Hi guys
I just upgraded to Plexconnect 0.3.1 and it stooped working. Whenever I try to open trailers i get an "Trailers are no currently available" message.
My ATV is version 3, with the latest updates.
Here's my Plesxconnect.log
12:56:35 PlexConnect: started: 12:56:35
12:56:35 PlexConnect: Version: 0.3.1
12:56:35 PlexConnect: Python: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
12:56:35 PlexConnect: Host OS: win32
12:56:35 PlexConnect: IP_self: 192.168.25.5
12:56:35 DNSServer: started: 12:56:35
12:56:35 DNSServer: ***
12:56:35 DNSServer: DNSServer: Serving DNS on 192.168.25.5 port 53.
12:56:35 WebServer: started: 12:56:35
12:56:35 WebServer: ***
12:56:35 WebServer: WebServer: Serving HTTP on 192.168.25.5 port 80.
12:56:36 WebServer: started: 12:56:36
12:56:36 WebServer: ***
12:56:36 WebServer: WebServer: Serving HTTPS on 192.168.25.5 port 443.
Strangely this is my Plexconnect window (shouldn't this be in the log too?)
14:12:44 PlexConnect: ***
14:12:44 PlexConnect: PlexConnect
14:12:44 PlexConnect: Press CTRL-C to shut down.
14:12:44 PlexConnect: started: 14:12:44
14:12:44 PlexConnect: Version: 0.3.1
14:12:44 PlexConnect: Python: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500
64 bit (AMD64)]
14:12:44 PlexConnect: Host OS: win32
14:12:44 PlexConnect: IP_self: 192.168.25.5
14:12:44 DNSServer: started: 14:12:44
14:12:44 DNSServer: ***
14:12:44 DNSServer: DNSServer: Serving DNS on 192.168.25.5 port 53.
14:12:44 DNSServer: intercept: ['trailers.apple.com'] => 192.168.25.5
14:12:44 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
14:12:44 DNSServer: forward other to higher level DNS: 8.8.8.8
14:12:44 WebServer: started: 14:12:44
14:12:44 WebServer: ***
14:12:44 WebServer: WebServer: Serving HTTP on 192.168.25.5 port 80.
14:12:44 WebServer: WebServer: Serving HTTPS on 192.168.25.5 port 443.
14:13:44 DNSServer: DNS request received!
14:13:44 DNSServer: Source: ('192.168.25.7', 64423)
14:13:44 DNSServer: Domain: trailers.apple.com
14:13:44 DNSServer: ***intercept request
14:13:44 DNSServer: -> DNS response: 192.168.25.5
Am I missing something here?
baa
February 19, 2014, 5:26pm
2
Time is different as well...
Are you sure, you are running PlexConnect from the directory you are looking for the log?
Yes! It even updates the log when I run it
baa
February 19, 2014, 6:02pm
4
You can control the content of your log with the settings file - "loglevel". Set it to "High", you will see everything from the terminal, and then some...
Now yeah
16:55:12 PlexConnect: started: 16:55:12
16:55:12 PlexConnect: Version: 0.3.1
16:55:12 PlexConnect: Python: 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
16:55:12 PlexConnect: Host OS: win32
16:55:12 Settings: getsetting enable_plexconnect_autodetect=True
16:55:12 PlexConnect: IP_self: 192.168.25.5
16:55:12 Settings: getsetting port_webserver=80
16:55:12 Settings: getsetting hosttointercept=trailers.apple.com
16:55:12 Settings: getsetting enable_dnsserver=True
16:55:12 DNSServer: started: 16:55:12
16:55:12 Settings: getsetting port_dnsserver=53
16:55:12 Settings: getsetting ip_dnsmaster=8.8.8.8
16:55:12 Settings: getsetting prevent_atv_update=True
16:55:12 DNSServer: ***
16:55:12 DNSServer: DNSServer: Serving DNS on 192.168.25.5 port 53.
