I know you probably understand the problem but I figured I would include my logs with and without the firewall. Note the only changes I am doing are toggling off the firewall. These conditions are the same ATV, nothing else is tasking my server. Only difference is that firewall. Which I have added and I even have the ATV’s IP addresses added in the rules.
That is all of the plexconnect related apps I have completely opened on the firewall to troubleshoot to try to get it to work and still not resolution.
With AVAST Firewall on:
Jan 05,2019 15:00:32 PlexConnect: Started
Jan 05,2019 15:00:32 PlexConnect: Version: 0.5-dev-161017
Jan 05,2019 15:00:32 PlexConnect: Python: 2.7.13 (v2.7.13:a06454b1afa1, Dec 17 2016, 20:53:40) [MSC v.1500 64 bit (AMD64)]
Jan 05,2019 15:00:32 PlexConnect: Host OS: win32
Jan 05,2019 15:00:32 PlexConnect: PILBackgrounds: Is PIL installed? False
Jan 05,2019 15:00:32 Settings: getsetting enable_plexconnect_autodetect=False
Jan 05,2019 15:00:32 Settings: getsetting ip_plexconnect=192.168.1.77
Jan 05,2019 15:00:32 PlexConnect: IP_self (from settings): 192.168.1.77
Jan 05,2019 15:00:32 Settings: getsetting hosttointercept=trailers.apple.com
Jan 05,2019 15:00:32 Settings: getsetting enable_dnsserver=True
Jan 05,2019 15:00:32 DNSServer: Started
Jan 05,2019 15:00:32 Settings: getsetting port_dnsserver=53
Jan 05,2019 15:00:32 Settings: getsetting ip_dnsmaster=209.222.18.222
Jan 05,2019 15:00:32 Settings: getsetting prevent_atv_update=True
Jan 05,2019 15:00:32 DNSServer: ***
Jan 05,2019 15:00:32 DNSServer: DNSServer: Serving DNS on 192.168.1.77 port 53.
Jan 05,2019 15:00:32 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.1.77
Jan 05,2019 15:00:32 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
Jan 05,2019 15:00:32 DNSServer: forward other to higher level DNS: 209.222.18.222
Jan 05,2019 15:00:32 Settings: getsetting enable_webserver_ssl=True
Jan 05,2019 15:00:32 WebServer: Started
Jan 05,2019 15:00:32 Settings: getsetting port_webserver=80
Jan 05,2019 15:00:32 WebServer: ***
Jan 05,2019 15:00:32 WebServer: WebServer: Serving HTTP on 192.168.1.77 port 80.
Jan 05,2019 15:00:32 Settings: getsetting port_ssl=443
Jan 05,2019 15:00:32 Settings: getsetting certfile=./assets/certificates/trailers.pem
Jan 05,2019 15:00:33 WebServer: ***
Jan 05,2019 15:00:33 WebServer: WebServer: Serving HTTPS on 192.168.1.77 port 443.
Jan 05,2019 15:00:35 DNSServer: DNS request received!
Jan 05,2019 15:00:35 DNSServer: Source: (‘192.168.1.82’, 50107)
Jan 05,2019 15:00:35 DNSServer: Domain: e673.dsce9.akamaiedge.net
Jan 05,2019 15:00:35 DNSServer: ***forward request
Jan 05,2019 15:00:35 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:35 DNSServer: Source: (‘192.168.1.82’, 58220)
Jan 05,2019 15:00:36 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:36 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:00:39 DNSServer: DNS request received!
Jan 05,2019 15:00:39 DNSServer: Source: (‘192.168.1.82’, 57395)
Jan 05,2019 15:00:39 DNSServer: Domain: s.mzstatic.com
Jan 05,2019 15:00:39 DNSServer: ***forward request
Jan 05,2019 15:00:39 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:39 DNSServer: Source: (‘192.168.1.82’, 63170)
Jan 05,2019 15:00:39 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:00:45 DNSServer: DNS request received!
Jan 05,2019 15:00:45 DNSServer: Source: (‘192.168.1.82’, 55207)
Jan 05,2019 15:00:45 DNSServer: Domain: p46-buy.itunes-apple.com.akadns.net
Jan 05,2019 15:00:45 DNSServer: ***forward request
Jan 05,2019 15:00:45 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:45 DNSServer: Source: (‘192.168.1.82’, 52319)
Jan 05,2019 15:00:46 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:48 DNSServer: DNS request received!
