ATV3: No Plex Library Sections Available
Hi guys! I'm a new to plex and I'm trying to setup my ATV3 with PlexConnet, but no luck.
My setup is:
  • ATV3,
    • Firmware 6.2
    • DNS Server 192.168.10.140 (PMS and Plexconnect Server)
  • PMS+PlexConnect Server
    • OS: Windows 7 Edition Famliale Premimun, Service pack 1 (French version, long story!)
    • IP Address: 192.168.10.140
    • PMS Version: Version 2.2.5
    • PlexConnect: Version 0.4-dev
  • Settings.cfg
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.10.140
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
Note: I thought it was something related to authentication, but "Require authentication on local networks" is NOT checked. I even added 192.168.10.0/255.255.255.0 to "List of networks that are allowed without auth".
I should also mention that I do have content on Plex, which I can see from other computers via web browser and iPad via Plex App.
At this point I'm not sure what to look for.  Any help would be really appreciated.
Cheers!
log: "This paste has been removed!"
Strange.... let me paste it instead:
09:57:14 PlexConnect: started: 09:57:14
09:57:14 PlexConnect: Version: 0.4-dev
09:57:14 PlexConnect: Python: 2.7.6 (default, Feb 27 2014, 14:15:49) [MSC v.1500 32 bit (Intel)]
09:57:14 PlexConnect: Host OS: win32
09:57:14 Settings: getsetting enable_plexconnect_autodetect=True
09:57:14 PlexConnect: IP_self: 192.168.10.140
09:57:14 Settings: getsetting hosttointercept=trailers.apple.com
09:57:14 Settings: getsetting enable_dnsserver=True
09:57:14 Settings: getsetting enable_webserver_ssl=True
09:57:14 DNSServer: started: 09:57:14
09:57:14 Settings: getsetting port_dnsserver=53
09:57:14 Settings: getsetting ip_dnsmaster=8.8.8.8
09:57:14 Settings: getsetting prevent_atv_update=True
09:57:14 DNSServer: ***
09:57:14 DNSServer: DNSServer: Serving DNS on 192.168.10.140 port 53.
09:57:14 DNSServer: intercept: ['trailers.apple.com'] => 192.168.10.140
09:57:14 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
09:57:14 DNSServer: forward other to higher level DNS: 8.8.8.8
09:57:14 WebServer: started: 09:57:14
09:57:14 Settings: getsetting port_webserver=80
09:57:14 WebServer: ***
09:57:14 WebServer: WebServer: Serving HTTP on 192.168.10.140 port 80.
09:57:14 ATVSettings: init class CATVSettings
09:57:14 ATVSettings: load settings
09:57:15 WebServer: started: 09:57:15
09:57:15 Settings: getsetting port_ssl=443
09:57:15 Settings: getsetting certfile=./assets/certificates/trailers.pem
09:57:15 WebServer: ***
09:57:15 WebServer: WebServer: Serving HTTPS on 192.168.10.140 port 443.
09:57:43 DNSServer: DNS request received!
09:57:43 DNSServer: Source: ('192.168.10.102', 65493)
09:57:43 DNSServer: Domain: p71-buy.itunes.apple.com
09:57:43 DNSServer: ***forward request
09:57:43 DNSServer: -> DNS response from higher level
09:58:06 DNSServer: DNS request received!
