@bocs100 said:
I see in the latest build you returned the progress lines is that better for Kodi 17 or 16?
It should work with Kodi 16 too, but you need a skin which supports it.
At the moment, only the Andromeda skin (github version only - krypton) supports it.
Is there a way âcastâ option can be made working on Kodi Krypton?
You can get the helper back. You have just to remove the â#â symbol from every line in the file âhelper.pyâ in the âplugin.video.plexbmcâ folder and then save the file.
However this will make Kodi hang on exitâŠ
Or switch to PlexKodiKonnect. Itâs working fairly well.
Tgx
Use Direct Paths with PlexKodiConnect if you plan to use music
Tgx
Direct paths with no music library sync nailed it! Thanks
I have Problems setting up a Friends System.
We both use Raspberry Pis, we both use OSMC with Kryton, we both use Plexbmc 4.1.
I did set up my both Pis the same way:
installed OSMC
switched to Amber-Skin
installed Plexbmc
authenticated my account in the Plexbmc settings
switched to Plex-Mode
Bam! Worked like a charm.
This works even with changing the Skin to the marvelous Andromeda (for the 4.1 and that Skin: Many Thanks to Tgx)
Today I tried the same procedure (which worked so well for me) at my friends house with his Pi and to my big surprise the sections didnât show up on the Homescreen. The Connection to the Server was there because we could navigate through it with Kodis inner âFilesystemâ and could watch stuff. But the Amber-Skin wouldnât update the way it did for me.
After some research here I found out to ACTIVATE (which is activated by default and so is untouched in my systems) the âUse menu for shared sectionsâ-option in plexbmc-setting so i chose, in my dispair, to deactivate it just to try anything and after that amber did show the Sections and we could access them by that, but the Homeshelf Widget (showing the recently added etc. Items) was not there.
BTW: The PMS is mine and I am sharing some Section/Libraries with my friend with the PMS-Friends-Functionality
Now I am at my witâs end Has anyone any ideas how to get that to work?
Would like to get this running on an Apple TV1. Reinstalled PlexBMC on an install of Openelec/Frodo.
Install worked but still says cannot reach server. Sees the server but cannot connect. I do not have secure connection on the server. anywhere I should look?
Does anyone know how to get the Plexbmc addon to always direct play?. I have it linked with iVue TV guide and have a feeling it is transcoding the streams
Any chance of anyone picking this back up? I can live without 18 for now⊠but i think this saves the settings in a folder that gets cleaned by most auto cleaners in builds i run⊠have to resign in everytime i reboot
And i know someone will say use this or that⊠but the official addons UI is just horrific⊠plus if you try to back out to do something else while itâs running it closes. And the other one (which i canât remember the name of) only connects to one server which makes it pretty useless for me as i use many serversâŠ
thanks guys⊠i wish i knew how to program but gotta beg instead