Jan 05,2019 15:00:48 DNSServer: Source: (‘192.168.1.82’, 50137)
Jan 05,2019 15:00:48 DNSServer: Domain: kraken.nbcuni.com
Jan 05,2019 15:00:48 DNSServer: ***forward request
Jan 05,2019 15:00:49 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:49 DNSServer: DNS request received!
Jan 05,2019 15:00:49 DNSServer: Source: (‘192.168.1.82’, 54684)
Jan 05,2019 15:00:49 DNSServer: Domain: kraken.nbcuni.com
Jan 05,2019 15:00:49 DNSServer: ***forward request
Jan 05,2019 15:00:49 DNSServer: Source: (‘192.168.1.82’, 53719)
Jan 05,2019 15:00:49 DNSServer: Domain: e776.b.akamaiedge.net
Jan 05,2019 15:00:49 DNSServer: Source: (‘192.168.1.82’, 58107)
Jan 05,2019 15:00:49 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:00:50 DNSServer: DNS request received!
Jan 05,2019 15:00:50 DNSServer: Source: (‘192.168.1.82’, 54325)
Jan 05,2019 15:00:50 DNSServer: Domain: api.nbcuni.com
Jan 05,2019 15:00:50 DNSServer: ***forward request
Jan 05,2019 15:00:50 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:50 DNSServer: Source: (‘192.168.1.82’, 57449)
Jan 05,2019 15:00:50 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:00:50 DNSServer: Source: (‘192.168.1.82’, 62607)
Jan 05,2019 15:00:50 DNSServer: Domain: api.auth.adobe.com
Jan 05,2019 15:00:50 DNSServer: Source: (‘192.168.1.82’, 50037)
Jan 05,2019 15:00:50 DNSServer: Source: (‘192.168.1.82’, 54189)
Jan 05,2019 15:00:50 DNSServer: Domain: api-gateway-ap-prod2-ue1.adobe.io
Jan 05,2019 15:00:51 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:51 DNSServer: DNS request received!
Jan 05,2019 15:00:51 DNSServer: Source: (‘192.168.1.82’, 61649)
Jan 05,2019 15:00:51 DNSServer: Domain: api-gateway-ap-prod2-ue1.adobe.io
Jan 05,2019 15:00:51 DNSServer: ***forward request
Jan 05,2019 15:00:51 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:00:52 DNSServer: DNS request received!
Jan 05,2019 15:00:52 DNSServer: Source: (‘192.168.1.82’, 65264)
Jan 05,2019 15:00:52 DNSServer: Domain: nbcume.sc.omtrdc.net
Jan 05,2019 15:00:52 DNSServer: ***forward request
Jan 05,2019 15:00:53 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:53 DNSServer: DNS request received!
Jan 05,2019 15:00:53 DNSServer: Source: (‘192.168.1.82’, 57805)
Jan 05,2019 15:00:53 DNSServer: Domain: nbcume.sc.omtrdc.net
Jan 05,2019 15:00:53 DNSServer: ***forward request
Jan 05,2019 15:00:54 DNSServer: DNS request received!
Jan 05,2019 15:00:54 DNSServer: Source: (‘192.168.1.82’, 60729)
Jan 05,2019 15:00:54 DNSServer: Domain: dbjr3wl54-images.nbcuni.com
Jan 05,2019 15:00:54 DNSServer: ***forward request
Jan 05,2019 15:00:54 DNSServer: -> DNS response from higher level
Jan 05,2019 15:00:54 DNSServer: Source: (‘192.168.1.82’, 60654)
Jan 05,2019 15:00:54 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:09 DNSServer: DNS request received!
Jan 05,2019 15:01:09 DNSServer: Source: (‘192.168.1.82’, 59022)
Jan 05,2019 15:01:09 DNSServer: Domain: is-ssl.mzstatic.com.itunes-apple.com.akadns.net
Jan 05,2019 15:01:09 DNSServer: ***forward request
Jan 05,2019 15:01:09 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:09 DNSServer: Source: (‘192.168.1.82’, 63619)
Jan 05,2019 15:01:09 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:22 DNSServer: DNS request received!
