Plexconnect - Can't connect
When I open trailers on my apple tv it says no media servers found. I also feel my plexconnect terminal on my computer keeps running the same loop.
Here is my log file
18:40:05 PlexConnect: started: 18:40:05
18:40:05 PlexConnect: IP_self: 192.168.0.100
18:40:05 DNSServer: started: 18:40:05
18:40:05 DNSServer: ***
18:40:05 DNSServer: Starting up.
18:40:05 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.100
18:40:05 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
18:40:05 DNSServer: forward other to higher level DNS: 8.8.8.8
18:40:05 WebServer: started: 18:40:05
18:40:05 WebServer: ***
18:40:05 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
18:40:05 PlexGDM: ***
18:40:05 PlexGDM: looking up Plex Media Server
18:40:06 PlexGDM: No servers discovered
18:40:06 XMLConverter: PlexGDM - no PMS found
18:40:20 DNSServer: DNS request received!
18:40:20 DNSServer: Source: ('192.168.0.103', 65503)
18:40:20 DNSServer: Domain: phobos.apple.com
18:40:20 DNSServer: ***forward request
18:40:20 DNSServer: -> DNS response from higher level
18:40:20 DNSServer: Source: ('192.168.0.103', 62339)
18:40:21 DNSServer: -> DNS response from higher level
18:40:21 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
18:40:21 DNSServer: DNS request received!
18:40:21 DNSServer: Source: ('192.168.0.103', 54384)
18:40:21 DNSServer: Domain: phobos.apple.com.akadns.net
18:40:21 DNSServer: ***forward request
18:40:38 DNSServer: DNS request received!
18:40:38 DNSServer: Source: ('192.168.0.103', 49583)
18:40:38 DNSServer: Domain: trailers.apple.com
18:40:38 DNSServer: ***intercept request
18:40:38 DNSServer: -> DNS response: 192.168.0.100
18:40:38 DNSServer: Source: ('192.168.0.103', 60795)
18:40:38 WebServer: serving application.js
18:40:38 DNSServer: Source: ('192.168.0.103', 62870)
18:40:38 DNSServer: Domain: atv.plexconnect
18:40:38 DNSServer: Source: ('192.168.0.103', 64598)
18:40:38 WebServer: serving C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\plexconnect.xml
18:40:38 WebServer: serving  C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\js\utils.js
18:40:39 ATVLogger: loadItem: Library
18:40:39 WebServer: serving .xml: /library/sections
18:40:39 ATVSettings: add section C1MHFTA6DRHN
18:40:39 PlexGDM: ***
18:40:39 PlexGDM: looking up Plex Media Server
18:40:40 PlexGDM: No servers discovered
18:40:40 XMLConverter: PlexGDM - no PMS found
18:40:45 ATVLogger: loadItem: Channels
18:40:45 WebServer: serving .xml: /channels/all
18:40:45 PlexGDM: ***
18:40:45 PlexGDM: looking up Plex Media Server
18:40:46 PlexGDM: No servers discovered
18:40:46 XMLConverter: PlexGDM - no PMS found
18:40:46 ATVLogger: loadItem: Search
18:40:46 WebServer: serving C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\search.xml
18:40:46 ATVLogger: loadItem: Settings
18:40:46 WebServer: serving .xml: /
18:40:46 WebServer: serving  C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\js\utils.js
18:40:46 WebServer: serving  C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\js\settings.js
18:40:47 WebServer: serving *.jpg: /thumbnails/PlexConnectLogo.jpg
18:40:48 WebServer: serving .xml: /
18:40:48 ATVLogger: loadURL (override): http://atv.plexconnect/&PlexConnect=SettingsMovies
18:40:48 WebServer: serving  C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\js\settings.js
18:40:57 ATVLogger: loadItem: Search
18:40:57 WebServer: serving C:\Users\Mark\Downloads\PlexConnect-master\PlexConnect-master\assets\search.xml
18:40:58 ATVLogger: loadItem: Channels
18:40:58 WebServer: serving .xml: /channels/all
18:40:58 PlexGDM: ***
18:40:58 PlexGDM: looking up Plex Media Server
18:40:59 PlexGDM: No servers discovered
18:40:59 XMLConverter: PlexGDM - no PMS found
18:41:00 ATVLogger: loadItem: Library
18:41:00 WebServer: serving .xml: /library/sections
18:41:00 PlexGDM: ***
18:41:00 PlexGDM: looking up Plex Media Server
18:41:01 PlexGDM: No servers discovered
18:41:01 XMLConverter: PlexGDM - no PMS found
18:42:35 DNSServer: DNS request received!
18:42:35 DNSServer: Source: ('192.168.0.103', 56698)
18:42:35 DNSServer: Domain: ax.init.itunes.apple.com
18:42:35 DNSServer: ***forward request
18:42:35 DNSServer: -> DNS response from higher level
18:42:35 DNSServer: Source: ('192.168.0.103', 49247)
18:42:35 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
18:42:35 DNSServer: Source: ('192.168.0.103', 56782)
18:42:35 DNSServer: Domain: a771.da1.akamai.net
18:42:35 DNSServer: Source: ('192.168.0.103', 64519)
18:42:35 DNSServer: Domain: p11-buy.itunes.apple.com
18:42:35 DNSServer: Source: ('192.168.0.103', 57106)
18:42:36 DNSServer: DNS request received!
18:42:36 DNSServer: Source: ('192.168.0.103', 57927)
18:42:36 DNSServer: Domain: p11-buy.itunes.apple.com.akadns.net
18:42:36 DNSServer: ***forward request
18:42:36 DNSServer: -> DNS response from higher level
18:42:39 DNSServer: DNS request received!
18:42:39 DNSServer: Source: ('192.168.0.103', 65214)
18:42:39 DNSServer: Domain: itunes.apple.com
18:42:39 DNSServer: ***forward request
18:42:39 DNSServer: -> DNS response from higher level
18:42:39 DNSServer: Source: ('192.168.0.103', 54641)
18:42:39 DNSServer: Source: ('192.168.0.103', 58078)
18:42:39 DNSServer: Domain: se.itunes.apple.com
18:42:39 DNSServer: Source: ('192.168.0.103', 49179)
18:42:39 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
18:42:39 DNSServer: Source: ('192.168.0.103', 51673)
18:42:39 DNSServer: Domain: e673.g.akamaiedge.net
18:42:39 DNSServer: Source: ('192.168.0.103', 60621)
18:42:39 DNSServer: Domain: e673.b.akamaiedge.net
In the log you can see that PlexGDM is not able to find your Plex Media Server.  Can you post details of the PMS version , IP address etc.
ALso if you edit the Settings.cfg file you can add the PMS's IP address in the ip_pms = section
I am currently having a similar issue. I have my settings.conf set as followed:
[PlexConnect]
enable_plexgdm = False
ip_pms = 192.168.2.44
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = False
ip_plexconnect = 192.168.2.44
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
allow_gzip_atv = False
allow_gzip_pmslocal = False
allow_gzip_pmsremote = True
loglevel = Normal
logpath = .
It has been worked perfect before. I now get intermittent outages and constantly receive the errors
" DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host " which I did not get before.
I use PIA for VPN and the only other thing I tried is changing my ip_dnsmaster line to match PIA’s DNS serve IPs. This did not make a difference. I know this thread is old but I am hoping I can still get some help. I am on plexconnect version .5