09:58:06 DNSServer: Source: ('192.168.10.102', 59648)
09:58:06 DNSServer: Domain: trailers.apple.com
09:58:06 DNSServer: ***intercept request
09:58:06 DNSServer: -> DNS response: 192.168.10.140
09:58:06 WebServer: http request header:
Host: trailers.apple.com Accept-Encoding: gzip, deflate Accept: */* Accept-Language: en;q=0.9 Cookie: mz_at0-129515114=AwQAAAEMAADEfAAAAABSVfF4kIgv+ga03dndfJRVc4tWrdzIGEc=; mz_at_ssl-129515114=AwUAAAEMAADEfAAAAABSVfF4p0fqAX3y+de1lRl0JBOUrZmISNM=; s_vi=[CS]v1|27BD282285159953-40000174603103CE[CE]; X-Dsid=129515114 Connection: keep-alive X-Apple-TV-Resolution: 1080 X-Apple-TV-Version: 6.2 User-Agent: iTunes-AppleTV/6.2 (3; 8GB; dt:12)
09:58:06 WebServer: http request path:
/appletv/us/js/application.js
09:58:06 Localize: aTVLanguage: en
09:58:06 WebServer: pms address:
09:58:06 WebServer: cleaned path:
09:58:06 WebServer: PlexConnect options:
{‘aTVScreenResolution’: ‘1080’, ‘aTVFirmwareVersion’: ‘6.2’, ‘aTVLanguage’: ‘en’, ‘aTVAddress’: ‘192.168.10.102’}
09:58:06 WebServer: additional arguments:
09:58:06 WebServer: serving /js/application.js
Host: trailers.apple.com X-Apple-Store-Front: 143455-6,19 ab:XYZ1 Accept: / Accept-Encoding: gzip, deflate Accept-Language: en;q=0.9 Cookie: mz_at0-129515114=AwQAAAEMAADEfAAAAABSVfF4kIgv+ga03dndfJRVc4tWrdzIGEc=; s_vi=[CS]v1|27BD282285159953-40000174603103CE[CE]; X-Dsid=129515114 Connection: keep-alive X-Apple-TV-Resolution: 1080 X-Apple-TV-Version: 6.2 User-Agent: iTunes-AppleTV/6.2 (3; 8GB; dt:12)
/&PlexConnect=Discover&PlexConnectUDID=DY4HFTTLDRHN
{‘aTVAddress’: ‘192.168.10.102’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectUDID’: ‘DY4HFTTLDRHN’, ‘aTVLanguage’: ‘en’, ‘aTVFirmwareVersion’: ‘6.2’, ‘PlexConnect’: ‘Discover’}
09:58:06 WebServer: serving .xml: /
09:58:06 XMLConverter: PlexConnect Cmd: Discover
09:58:06 XMLConverter: PlexConnectChannelsSearch:
09:58:06 ATVSettings: getsetting NKvQy1s5W2pxb43Kk1be
09:58:06 Settings: getsetting enable_plexgdm=True
09:58:06 PlexAPI: ***
09:58:06 PlexAPI: looking up Plex Media Server
09:58:06 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
09:58:06 PlexAPI: Received data from (‘169.254.62.159’, 32414)
09:58:06 PlexAPI: Data received:
HTTP/1.0 200 OK Content-Type: plex/media-server Resource-Identifier: 10d52a6a0f2dece74fc79ebf50d01e481701e769 Name: Hans-PC7 Port: 32400 Updated-At: 1410417157 Version: 0.9.9.14.531-7eef8c6
09:58:07 PlexAPI: GDM: Servers discovered: 1
09:58:07 PlexAPI: Hans-PC7 169.254.62.159:32400
09:58:07 PlexAPI: URL: https://plex.tv/pms/servers
09:58:07 PlexAPI: xargs: {‘X-Plex-Token’: ‘NKvQy1s5W2pxb43Kk1be’}
09:58:08 PlexAPI: ====== received PMS-XML ======
09:58:08 09:58:09 WebServer: http request header:
09:58:09 WebServer: http request path:
09:58:09 Localize: aTVLanguage: en
09:58:09 WebServer: pms address:
09:58:09 WebServer: cleaned path:
09:58:09 WebServer: PlexConnect options:
09:58:09 WebServer: additional arguments:
09:58:09 WebServer: serving .xml: /
09:58:09 XMLConverter: PlexConnect Cmd: Discover
09:58:09 XMLConverter: PlexConnectChannelsSearch:
09:58:09 ATVSettings: getsetting NKvQy1s5W2pxb43Kk1be
