Plexconnect and Netflix
Netflix and Plexconnect were running fine together on my ATV3 but SInce a couple of days Netflix doesn’t work anymore. I get the message that Netflix isn’t avaiable. Deleting the trailers.cer profile and change DNS to automatic makes Netflix work again, but them Plex won’t work anymore. The only thing i can think of is that Netflix did an update. What can i do to make Plexconnect end Netflix both work again?
whats your settings.cfg file contents, specifically the ip_dnsmaster master setting.
Is it set to the default of 8.8.8.8 or something else?
ip_dnsmaster is set to 0.0.0.0
0.0.0.0 is not a valid ip. So you will need to provide your full setup as per the how to report a problem section of the “Read before Posting” pinned thread. Without that we can’t really assist easily. It’s all about making it easy for us to help you
fixed it, i reinstalled the latest version and everything works again :s
topic can be closed
