: PleXBMC -> ID: None
19:53:59 T:1189344352 NOTICE: PleXBMC -> identifier: None
19:53:59 T:1189344352 NOTICE: PleXBMC -> token: None
19:53:59 T:1189344352 NOTICE: == ENTER: discoverAllServers ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> Settings hostname and port: 192.168.0.112:32400
19:53:59 T:1189344352 NOTICE: PleXBMC -> serverList is [{‘uuid’: None, ‘serverName’: ‘unknown’, ‘token’: None, ‘role’: ‘master’, ‘address’: ‘192.168.0.112:32400’, ‘discovery’: ‘local’}]
19:53:59 T:1189344352 NOTICE: == ENTER: displaySections() ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> displaySections: Using list of 1 servers: [{‘uuid’: None, ‘serverName’: ‘unknown’, ‘token’: None, ‘role’: ‘master’, ‘address’: ‘192.168.0.112:32400’, ‘discovery’: ‘local’}]
19:53:59 T:1189344352 NOTICE: == ENTER: getAllSections ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> getAllSections: Using servers list: [{‘uuid’: None, ‘serverName’: ‘unknown’, ‘token’: None, ‘role’: ‘master’, ‘address’: ‘192.168.0.112:32400’, ‘discovery’: ‘local’}]
19:53:59 T:1189344352 NOTICE: == ENTER: getURL ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> getURL: url = http://192.168.0.112:32400/system/library/sections
19:53:59 T:1189344352 NOTICE: PleXBMC -> getURL: header = {}
19:53:59 T:1189344352 NOTICE: PleXBMC -> getURL: ====== XML returned =======
19:53:59 T:1189344352 NOTICE: <?xml version='1.0' encoding='utf-8'?>
19:53:59 T:1189344352 NOTICE: PleXBMC -> getURL: ====== XML finished ======
19:53:59 T:1189344352 NOTICE: == ENTER: addDir ==
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Adding Dir for [Filme]
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed arguments are {‘fanart_image’: ‘http://fe80::212:79ff:fe67:fbd3:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2F%3A%2Fresources%2Fmovie-fanart.jpg&width=1280&height=720’, ‘type’: ‘Video’, ‘thumb’: ‘http://fe80::212:79ff:fe67:fbd3:32400/:/resources/movie-fanart.jpg’}
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed details are {‘title’: ‘Filme’}
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: URL to use for listing: plugin://plugin.video.plexbmc/?url=http://fe80::212:79ff:fe67:fbd3:32400/library/sections/2/all&mode=2
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Setting thumbnail as http://fe80::212:79ff:fe67:fbd3:32400/:/resources/movie-fanart.jpg
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Setting fan art as http://fe80::212:79ff:fe67:fbd3:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2F%3A%2Fresources%2Fmovie-fanart.jpg&width=1280&height=720 with headers:
19:53:59 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Building Context Menus
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Adding Dir for [Musik]
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed arguments are {‘fanart_image’: ‘http://fe80::212:79ff:fe67:fbd3:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2F%3A%2Fresources%2Fmovie-fanart.jpg&width=1280&height=720’, ‘type’: ‘Video’, ‘thumb’: ‘http://fe80::212:79ff:fe67:fbd3:32400/:/resources/movie-fanart.jpg’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed details are {‘title’: ‘Musik’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: URL to use for listing: plugin://plugin.video.plexbmc/?url=http://fe80::212:79ff:fe67:fbd3:32400/library/sections/1/all&mode=2
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Setting thumbnail as http://fe80::212:79ff:fe67:fbd3:32400/:/resources/movie-fanart.jpg
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Setting fan art as http://fe80::212:79ff:fe67:fbd3:32400/photo/:/transcode?url=http%3A%2F%2Flocalhost%3A32400%2F%3A%2Fresources%2Fmovie-fanart.jpg&width=1280&height=720 with headers:
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Building Context Menus
19:54:00 T:1189344352 NOTICE: == ENTER: addDir ==