09:58:09 Settings: getsetting enable_plexgdm=True
09:58:09 PlexAPI: ***
09:58:09 PlexAPI: looking up Plex Media Server
09:58:09 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
09:58:09 PlexAPI: Received data from (‘169.254.62.159’, 32414)
09:58:09 PlexAPI: Data received:
09:58:10 PlexAPI: GDM: Servers discovered: 1
09:58:10 PlexAPI: Hans-PC7 169.254.62.159:32400
09:58:10 PlexAPI: URL: https://plex.tv/pms/servers
09:58:10 PlexAPI: xargs: {‘X-Plex-Token’: ‘NKvQy1s5W2pxb43Kk1be’}
09:58:10 PlexAPI: ====== received PMS-XML ======
09:58:10 09:58:10 WebServer: http request header:
09:58:10 WebServer: http request path:
09:58:10 Localize: aTVLanguage: en
09:58:10 WebServer: pms address:
09:58:10 WebServer: cleaned path:
09:58:10 WebServer: PlexConnect options:
09:58:10 WebServer: additional arguments:
09:58:10 WebServer: serving .xml: /
09:58:10 XMLConverter: PlexConnect Cmd: Discover
09:58:10 XMLConverter: PlexConnectChannelsSearch:
09:58:10 ATVSettings: getsetting NKvQy1s5W2pxb43Kk1be
09:58:10 Settings: getsetting enable_plexgdm=True
09:58:10 PlexAPI: ***
09:58:10 PlexAPI: looking up Plex Media Server
09:58:10 PlexAPI: Sending discovery message: M-SEARCH * HTTP/1.0
09:58:10 PlexAPI: Received data from (‘169.254.62.159’, 32414)
09:58:10 PlexAPI: Data received:
09:58:11 PlexAPI: GDM: Servers discovered: 1
09:58:11 PlexAPI: Hans-PC7 169.254.62.159:32400
09:58:11 PlexAPI: URL: https://plex.tv/pms/servers
09:58:11 PlexAPI: xargs: {‘X-Plex-Token’: ‘NKvQy1s5W2pxb43Kk1be’}
09:58:11 PlexAPI: ====== received PMS-XML ======
09:58:11 09:58:11 WebServer: http request header:
Host: trailers.apple.com Accept: / Accept-Encoding: gzip, deflate Accept-Language: en Cookie: ns-mzf-inst=41-26-80-153-11-8121-712335-71-nk11; xp_ci=3z1ljHVNzGhNz5INzCG5zSdK7uDX6; s_vi=[CS]v1|27BD282285159953-40000174603103CE[CE]; Pod=71; mz_at0-129515114=AwQAAAEMAADrKAAAAABT57jn+uQ7RqAbt+z6k+RQ4Zpr32NBEzI=; itspod=71; X-Dsid=129515114 Connection: keep-alive X-Apple-TV-Resolution: 1080 X-Apple-TV-Version: 6.2 User-Agent: iTunes-AppleTV/6.2 (3; 8GB; dt:12)
09:58:11 WebServer: http request path:
/PlexConnect.xml&PlexConnectUDID=DY4HFTTLDRHN
09:58:11 Localize: aTVLanguage: en
09:58:11 WebServer: pms address:
09:58:11 WebServer: cleaned path:
/PlexConnect.xml
09:58:11 WebServer: PlexConnect options:
{‘aTVScreenResolution’: ‘1080’, ‘PlexConnectUDID’: ‘DY4HFTTLDRHN’, ‘aTVFirmwareVersion’: ‘6.2’, ‘aTVLanguage’: ‘en’, ‘aTVAddress’: ‘192.168.10.102’}
09:58:11 WebServer: additional arguments:
09:58:11 WebServer: serving .xml: /PlexConnect.xml
09:58:11 XMLConverter: PlexConnect Cmd:
09:58:11 XMLConverter: PlexConnectChannelsSearch:
09:58:11 XMLConverter: XMLTemplate: PlexConnect.xml
09:58:11 XMLConverter: XML_ExpandNode: None - done
09:58:11 XMLConverter: XML_ExpandNode: {{CUT($myplex_auth:CUT:=CUT| =)}}
09:58:11 XMLConverter: CCmds_getParam: $myplex_auth, CUT:=CUT| =
09:58:11 XMLConverter: CCmds_getParam: CUT, =CUT| =
09:58:11 ATVSettings: getsetting NKvQy1s5W2pxb43Kk1be
09:58:11 XMLConverter: CCmds_getKey: NKvQy1s5W2pxb43Kk1be,=CUT| =,False
09:58:11 XMLConverter: CCmds_getParam: =CUT| =,