16:55:12 DNSServer: intercept: ['trailers.apple.com'] => 192.168.25.5
16:55:12 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
16:55:12 DNSServer: forward other to higher level DNS: 8.8.8.8
16:55:12 WebServer: started: 16:55:12
16:55:12 Settings: getsetting enable_webserver_ssl=True
16:55:12 WebServer: ***
16:55:12 WebServer: WebServer: Serving HTTP on 192.168.25.5 port 80.
16:55:12 ATVSettings: init class CATVSettings
16:55:12 ATVSettings: load settings
16:55:12 Settings: getsetting port_ssl=443
16:55:12 Settings: getsetting certfile=./assets/certificates/trailers.pem
16:55:12 WebServer: WebServer: Serving HTTPS on 192.168.25.5 port 443.
16:57:32 DNSServer: DNS request received!
16:57:32 DNSServer: Source: ('192.168.25.7', 51642)
16:57:32 DNSServer: Domain: trailers.apple.com
16:57:32 DNSServer: ***intercept request
16:57:32 DNSServer: -> DNS response: 192.168.25.5
16:59:39 DNSServer: DNS request received!
16:59:39 DNSServer: Source: ('192.168.25.7', 63550)
16:59:39 DNSServer: Domain: init.itunes.apple.com
16:59:39 DNSServer: ***forward request
16:59:39 DNSServer: -> DNS response from higher level
16:59:40 DNSServer: DNS request received!
16:59:40 DNSServer: Source: ('192.168.25.7', 63673)
16:59:40 DNSServer: Domain: EVIntl-ocsp.verisign.com
16:59:40 DNSServer: ***forward request
16:59:40 DNSServer: -> DNS response from higher level
16:59:40 DNSServer: Source: ('192.168.25.7', 61802)
16:59:40 DNSServer: Domain: EVSecure-ocsp.verisign.com
16:59:41 DNSServer: DNS request received!
16:59:41 DNSServer: Source: ('192.168.25.7', 64480)
16:59:41 DNSServer: Domain: configuration.apple.com
16:59:41 DNSServer: ***forward request
16:59:41 DNSServer: -> DNS response from higher level
16:59:41 DNSServer: Source: ('192.168.25.7', 56252)
16:59:41 DNSServer: Domain: itunes.apple.com
16:59:42 DNSServer: Source: ('192.168.25.7', 53848)
16:59:42 DNSServer: Domain: xp.apple.com
16:59:42 DNSServer: ***forward request
16:59:42 DNSServer: -> DNS response from higher level
16:59:42 DNSServer: DNS request received!
16:59:42 DNSServer: Source: ('192.168.25.7', 56926)
16:59:42 DNSServer: Domain: e673.e9.akamaiedge.net
17:03:43 DNSServer: DNS request received!
17:03:43 DNSServer: Source: ('192.168.25.7', 50490)
17:03:43 DNSServer: Domain: api-global.netflix.com
17:03:43 DNSServer: ***forward request
17:03:43 DNSServer: -> DNS response from higher level
I've notice it's using two ports. Is that normal?
baa
February 19, 2014, 8:16pm
6
Actually three - 53 (DNS), 80 (HTTP), 443 (HTTPS).
Yes, since Apple forced HTTPS/SSL on us, it is normal.
Edit: Log looks good so far - if you still get "trailers unavailable" my first guess would be issues with the certificate. :-)
Probably forgot to move cert file to assets folder
Should I follow this again? https://forums.plex.tv/topic/79540-windows-specific-instructions-for-creating-and-installing-the-ssl-cert/
I did it when I first installed Plexcconnect, but not when I updated it
You don't need to redo the certificate. The same ones can be used. If you updated by replacing the plexconnect folder then put the certs created before back into the assets folder. If you already have the trailers.pem in the assets folder then my guess was wrong and ignore what I said completely. Sorry for the confusion.
I was thinking this over. Best bet is to redo the certs and go from there. Just to be safe.
f00b4r
February 20, 2014, 10:42am
12
First try backing up the folder, downloading a fresh copy. Try using the fresh copy with default settings, only add back the certs from the old folder (nit anything else).
baa
February 20, 2014, 4:26pm
13
And delete (!) and reinstall the certs to your aTV. Seems to fix those hick-ups more often...
