I installed PlexConnect Baa version. It won’t launch so I prefer to uninstall, but uninstall fails. How can I remove from my synology ds213j DSM 6.1’
thanks
The recommended way to install PlexConnect in Synology NAS is to follow these instructions https://forums.plex.tv/discussion/72356/plexconnect-on-synology/p1
I followed them. But I cannot launch it and also (what I wish) Uninstall. Because is slowing Synology Nas and cannot use Plex adding more folders
Solved thanks to ChuckPa:
You can manually remove it.
Stop PMS
Open Control Panel - Shared Folders.
Give your username permission to R/W in the Plex share
Open File Station
Navigate in the Plex share, through Library -> Plex Media Server -> Plug-ins
Manually delete the .bundle file
Start PMS
What I’ve seen in your threads is that you had difficulties removing Plex Media Server. PlexConnect is a different app, and certainly not a plug-in (I wish it was, this would bring platform independence), therefore it does not installs in the Plug-ins folder. You only need PlexConnect if you use ATV2 or ATV3 as your media player.
Synology should be able to use docker.