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 50195)
Jan 05,2019 15:01:22 DNSServer: Domain: init.itunes.apple.com
Jan 05,2019 15:01:22 DNSServer: ***forward request
Jan 05,2019 15:01:22 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 63015)
Jan 05,2019 15:01:22 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 50894)
Jan 05,2019 15:01:22 DNSServer: Domain: xp.itunes-apple.com.akadns.net
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 49603)
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 55881)
Jan 05,2019 15:01:22 DNSServer: Domain: mt-ingestion-service-ms.itunes-apple.com.akadns.net
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 53658)
Jan 05,2019 15:01:22 DNSServer: Source: (‘192.168.1.82’, 52493)
Jan 05,2019 15:01:22 DNSServer: Domain: play.itunes.apple.com
Jan 05,2019 15:01:23 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:23 DNSServer: DNS request received!
Jan 05,2019 15:01:23 DNSServer: Source: (‘192.168.1.82’, 55221)
Jan 05,2019 15:01:23 DNSServer: Domain: play.itunes.apple.com
Jan 05,2019 15:01:23 DNSServer: ***forward request
Jan 05,2019 15:01:23 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:24 DNSServer: DNS request received!
Jan 05,2019 15:01:24 DNSServer: Source: (‘192.168.1.82’, 50355)
Jan 05,2019 15:01:24 DNSServer: Domain: pd.itunes.apple.com
Jan 05,2019 15:01:24 DNSServer: ***forward request
Jan 05,2019 15:01:24 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:24 DNSServer: Source: (‘192.168.1.82’, 62762)
Jan 05,2019 15:01:24 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:24 DNSServer: Source: (‘192.168.1.84’, 62767)
Jan 05,2019 15:01:25 DNSServer: DNS request received!
Jan 05,2019 15:01:25 DNSServer: Source: (‘192.168.1.82’, 56373)
Jan 05,2019 15:01:25 DNSServer: Domain: video.itunes.apple.com
Jan 05,2019 15:01:25 DNSServer: ***forward request
Jan 05,2019 15:01:25 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:25 DNSServer: Source: (‘192.168.1.82’, 63758)
Jan 05,2019 15:01:25 DNSServer: Source: (‘192.168.1.82’, 54110)
Jan 05,2019 15:01:25 DNSServer: Domain: video.itunes.g.aaplimg.com
Jan 05,2019 15:01:25 DNSServer: Source: (‘192.168.1.82’, 52109)
Jan 05,2019 15:01:25 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:25 DNSServer: Source: (‘192.168.1.82’, 60021)
Jan 05,2019 15:01:25 DNSServer: Domain: s-mzstatic-applak.itunes-apple.com.akadns.net
Jan 05,2019 15:01:26 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:26 DNSServer: DNS request received!
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 58568)
Jan 05,2019 15:01:26 DNSServer: Domain: s-mzstatic-applak.itunes-apple.com.akadns.net
Jan 05,2019 15:01:26 DNSServer: ***forward request
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 57676)
Jan 05,2019 15:01:26 DNSServer: Domain: configuration.apple.com.akadns.net
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 56793)
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 62225)
Jan 05,2019 15:01:26 DNSServer: Domain: a1978.hsar.video.itunes.apple.com-a.akamaihd.net
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 52621)
Jan 05,2019 15:01:26 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 57558)
Jan 05,2019 15:01:26 DNSServer: Domain: a722.w11.akamai.net
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 57939)
Jan 05,2019 15:01:26 DNSServer: Domain: a1978.w73.akamai.net
Jan 05,2019 15:01:26 DNSServer: Source: (‘192.168.1.82’, 49320)
Jan 05,2019 15:01:27 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:27 DNSServer: DNS request received!
Jan 05,2019 15:01:27 DNSServer: Source: (‘192.168.1.82’, 65456)
Jan 05,2019 15:01:27 DNSServer: Domain: e673.dsce9.akamaiedge.net
Jan 05,2019 15:01:27 DNSServer: ***forward request
Jan 05,2019 15:01:27 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:27 DNSServer: Source: (‘192.168.1.84’, 65429)
Jan 05,2019 15:01:27 DNSServer: Domain: hls.itunes.apple.com
Jan 05,2019 15:01:27 DNSServer: Source: (‘192.168.1.84’, 65227)
Jan 05,2019 15:01:27 DNSServer: Source: (‘192.168.1.84’, 52343)
Jan 05,2019 15:01:27 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:01:28 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:28 DNSServer: DNS request received!