09:58:11 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (’ ', ‘’)],
09:58:11 XMLConverter: CCmds_applyConversion:
09:58:11 XMLConverter: XML_ExpandNode: {{TEXT(Playlists)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Playlists)}}
09:58:11 XMLConverter: XML_ExpandNode: {{URL(:/PMS(all)/playlists&PlexConnect=Playlists)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(all)/playlists&PlexConnect=Playlists)}}
09:58:11 XMLConverter: XML_ExpandNode: {{TEXT(Library)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Library)}}
09:58:11 XMLConverter: XML_ExpandNode: {{URL(:/PMS(owned)/library/sections)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(owned)/library/sections)}}
09:58:11 XMLConverter: XML_ExpandNode: {{TEXT(Channels)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Channels)}}
09:58:11 XMLConverter: XML_ExpandNode: {{URL(:/PMS(owned)/channels/all)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(owned)/channels/all)}}
09:58:11 XMLConverter: XML_ExpandNode: {{TEXT(Shared Libraries)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Shared Libraries)}}
09:58:11 XMLConverter: XML_ExpandNode: {{URL(:/PMS(shared)/library/sections)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/PMS(shared)/library/sections)}}
09:58:11 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (’ ‘, ‘’)],
09:58:11 XMLConverter: XML_ExpandNode: {{TEXT(Settings)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Settings)}}
09:58:11 XMLConverter: XML_ExpandNode: {{URL(:/&PlexConnect=Settings)}}
09:58:11 XMLConverter: XML_ExpandNode - Stumbled over URL in line {{URL(:/&PlexConnect=Settings)}}
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/js/utils.js)}}
09:58:11 XMLConverter: CCmds_getParam: , /js/utils.js
09:58:11 XMLConverter: CCmds_getParam: /js/utils.js,
09:58:11 XMLConverter: CCmds_getKey: /js/utils.js,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/utils.js - done
09:58:11 XMLConverter: XML_ExpandLine: {{VAL($myplex_auth:0:=0| =1)}}
09:58:11 XMLConverter: CCmds_getParam: $myplex_auth, 0:=0| =1
09:58:11 XMLConverter: CCmds_getParam: 0, =0| =1
09:58:11 XMLConverter: CCmds_getKey: NKvQy1s5W2pxb43Kk1be,=0| =1,False
09:58:11 XMLConverter: CCmds_getParam: =0| =1,
09:58:11 XMLConverter: CCmds_getConversion: [(’’, ‘0’), (’ ', ‘1’)],
09:58:11 XMLConverter: CCmds_applyConversion: 1
09:58:11 XMLConverter: XML_ExpandLine: 1 - done
09:58:11 XMLConverter: XML_ExpandLine: {{TEXT(Playlists)}}
09:58:11 XMLConverter: XML_ExpandLine: Playlists - done
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/PMS(all)/playlists&PlexConnect=Playlists)}}
09:58:11 XMLConverter: CCmds_getParam: , /PMS(all)/playlists&PlexConnect=Playlists
09:58:11 XMLConverter: CCmds_getParam: /PMS(all)/playlists&PlexConnect=Playlists,
09:58:11 XMLConverter: CCmds_getKey: /PMS(all)/playlists&PlexConnect=Playlists,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(all)/playlists&PlexConnect=Playlists - done
09:58:11 XMLConverter: XML_ExpandLine: {{TEXT(Library)}}
09:58:11 XMLConverter: XML_ExpandLine: Library - done
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/PMS(owned)/library/sections)}}