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Adding Dir for [Recordings]
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed details are {‘title’: ‘Recordings’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: URL to use for listing: plugin://plugin.video.plexbmc/?url=http://fe80::212:79ff:fe67:fbd3:32400/library/sections/6/all&mode=2
19:54:00 T:1189344352 NOTICE: == ENTER: resolveAllServers ==
19:54:00 T:1189344352 NOTICE: == ENTER: getLocalServers ==
19:54:00 T:1189344352 NOTICE: == ENTER: getURL ==
19:54:00 T:1189344352 NOTICE: PleXBMC -> getURL: url = 192.168.0.112:32400/servers
19:54:00 T:1189344352 NOTICE: PleXBMC -> getURL: header = {}
19:54:00 T:1189344352 NOTICE: PleXBMC -> getURL: ====== XML returned =======
19:54:00 T:1189344352 NOTICE: <?xml version="1.0" encoding="UTF-8"?>
19:54:00 T:1189344352 NOTICE: PleXBMC -> getURL: ====== XML finished ======
19:54:00 T:1189344352 NOTICE: PleXBMC -> resolveAllServers: Resolved server List: [{‘uuid’: ‘34037aa5937d8a7e4e8d6557f2af3f489bf74b67’, ‘serverName’: ‘MyMediaServer’, ‘owned’: ‘1’, ‘token’: None, ‘master’: 1, ‘address’: ‘192.168.0.112:32400’, ‘discovery’: ‘local’}]
19:54:00 T:1189344352 NOTICE: PleXBMC -> resolveAllServers: Unique server List: [{‘uuid’: ‘34037aa5937d8a7e4e8d6557f2af3f489bf74b67’, ‘serverName’: ‘MyMediaServer’, ‘owned’: ‘1’, ‘token’: None, ‘master’: 1, ‘address’: ‘192.168.0.112:32400’, ‘discovery’: ‘local’}]
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Adding Dir for [Channels]
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed arguments are {‘type’: ‘Video’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed details are {‘title’: ‘Channels’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: URL to use for listing: plugin://plugin.video.plexbmc/?url=http://192.168.0.112:32400/system/plugins/all&mode=21
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Setting fan art as with headers:
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Adding Dir for [Plex Online]
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed arguments are {‘type’: ‘file’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: Passed details are {‘title’: ‘Plex Online’}
19:54:00 T:1189344352 NOTICE: PleXBMC -> addGUIItem: URL to use for listing: plugin://plugin.video.plexbmc/?url=http://192.168.0.112:32400/system/plexonline&mode=19
19:54:00 T:1118827616 DEBUG: WaitOnScriptResult- plugin returned successfully
19:54:00 T:1189344352 NOTICE: ===== PLEXBMC STOP =====
19:54:00 T:1075737104 DEBUG: Saving fileitems [plugin://plugin.video.plexbmc/?content_type=video]
19:54:00 T:1075737104 DEBUG: – items: 5, sort method: 0, ascending: false
19:54:01 T:1189344352 INFO: Scriptresult: Success
19:54:01 T:1189344352 INFO: Python script stopped
19:54:01 T:1189344352 DEBUG: Thread XBPyThread 1189344352 terminating
19:54:01 T:1189344352 NOTICE: Thread Background Loader start, auto delete: false
19:54:01 T:1075737104 DEBUG: waiting for python thread 27 to stop
19:54:01 T:1075737104 DEBUG: python thread 27 destructed
19:54:01 T:1075737104 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
19:54:01 T:1189344352 DEBUG: Thread Background Loader 1189344352 terminating
19:54:11 T:1075737104 DEBUG: LIRC: Update - NEW at 34696264:160 0 KEY_OK devinput (KEY_OK)
19:54:11 T:1075737104 DEBUG: OnKey: 11 (0b) pressed, action is Select**
19:54:11 T:1075737104 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.plexbmc/?url=http://fe80::212:79ff:fe67:fbd3:32400/library/sections/1/all&mode=2)**
19:54:11 T:1075737104 DEBUG: ParentPath = [plugin://plugin.video.plexbmc/?content_type=video]
19:54:11 T:1118827616 DEBUG: StartScript - calling plugin PleXBMC(‘plugin://plugin.video.plexbmc/’,‘0’,’?url=http://fe80/library/sections/1/all&mode=2’)
19:54:11 T:1118827616 INFO: initializing python engine.