Jan 05,2019 15:01:28 DNSServer: Source: (‘192.168.1.84’, 51620)
Jan 05,2019 15:01:28 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:01:28 DNSServer: ***forward request
Jan 05,2019 15:01:28 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:28 DNSServer: Source: (‘192.168.1.82’, 53733)
Jan 05,2019 15:01:28 DNSServer: Domain: pancake.apple.com
Jan 05,2019 15:01:28 DNSServer: Source: (‘192.168.1.82’, 61697)
Jan 05,2019 15:01:28 DNSServer: Source: (‘192.168.1.82’, 62869)
Jan 05,2019 15:01:28 DNSServer: Domain: pancake.g.aaplimg.com
Jan 05,2019 15:01:29 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:29 DNSServer: DNS request received!
Jan 05,2019 15:01:29 DNSServer: Source: (‘192.168.1.82’, 63081)
Jan 05,2019 15:01:29 DNSServer: Domain: pancake.g.aaplimg.com
Jan 05,2019 15:01:29 DNSServer: ***forward request
Jan 05,2019 15:01:29 DNSServer: Warning: DNS error (10054): An existing connection was forcibly closed by the remote host
Jan 05,2019 15:01:29 DNSServer: Source: (‘192.168.1.82’, 52962)
Jan 05,2019 15:01:29 DNSServer: Domain: hls.itunes.apple.com
Jan 05,2019 15:01:29 DNSServer: Source: (‘192.168.1.82’, 63689)
Jan 05,2019 15:01:29 DNSServer: Source: (‘192.168.1.82’, 59229)
Jan 05,2019 15:01:29 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:01:29 DNSServer: Source: (‘192.168.1.82’, 49615)
Jan 05,2019 15:01:32 PlexConnect: Shutting down.
Jan 05,2019 15:01:32 WebServer: Shutting down (HTTP).
Jan 05,2019 15:01:33 WebServer: Shutting down (HTTPS).
Jan 05,2019 15:01:36 DNSServer: DNS request received!
Jan 05,2019 15:01:36 DNSServer: Source: (‘192.168.1.80’, 53793)
Jan 05,2019 15:01:36 DNSServer: Domain: api-global.netflix.com
Jan 05,2019 15:01:36 DNSServer: ***forward request
Jan 05,2019 15:01:36 DNSServer: -> DNS response from higher level
Jan 05,2019 15:01:36 DNSServer: Shutting down.
Jan 05,2019 15:01:36 PlexConnect: Shutdown
With AVAST Firewall OFF:
Jan 05,2019 15:07:09 PlexConnect: Started
Jan 05,2019 15:07:09 PlexConnect: Version: 0.5-dev-161017
Jan 05,2019 15:07:09 PlexConnect: Python: 2.7.13 (v2.7.13:a06454b1afa1, Dec 17 2016, 20:53:40) [MSC v.1500 64 bit (AMD64)]
Jan 05,2019 15:07:09 PlexConnect: Host OS: win32
Jan 05,2019 15:07:09 PlexConnect: PILBackgrounds: Is PIL installed? False
Jan 05,2019 15:07:09 Settings: getsetting enable_plexconnect_autodetect=False
Jan 05,2019 15:07:09 Settings: getsetting ip_plexconnect=192.168.1.77
Jan 05,2019 15:07:09 PlexConnect: IP_self (from settings): 192.168.1.77
Jan 05,2019 15:07:09 Settings: getsetting hosttointercept=trailers.apple.com
Jan 05,2019 15:07:09 Settings: getsetting enable_dnsserver=True
Jan 05,2019 15:07:09 Settings: getsetting enable_webserver_ssl=True
Jan 05,2019 15:07:09 DNSServer: Started
Jan 05,2019 15:07:09 Settings: getsetting port_dnsserver=53
Jan 05,2019 15:07:09 Settings: getsetting ip_dnsmaster=209.222.18.222
Jan 05,2019 15:07:09 Settings: getsetting prevent_atv_update=True
Jan 05,2019 15:07:09 DNSServer: ***
Jan 05,2019 15:07:09 DNSServer: DNSServer: Serving DNS on 192.168.1.77 port 53.
