Following the install guide, when I came to launching plexconnect.py, a dos window would open for a second and close. There was no firewall exception request, no log file was created, and no plexconnect.cfg.
After lots of re-tracing my steps, still no go, until I manually opened a cmd window, and opened plexconnect.py by browsing to the dir. Then it stayed open, I was able to finally install the profile, and everything worked. I tried shutting down the plexconnect server and launching by double clicking the .py file, but still no go.
But, I want to be able to launch plexconnect.py at startup, and I can’t since I have to open a cmd window
I suggest you provide all details asked for in the "Read Be3fore POsting" troubleshooting section so we know exactly your Operating system etc.
but if ytou are runnign windows 7 I would ask the following;
Do you have the path to Python set correctly in the syetm variables?
Have you tried starting it via a .bat file on startup (Thus it opens the command window first).