09:58:11 XMLConverter: CCmds_getParam: , /PMS(owned)/library/sections
09:58:11 XMLConverter: CCmds_getParam: /PMS(owned)/library/sections,
09:58:11 XMLConverter: CCmds_getKey: /PMS(owned)/library/sections,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(owned)/library/sections - done
09:58:11 XMLConverter: XML_ExpandLine: {{TEXT(Channels)}}
09:58:11 XMLConverter: XML_ExpandLine: Channels - done
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/PMS(owned)/channels/all)}}
09:58:11 XMLConverter: CCmds_getParam: , /PMS(owned)/channels/all
09:58:11 XMLConverter: CCmds_getParam: /PMS(owned)/channels/all,
09:58:11 XMLConverter: CCmds_getKey: /PMS(owned)/channels/all,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(owned)/channels/all - done
09:58:11 XMLConverter: XML_ExpandLine: {{TEXT(Shared Libraries)}}
09:58:11 XMLConverter: XML_ExpandLine: Shared Libraries - done
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/PMS(shared)/library/sections)}}
09:58:11 XMLConverter: CCmds_getParam: , /PMS(shared)/library/sections
09:58:11 XMLConverter: CCmds_getParam: /PMS(shared)/library/sections,
09:58:11 XMLConverter: CCmds_getKey: /PMS(shared)/library/sections,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS(shared)/library/sections - done
09:58:11 XMLConverter: XML_ExpandLine: {{TEXT(Settings)}}
09:58:11 XMLConverter: XML_ExpandLine: Settings - done
09:58:11 XMLConverter: XML_ExpandLine: {{URL(:/&PlexConnect=Settings)}}
09:58:11 XMLConverter: CCmds_getParam: , /&PlexConnect=Settings
09:58:11 XMLConverter: CCmds_getParam: /&PlexConnect=Settings,
09:58:11 XMLConverter: CCmds_getKey: /&PlexConnect=Settings,True
09:58:11 XMLConverter: XML_ExpandLine: http://trailers.apple.com/PMS()/&PlexConnect=Settings - done
09:58:11 XMLConverter: ====== generated aTV-XML ======
Playlists http://trailers.apple.com/PMS(all)/playlists&PlexConnect=Playlists Library http://trailers.apple.com/PMS(owned)/library/sections Channels http://trailers.apple.com/PMS(owned)/channels/all Shared Libraries http://trailers.apple.com/PMS(shared)/library/sections Settings http://trailers.apple.com/PMS()/&PlexConnect=Settings
09:58:11 XMLConverter: ====== aTV-XML finished ======
09:58:12 WebServer: http request header:
Host: trailers.apple.com Accept-Encoding: gzip, deflate Accept: / Accept-Language: en;q=0.9 Cookie: mz_at0-129515114=AwQAAAEMAADEfAAAAABSVfF4kIgv+ga03dndfJRVc4tWrdzIGEc=; s_vi=[CS]v1|27BD282285159953-40000174603103CE[CE]; X-Dsid=129515114 Connection: keep-alive X-Apple-TV-Resolution: 1080 X-Apple-TV-Version: 6.2 User-Agent: iTunes-AppleTV/6.2 (3; 8GB; dt:12)
09:58:12 WebServer: http request path:
/js/utils.js
09:58:12 Localize: aTVLanguage: en
09:58:12 WebServer: pms address:
09:58:12 WebServer: cleaned path:
/js/utils.js
09:58:12 WebServer: PlexConnect options:
09:58:12 WebServer: additional arguments:
09:58:12 WebServer: serving /js/utils.js
/&PlexConnectATVLogLevel=1&PlexConnectLog=loadItem%3A%20Library
{‘aTVAddress’: ‘192.168.10.102’, ‘aTVScreenResolution’: ‘1080’, ‘PlexConnectATVLogLevel’: ‘1’, ‘PlexConnectLog’: ‘loadItem: Library’, ‘aTVFirmwareVersion’: ‘6.2’, ‘aTVLanguage’: ‘en’}