Jan 05,2019 15:07:09 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.1.77
Jan 05,2019 15:07:09 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
Jan 05,2019 15:07:09 DNSServer: forward other to higher level DNS: 209.222.18.222
Jan 05,2019 15:07:09 WebServer: Started
Jan 05,2019 15:07:09 Settings: getsetting port_webserver=80
Jan 05,2019 15:07:09 WebServer: ***
Jan 05,2019 15:07:09 WebServer: WebServer: Serving HTTP on 192.168.1.77 port 80.
Jan 05,2019 15:07:09 Settings: getsetting port_ssl=443
Jan 05,2019 15:07:09 Settings: getsetting certfile=./assets/certificates/trailers.pem
Jan 05,2019 15:07:10 WebServer: ***
Jan 05,2019 15:07:10 WebServer: WebServer: Serving HTTPS on 192.168.1.77 port 443.
Jan 05,2019 15:07:16 DNSServer: DNS request received!
Jan 05,2019 15:07:16 DNSServer: Source: (‘192.168.1.82’, 64947)
Jan 05,2019 15:07:16 DNSServer: Domain: e673.dsce9.akamaiedge.net
Jan 05,2019 15:07:16 DNSServer: ***forward request
Jan 05,2019 15:07:16 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:16 DNSServer: Source: (‘192.168.1.82’, 60827)
Jan 05,2019 15:07:16 DNSServer: Source: (‘192.168.1.82’, 50255)
Jan 05,2019 15:07:16 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:07:16 DNSServer: Source: (‘192.168.1.82’, 50618)
Jan 05,2019 15:07:21 DNSServer: DNS request received!
Jan 05,2019 15:07:21 DNSServer: Source: (‘192.168.1.82’, 60877)
Jan 05,2019 15:07:21 DNSServer: Domain: is-ssl.mzstatic.com.itunes-apple.com.akadns.net
Jan 05,2019 15:07:21 DNSServer: ***forward request
Jan 05,2019 15:07:21 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:21 DNSServer: Source: (‘192.168.1.82’, 55201)
Jan 05,2019 15:07:25 DNSServer: DNS request received!
Jan 05,2019 15:07:25 DNSServer: Source: (‘192.168.1.82’, 64399)
Jan 05,2019 15:07:25 DNSServer: Domain: xp.apple.com
Jan 05,2019 15:07:25 DNSServer: ***forward request
Jan 05,2019 15:07:25 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:25 DNSServer: Source: (‘192.168.1.82’, 60859)
Jan 05,2019 15:07:25 DNSServer: Source: (‘192.168.1.82’, 59528)
Jan 05,2019 15:07:25 DNSServer: Domain: mt-ingestion-service-pv.itunes-apple.com.akadns.net
Jan 05,2019 15:07:25 DNSServer: Source: (‘192.168.1.82’, 55748)
Jan 05,2019 15:07:28 DNSServer: DNS request received!
Jan 05,2019 15:07:28 DNSServer: Source: (‘192.168.1.82’, 60978)
Jan 05,2019 15:07:28 DNSServer: Domain: e673.dsce9.akamaiedge.net
Jan 05,2019 15:07:28 DNSServer: ***forward request
Jan 05,2019 15:07:28 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:28 DNSServer: Source: (‘192.168.1.82’, 54124)
Jan 05,2019 15:07:30 DNSServer: DNS request received!
Jan 05,2019 15:07:30 DNSServer: Source: (‘192.168.1.82’, 55739)
Jan 05,2019 15:07:30 DNSServer: Domain: configuration.apple.com.akadns.net
Jan 05,2019 15:07:30 DNSServer: ***forward request
Jan 05,2019 15:07:30 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:30 DNSServer: Source: (‘192.168.1.82’, 58847)
Jan 05,2019 15:07:33 DNSServer: DNS request received!