19:54:11 T:1118827616 DEBUG: new python thread created. id=28
19:54:11 T:1118827616 DEBUG: WaitOnScriptResult - waiting on the PleXBMC plugin…
19:54:11 T:1189344352 NOTICE: Thread XBPyThread start, auto delete: false
19:54:11 T:1189344352 DEBUG: Python thread: start processing
19:54:12 T:1189344352 NOTICE: -->Python Interpreter Initialized<–
19:54:12 T:1189344352 DEBUG: Process - The source file to load is /storage/.xbmc/addons/plugin.video.plexbmc/default.py
19:54:12 T:1189344352 DEBUG: Process - Setting the Python path to /storage/.xbmc/addons/plugin.video.plexbmc:/storage/.xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/PIL:/usr/lib/python2.7/site-packages/gtk-2.0:
19:54:12 T:1189344352 DEBUG: Process - Entering source directory /storage/.xbmc/addons/plugin.video.plexbmc
19:54:12 T:1189344352 DEBUG: Instantiating addon using automatically obtained id of “plugin.video.plexbmc” dependent on version 2.0 of the xbmc.python api
19:54:12 T:1075737104 DEBUG: ------ Window Init (DialogBusy.xml) ------
19:54:12 T:1075737104 DEBUG: LIRC: Update - NEW at 34696801:160 0 KEY_OK_UP devinput (KEY_OK_UP)
19:54:13 T:1189344352 ERROR: /storage/.xbmc/addons/plugin.video.plexbmc/default.py:760: SyntaxWarning: name ‘g_stream’ is used prior to global declaration
global g_stream
19:54:15 T:1189344352 NOTICE: ===== PLEXBMC START =====
19:54:15 T:1189344352 NOTICE: PleXBMC -> running on sys.version_info(major=2, minor=7, micro=3, releaselevel=‘final’, serial=0)
19:54:15 T:1189344352 NOTICE: PleXBMC -> running on 2.0b rev 1
19:54:15 T:1189344352 NOTICE: PleXBMC -> Running with cElementTree on Python 2.5+
19:54:15 T:1189344352 NOTICE: PleXBMC -> Flatten is: 0
19:54:15 T:1189344352 NOTICE: PleXBMC -> Settings streaming: 0
19:54:15 T:1189344352 NOTICE: PleXBMC -> Setting filter menus: false
19:54:15 T:1189344352 NOTICE: PleXBMC -> Setting debug to true
19:54:15 T:1189344352 NOTICE: PleXBMC -> Setting stream Control to : 0
19:54:15 T:1189344352 NOTICE: PleXBMC -> Running skin: skin.confluence
19:54:15 T:1189344352 NOTICE: PleXBMC -> Running watch view skin: xbmc
19:54:15 T:1189344352 NOTICE: PleXBMC -> Force DVD playback: false
19:54:15 T:1189344352 NOTICE: PleXBMC -> SMB IP Override: false
19:54:15 T:1189344352 NOTICE: PleXBMC -> Script argument is 0
19:54:15 T:1189344352 NOTICE: == ENTER: get_params ==
19:54:16 T:1189344352 NOTICE: PleXBMC -> get_params: Parameter string: ?url=http://fe80/library/sections/1/all&mode=2
19:54:16 T:1189344352 NOTICE: PleXBMC -> get_params: Returning: {‘url’: ‘http://fe80/library/sections/1/all’, ‘mode’: ‘2’}
19:54:16 T:1189344352 NOTICE: PleXBMC -> Mode: 2
19:54:16 T:1189344352 NOTICE: PleXBMC -> URL: http://fe80/library/sections/1/all
19:54:16 T:1189344352 NOTICE: PleXBMC -> Name:
19:54:16 T:1189344352 NOTICE: PleXBMC -> ID: None
19:54:16 T:1189344352 NOTICE: PleXBMC -> identifier: None
19:54:16 T:1189344352 NOTICE: PleXBMC -> token: None
19:54:16 T:1189344352 NOTICE: == ENTER: Movies() ==
19:54:16 T:1189344352 NOTICE: == ENTER: getURL ==
19:54:16 T:1189344352 NOTICE: PleXBMC -> getURL: url = http://fe80/library/sections/1/all
19:54:16 T:1189344352 NOTICE: PleXBMC -> getURL: header = {}
19:54:16 T:1189344352 NOTICE: Unable to lookup host: fe80
Check host name is correct
19:54:16 T:1189344352 NOTICE: ===== PLEXBMC STOP =====
snap
Sorry, I didn;t see this thread. someone else has reported IPv6 issues. When parsing the XML data, PleXBMC expected to see an IPv4 style address x.x.x.x not an ipv6 one x:x:x:x:x:x. As port numbers are removed from any address URLs (including ip ones), then it only look at everything before the first :. ok in ipv4, not ok in ipv6.
Also, there are no provisions from IPv6 URLS (i.e. http://[ff:ff:ff:ff:ff:ff]:32400/library )in the addon.
My advice right now would be to switch off IPv6 at the plex media server.