09:58:12 ATVLogger: loadItem: Library
/PMS(owned)/library/sections&PlexConnectUDID=DY4HFTTLDRHN
owned
/library/sections
09:58:12 WebServer: serving .xml: /library/sections
09:58:12 XMLConverter: PlexConnect Cmd:
09:58:12 XMLConverter: PlexConnectChannelsSearch:
09:58:12 PlexAPI: URL: http://169.254.62.159:32400/library/sections
09:58:12 PlexAPI: xargs: {‘X-Plex-Platform’: ‘iOS’, ‘X-Plex-Model’: ‘3,1’, ‘X-Plex-Client-Platform’: ‘iOS’, ‘X-Plex-Client-Identifier’: ‘DY4HFTTLDRHN’, ‘X-Plex-Device’: ‘AppleTV’, ‘X-Plex-Product’: ‘PlexConnect’, ‘X-Plex-Platform-Version’: ‘6.2’, ‘X-Plex-Version’: ‘0.4-dev’}
09:58:12 PlexAPI: No Response from Plex Media Server
09:58:12 PlexAPI: We failed to reach a server. Reason: Unauthorized
09:58:12 PlexAPI: ====== Local Server/Sections XML ======
09:58:12 PlexAPI:
09:58:12 PlexAPI: ====== Local Server/Sections XML finished ======
09:58:12 XMLConverter: viewGroup: None
09:58:12 XMLConverter: XMLTemplate: Library.xml
09:58:12 XMLConverter: XML_ExpandNode: None - done
{{VAR(sections:NoKey:FALSE)}}
09:58:12 XMLConverter: CCmds_getParam: sections, NoKey:FALSE
09:58:12 XMLConverter: CCmds_getParam: NoKey, FALSE
09:58:12 XMLConverter: CCmds_getParam: FALSE,
09:58:12 XMLConverter: CCmds_getKey: FALSE,True
09:58:12 XMLConverter: CCmds_getParam: ,
09:58:12 XMLConverter: CCmds_getConversion: [],
{{CUT($libraryview::=CUT|List=|List =CUT)}}
09:58:12 XMLConverter: CCmds_getParam: $libraryview, :=CUT|List=|List =CUT
09:58:12 XMLConverter: CCmds_getParam: , =CUT|List=|List =CUT
09:58:12 ATVSettings: getsetting List
09:58:12 XMLConverter: CCmds_getKey: List,=CUT|List=|List =CUT,False
09:58:12 XMLConverter: CCmds_getParam: =CUT|List=|List =CUT,
09:58:12 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘List’, ‘’), ('List ', ‘CUT’)],
09:58:12 XMLConverter: CCmds_applyConversion:
09:58:12 XMLConverter: XML_ExpandNode: {{TEXT(Plex Library)}}
09:58:12 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Plex Library)}}
{{COPY(Server:@main/size::0=|1=COPY)}}
09:58:12 XMLConverter: CCmds_getParam: Server, @main/size::0=|1=COPY
09:58:12 XMLConverter: CCmds_getParam: @main/size, :0=|1=COPY
09:58:12 XMLConverter: CCmds_getParam: , 0=|1=COPY
09:58:12 XMLConverter: CCmds_getKey: 1,0=|1=COPY,False
09:58:12 XMLConverter: CCmds_getParam: 0=|1=COPY,
09:58:12 XMLConverter: CCmds_getConversion: [(‘0’, ‘’), (‘1’, ‘COPY’)],
09:58:12 XMLConverter: CCmds_applyConversion: COPY
09:58:12 XMLConverter: XML_ExpandNode: {{VAL(name)}}{{VAL(local::0= <{{TEXT(remote)}}>|0 =)}}
09:58:12 XMLConverter: XML_ExpandNode - Stumbled over VAL in line {{VAL(name)}}{{VAL(local::0= <{{TEXT(remote)}}>|0 =)}}
09:58:12 XMLConverter: XML_ExpandNode: {{CUT(@main/size:CUT:0=CUT|1=CUT|2=)}}
09:58:12 XMLConverter: CCmds_getParam: @main/size, CUT:0=CUT|1=CUT|2=
09:58:12 XMLConverter: CCmds_getParam: CUT, 0=CUT|1=CUT|2=
09:58:12 XMLConverter: CCmds_getKey: 1,0=CUT|1=CUT|2=,False
09:58:12 XMLConverter: CCmds_getParam: 0=CUT|1=CUT|2=,
09:58:12 XMLConverter: CCmds_getConversion: [(‘0’, ‘CUT’), (‘1’, ‘CUT’), (‘2’, ‘’)],
