PLexconnect not working after Yosemite upgrade
Yesterday I was glad and proud to install Plexconnect on my Mac Mini (has the Plex manager) without any issues and made the connection to my Apple TV3. Worked like a charm.
This morning I upgraded my Mac Mini to new version of Yosemite 10.10.3 and from that moment is says that the Trailers app, on the Apple TV, is no longer available.
There was an update for Plex Manager but this had no influence to Plexconnect/Apple TV.
Can somebody help me out please?
what does ur Plexconnect log say? Maybe try to uplaod new certs for mac mini and atv?
Well yeah I can do it all over again maybe, but was hoping on a easy solution. I just also saw that I have two folders on mu mac: Plexconnect en Plexconnect Master. I had only one yesterday.
The master folder is missing the update subfolder. Weird.
Maybe better to redo a new plexconnect installation, or maybe ur log can help to figure out ur issue… Are u using plexconnect over terminal or openplex app?
Yes I was thinking the same. I did the install via terminal and later installed the openplex app for the fanart option. Where can I find the log?
Ok i think i know what ur issue is… Use OpenPlex and do a fresh install of plexconnect! Then u should be good to go, just delete before all ur old plexconnect folders. The log u can find it by just pushing the log button on OpenPlex PlexConnect Remote. Let me know if u need help
Got it working again thanks to the openplex app.
And you of course. Thanks man.
No problem dont hesitate to ask if u need help :wink:
And now the fanart of yours!
Njoy :wink:
Hi again, is it in any way possible to ad subtitels when they are a separate file like .srt? I got several movies with .srt and they don;t show.
Thanks!
Rob.
Thanks!
Rob.
Sometimes this problem is caused by srt files not using utf-8 encoding. I use this plug-in https://forums.plex.tv/topic/94864-rel-str2utf-8/ to solve
Thanks. I will have a look.
