hello, im getting this message very time i enter trailers
ATV 3rd generation 7.2.1 (8011)
iMac 10.12 Sierra (recently updated)
and thats the log im getting
04:49:23 PlexConnect: ***
04:49:23 PlexConnect: PlexConnect
04:49:23 PlexConnect: Press CTRL-C to shut down.
04:49:23 PlexConnect: started: 04:49:23
04:49:23 PlexConnect: Version: 0.5-dev-110616
04:49:23 PlexConnect: Python: 2.7.8 (v2.7.8:ee879c0ffa11, Jun 29 2014, 21:07:35)
[GCC 4.2.1 (Apple Inc. build 5666) (dot 3)]
04:49:23 PlexConnect: Host OS: darwin
04:49:23 PlexConnect: PILBackgrounds: Is PIL installed? False
04:49:23 PlexConnect: IP_self: 192.168.1.7
04:49:23 DNSServer: started: 04:49:23
04:49:23 DNSServer: ***
04:49:23 DNSServer: DNSServer: Serving DNS on 192.168.1.7 port 53.
04:49:23 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.1.7
04:49:23 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
04:49:23 DNSServer: forward other to higher level DNS: 8.8.8.8
04:49:23 WebServer: started: 04:49:23
04:49:23 WebServer: ***
04:49:23 WebServer: WebServer: Serving HTTP on 192.168.1.7 port 80.
04:49:23 WebServer: WebServer: Serving HTTPS on 192.168.1.7 port 443.
04:49:34 DNSServer: DNS request received!
04:49:34 DNSServer: Source: (‘192.168.1.2’, 64566)
04:49:34 DNSServer: Domain: trailers.apple.com
04:49:34 DNSServer: ***intercept request
04:49:34 DNSServer: -> DNS response: 192.168.1.7
04:49:34 DNSServer: Source: (‘192.168.1.2’, 57188)
04:49:34 WebServer: serving /js/application.js
04:49:34 WebServer: serving .xml: /
04:49:34 PlexAPI: ***
04:49:34 PlexAPI: PlexGDM - looking up Plex Media Server
04:49:35 PlexAPI: GDM: Servers discovered: 1
04:49:35 PlexAPI: Servers (local, plex.tv, MyPlex): 2
04:49:35 WebServer: serving .xml: /PlexConnect.xml
04:49:35 WebServer: serving /js/utils.js
04:49:35 WebServer: serving /js/handlePlexConnectNavbar.js
04:49:35 WebServer: serving .xml: /library/sections
04:49:35 PlexAPI: No Response from Plex Media Server
04:49:35 PlexAPI: We failed to reach a server. Reason: Unauthorized
04:49:35 PlexAPI: Traceback:
Traceback (most recent call last):
File “/Applications/PlexConnect-master/PlexAPI.py”, line 432, in getXMLFromPMS
response = urllib2.urlopen(request, timeout=20)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 127, in urlopen
return _opener.open(url, data, timeout)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 410, in open
response = meth(req, response)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 523, in http_response
‘http’, request, response, code, msg, hdrs)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 448, in error
return self._call_chain(*args)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 382, in _call_chain
result = func(*args)
File “/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py”, line 531, in http_error_default
raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 401: Unauthorized
04:49:36 WebServer: serving /js/sectionHoldSelect.js
04:52:34 DNSServer: DNS request received!
04:52:34 DNSServer: Source: (‘192.168.1.2’, 61444)
04:52:34 DNSServer: Domain: mesu.apple.com
04:52:34 DNSServer: ***restrain request
04:52:34 DNSServer: -> DNS response: 192.168.1.7
04:52:34 DNSServer: Source: (‘192.168.1.2’, 51292)
04:52:34 DNSServer: Source: (‘192.168.1.2’, 50931)
04:52:34 DNSServer: Domain: setup.icloud.com
04:52:34 DNSServer: ***forward request
04:52:35 DNSServer: -> DNS response from higher level
04:52:35 DNSServer: DNS request received!
04:52:35 DNSServer: Source: (‘192.168.1.2’, 52094)
04:52:35 DNSServer: Domain: setup.icloud.com
04:52:35 DNSServer: ***forward request
04:52:35 DNSServer: Source: (‘192.168.1.2’, 50712)
04:52:35 DNSServer: Domain: st11-setup.icloud.com.akadns.net
04:52:35 DNSServer: Source: (‘192.168.1.2’, 58482)
Any ideas on how to solve this?
