das ist nicht ganz leicht zu beantworten, da der PMS ja recht viel loggt. Zudem habe ich nicht die genauen Zeitstempel, wann die Abbrüche auftraten. Wenn ich aber mal alle "DEBUG"-Ausgaben herausfiltere bleibt folgendes übrig (mal ein kurzer Ausschnitt):
Dec 19, 2013 20:57:00 [0x7f155d7fa700] INFO - [Transcoder] Input #0, matroska,webm, from 'http://127.0.0.1:32400/library/parts/6675/file.mkv':
Dec 19, 2013 20:57:00 [0x7f155bff7700] INFO - [Transcoder] Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 2k tbc (default)
Dec 19, 2013 20:57:00 [0x7f155c7f8700] INFO - [Transcoder] Stream #0:1(ger): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Dec 19, 2013 20:57:00 [0x7f155d7fa700] INFO - [Transcoder] Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s
Dec 19, 2013 20:57:00 [0x7f155c7f8700] INFO - [Transcoder] Output #0, segment, to 'media-%05d.ts':
Dec 19, 2013 20:57:00 [0x7f155d7fa700] INFO - [Transcoder] Stream #0:0: Video: h264, yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 90k tbn, 1k tbc (default)
Dec 19, 2013 20:57:00 [0x7f155bff7700] INFO - [Transcoder] Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp, 192 kb/s (default)
Dec 19, 2013 21:08:16 [0x7f155c7f8700] ERROR - [Transcoder] av_interleaved_write_frame(): No space left on device
Dec 19, 2013 21:09:35 [0x7f155bff7700] WARN - Transcode runner appears to have died.
Dec 19, 2013 21:09:35 [0x7f155bff7700] WARN - Timed out waiting for segment.
Dec 19, 2013 21:09:35 [0x7f15597f2700] WARN - Transcode runner appears to have died.
Dec 19, 2013 21:09:35 [0x7f15597f2700] WARN - Timed out waiting for segment.
Dec 19, 2013 21:09:35 [0x7f155c7f8700] WARN - Transcode runner appears to have died.
Dec 19, 2013 21:09:35 [0x7f155c7f8700] WARN - Timed out waiting for segment.
Die Zeile "ERROR - [Transcoder] av_interleaved_write_frame(): No space left on device" macht mich jetzt bei näherem Hinsehen stutzig. Wenn ich eines habe, dass ist es Speicher. Ausser im /tmp/.
Ich werde mal den PMS updaten und das Transcode-Verzeichnis woandern hinlegen. Melde mich dann zurück.