09:58:12 XMLConverter: CCmds_applyConversion: CUT
{{COPY(Directory)}}
{{VAR(sections:NoKey:TRUE)}}
09:58:12 XMLConverter: CCmds_getParam: Directory,
09:58:12 XMLConverter: XML_ExpandNode: {{TEXT(Search)}}
09:58:12 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(Search)}}
09:58:12 XMLConverter: XML_ExpandLine: atv.loadURL(’{{URL(searchKey)}}’)
09:58:12 XMLConverter: CCmds_getParam: searchKey,
09:58:12 XMLConverter: CCmds_getKey: PMS(169.254.62.159)/SearchForm.xml,False
09:58:12 XMLConverter: XML_ExpandLine: atv.loadURL(‘http://trailers.apple.com/PMS(169.254.62.159)/SearchForm.xml’) - done
09:58:12 XMLConverter: XML_ExpandLine: {{VAL(searchKey)}}
09:58:12 XMLConverter: CCmds_applyConversion: PMS(169.254.62.159)/SearchForm.xml
09:58:12 XMLConverter: XML_ExpandLine: PMS(169.254.62.159)/SearchForm.xml - done
09:58:12 XMLConverter: XML_ExpandLine: {{TEXT(Search)}}
09:58:12 XMLConverter: XML_ExpandLine: Search - done
09:58:12 XMLConverter: XML_ExpandNode: {{CUT(#sections::FALSE=CUT|TRUE=)}}
09:58:12 XMLConverter: CCmds_getParam: #sections, :FALSE=CUT|TRUE=
09:58:12 XMLConverter: CCmds_getParam: , FALSE=CUT|TRUE=
09:58:12 XMLConverter: CCmds_getKey: FALSE,FALSE=CUT|TRUE=,False
09:58:12 XMLConverter: CCmds_getParam: FALSE=CUT|TRUE=,
09:58:12 XMLConverter: CCmds_getConversion: [(‘FALSE’, ‘CUT’), (‘TRUE’, ‘’)],
{{CUT($libraryview:CUT:=CUT|Grid=|Grid =CUT)}}
09:58:12 XMLConverter: CCmds_getParam: $libraryview, CUT:=CUT|Grid=|Grid =CUT
09:58:12 XMLConverter: CCmds_getParam: CUT, =CUT|Grid=|Grid =CUT
09:58:12 XMLConverter: CCmds_getKey: List,=CUT|Grid=|Grid =CUT,False
09:58:12 XMLConverter: CCmds_getParam: =CUT|Grid=|Grid =CUT,
09:58:12 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘Grid’, ‘’), ('Grid ', ‘CUT’)],
{{CUT($libraryview:CUT:=CUT|Bookcase=|Bookcase =CUT)}}
09:58:12 XMLConverter: CCmds_getParam: $libraryview, CUT:=CUT|Bookcase=|Bookcase =CUT
09:58:12 XMLConverter: CCmds_getParam: CUT, =CUT|Bookcase=|Bookcase =CUT
09:58:12 XMLConverter: CCmds_getKey: List,=CUT|Bookcase=|Bookcase =CUT,False
09:58:12 XMLConverter: CCmds_getParam: =CUT|Bookcase=|Bookcase =CUT,
09:58:12 XMLConverter: CCmds_getConversion: [(’’, ‘CUT’), (‘Bookcase’, ‘’), ('Bookcase ', ‘CUT’)],
{{CUT(#sections::FALSE=|TRUE=CUT)}}
09:58:12 XMLConverter: CCmds_getParam: #sections, :FALSE=|TRUE=CUT
09:58:12 XMLConverter: CCmds_getParam: , FALSE=|TRUE=CUT
09:58:12 XMLConverter: CCmds_getKey: FALSE,FALSE=|TRUE=CUT,False
09:58:12 XMLConverter: CCmds_getParam: FALSE=|TRUE=CUT,
09:58:12 XMLConverter: CCmds_getConversion: [(‘FALSE’, ‘’), (‘TRUE’, ‘CUT’)],
09:58:12 XMLConverter: XML_ExpandNode: {{TEXT(No Plex Library Sections Available)}}
09:58:12 XMLConverter: XML_ExpandNode - Stumbled over TEXT in line {{TEXT(No Plex Library Sections Available)}}
09:58:12 XMLConverter: XML_ExpandLine: {{URL(:/js/utils.js)}}
09:58:12 XMLConverter: CCmds_getParam: , /js/utils.js
09:58:12 XMLConverter: CCmds_getParam: /js/utils.js,
09:58:12 XMLConverter: CCmds_getKey: /js/utils.js,True
09:58:12 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/utils.js - done
09:58:12 XMLConverter: XML_ExpandLine: {{URL(:/js/sectionHoldSelect.js)}}
