PlexConnect.py not working
Hi guys
I have tried running plexconnect.py through Python and it just shuts down immediately. I then tried running it through a CMD running as administrator and this happens. I have checked the folder and all the permissions are set to admin read and write.
Any ideas?
I don't have experience with PlexConnect but generally you run Python programs like:
python PlexConnect.py
or if you don't have python.exe in the system enivronment:
/path/to/python.exe PlexConnect.py
tried both of those, and the original method of just plexconnct.py and these are the results.
Just to confirm:
I have fixed the ip address in my router
I have installed the certificates into the plex connect folder
When I first did this a while ago I got it all working great, but for some reason the default program for my .py files have changed from python to CMD prompt, and since then I can't run the scripts in CMD and I can't seem to change the default back to Python despite going through control panel, and reinstalling python
I removed everything and started from the beginning and it is working fine now