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 65503)
Jan 05,2019 15:07:33 DNSServer: Domain: pancake.cdn-apple.com.akadns.net
Jan 05,2019 15:07:33 DNSServer: ***forward request
Jan 05,2019 15:07:33 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 60715)
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 63462)
Jan 05,2019 15:07:33 DNSServer: Domain: pancake.g.aaplimg.com
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 63113)
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 57121)
Jan 05,2019 15:07:33 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:07:33 DNSServer: Source: (‘192.168.1.82’, 59719)
Jan 05,2019 15:07:40 DNSServer: DNS request received!
Jan 05,2019 15:07:40 DNSServer: Source: (‘192.168.1.82’, 56141)
Jan 05,2019 15:07:40 DNSServer: Domain: e673.dsce9.akamaiedge.net
Jan 05,2019 15:07:40 DNSServer: ***forward request
Jan 05,2019 15:07:40 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:40 DNSServer: Source: (‘192.168.1.82’, 51611)
Jan 05,2019 15:07:44 DNSServer: DNS request received!
Jan 05,2019 15:07:44 DNSServer: Source: (‘192.168.1.82’, 63886)
Jan 05,2019 15:07:44 DNSServer: Domain: se-edge.itunes-apple.com.akadns.net
Jan 05,2019 15:07:44 DNSServer: ***forward request
Jan 05,2019 15:07:45 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:45 DNSServer: DNS request received!
Jan 05,2019 15:07:45 DNSServer: Source: (‘192.168.1.82’, 62823)
Jan 05,2019 15:07:45 DNSServer: Domain: se-edge.itunes-apple.com.akadns.net
Jan 05,2019 15:07:45 DNSServer: ***forward request
Jan 05,2019 15:07:45 DNSServer: Source: (‘192.168.1.82’, 61965)
Jan 05,2019 15:07:45 DNSServer: Domain: my.itunes-apple.com.akadns.net
Jan 05,2019 15:07:45 DNSServer: Source: (‘192.168.1.82’, 57425)
Jan 05,2019 15:07:46 DNSServer: DNS request received!
Jan 05,2019 15:07:46 DNSServer: Source: (‘192.168.1.82’, 59761)
Jan 05,2019 15:07:46 DNSServer: Domain: s-mzstatic-applak.itunes-apple.com.akadns.net
Jan 05,2019 15:07:46 DNSServer: ***forward request
Jan 05,2019 15:07:47 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:47 DNSServer: DNS request received!
Jan 05,2019 15:07:47 DNSServer: Source: (‘192.168.1.82’, 57034)
Jan 05,2019 15:07:47 DNSServer: Domain: s-mzstatic-applak.itunes-apple.com.akadns.net
Jan 05,2019 15:07:47 DNSServer: ***forward request
Jan 05,2019 15:07:49 DNSServer: DNS request received!
Jan 05,2019 15:07:49 DNSServer: Source: (‘192.168.1.82’, 57975)
Jan 05,2019 15:07:49 DNSServer: Domain: hls.itunes.g.aaplimg.com
Jan 05,2019 15:07:49 DNSServer: ***forward request
Jan 05,2019 15:07:49 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:49 DNSServer: Source: (‘192.168.1.82’, 56333)
Jan 05,2019 15:07:50 DNSServer: DNS request received!
Jan 05,2019 15:07:50 DNSServer: Source: (‘192.168.1.82’, 53584)
Jan 05,2019 15:07:50 DNSServer: Domain: p46-buy.itunes-apple.com.akadns.net
Jan 05,2019 15:07:50 DNSServer: ***forward request
Jan 05,2019 15:07:51 DNSServer: -> DNS response from higher level
Jan 05,2019 15:07:51 DNSServer: DNS request received!
Jan 05,2019 15:07:51 DNSServer: Source: (‘192.168.1.82’, 54393)
Jan 05,2019 15:07:51 DNSServer: Domain: p46-buy.itunes-apple.com.akadns.net
Jan 05,2019 15:07:51 DNSServer: ***forward request
Jan 05,2019 15:07:57 PlexConnect: Shutting down.
Jan 05,2019 15:07:57 WebServer: Shutting down (HTTP).
Jan 05,2019 15:07:58 WebServer: Shutting down (HTTPS).
Jan 05,2019 15:08:01 DNSServer: Shutting down.
Jan 05,2019 15:08:01 PlexConnect: Shutdown