09:58:12 XMLConverter: CCmds_getParam: , /js/sectionHoldSelect.js
09:58:12 XMLConverter: CCmds_getParam: /js/sectionHoldSelect.js,
09:58:12 XMLConverter: CCmds_getKey: /js/sectionHoldSelect.js,True
09:58:12 XMLConverter: XML_ExpandLine: http://trailers.apple.com/js/sectionHoldSelect.js - done
09:58:12 XMLConverter: XML_ExpandLine: {{TEXT(No Plex Library Sections Available)}}
09:58:12 XMLConverter: XML_ExpandLine: No Plex Library Sections Available - done
09:58:12 XMLConverter: ====== generated aTV-XML ======
PlexConnect No Plex Library Sections Available
09:58:12 XMLConverter: ====== aTV-XML finished ======
/js/utils.js
/js/utils.js
09:58:12 WebServer: serving /js/sectionHoldSelect.js
09:59:31 PlexConnect: Shutting down.
09:59:31 WebServer: Shutting down.
09:59:32 WebServer: Shutting down.
09:59:32 ATVSettings: save settings
09:59:36 DNSServer: Shutting down.
09:59:36 PlexConnect: shutdown
PMS is on .159 not .140 as said in your first post.
Any virtualization? Second network connection?
Set ip_pms to that and it should work...
Thanks Baa.
That is interesting to say the least. I saw the 169.254.62.159 address on the log and I didn't understand why it was using a local link address, or where it was it was getting it from... so I started to look for the address. The address was created by VirtualBox, although I'm not running this on a VM, not to mention VirtualBox is installed, but not running on this machine. This PC is the one I use for any new "thing" I'm about to install on the network, so I can mess it up without any consequences.
Anyhow, I even disabled the interface and still doesn't work. I will uninstall Vbox next and see what happens. If everything goes smoothly I will likely install this on a VBox, which resides on another host all together.
Configuration IP de Windows
Carte Ethernet Connexion au réseau local 2 :
Statut du média. . . . . . . . . . . . : Média déconnecté
Suffixe DNS propre à la connexion. . . :
Carte Ethernet Connexion au réseau local :
Suffixe DNS propre à la connexion. . . : home
Adresse IPv6 de liaison locale. . . . .: fe80::2075:ca50:bc4a:f859%11
Adresse IPv4. . . . . . . . . . . . . .: 192.168.10.140
Masque de sous-réseau. . . . . . . . . : 255.255.255.0
Passerelle par défaut. . . . . . . . . : 192.168.10.4
Carte réseau sans fil Connexion réseau sans fil :
Carte Ethernet VirtualBox Host-Only Network :
Adresse IPv6 de liaison locale. . . . .: fe80::ce9:1d6b:761e:3e9f%19
Adresse d’autoconfiguration IPv4 . . . : 169.254.62.159
Masque de sous-réseau. . . . . . . . . : 255.255.0.0
Carte Tunnel isatap.home :
Carte Tunnel Connexion au réseau local* :
Carte Tunnel isatap.{7721D180-415E-4BD6-9CE8-1E9351CAB4AC} :
Carte Tunnel isatap.{5BA6FE7D-63CD-4370-9A83-B20B6B4F2E89} :
Carte Tunnel isatap.{ACA44369-D902-4F16-80F2-9C1104F0E1CE} :
Hum, it works after un-instaling VBox from the host. Like I said, i was not really using it and it was not even running.
The minute you said "virtualization" it got me thinking! Thanks a lo Baat!!! I spent so many hours on this last night... quite frustrating.
PROBLEM SOLVED!
