I still can't find the problem, everything seems ok, but every movie stops playing at approx. 1 hour and 20 minutes, gives a spinning wheel at the left and resumes after couple of minutes.
After then it repeats every couple of minutes.
uname -a
FreeBSD donald.flissinger.com 10.1-RELEASE-p5 FreeBSD 10.1-RELEASE-p5 #27: Mon Feb 9 10:33:27 CET 2015
latest plexconnect via git.
and via bind dns server and apache virtual host on same server.
Settings.cfg:
[PlexConnect]
enable_plexgdm = False
ip_pms = 10.0.0.1
port_pms = 32400
enable_dnsserver = False
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = False
enable_plexconnect_autodetect = False
ip_plexconnect = 10.0.0.1
hosttointercept = trailers.apple.com
port_webserver = 9999
enable_webserver_ssl = True
port_ssl = 9443
certfile = /usr/local/etc/certs/plexconnect.pem
allow_gzip_atv = True
allow_gzip_pmslocal = True
allow_gzip_pmsremote = True
loglevel = High
logpath = /var/log/plexconnect
/var/log/plexconnect.log
[data]
13:46:24 ATVLogger: Player state: Playing at this time: 0
15:09:14 WebServer: http request header:
Host: trailers.apple.com
X-Apple-Store-Front: 143452-2,19
Accept: */*
Accept-Encoding: gzip, deflate
Accept-Language: en;q=0.9
Cookie: s_vi=[CS]v1|2A3115FF05010EC8-6000013500001285[CE]
X-Apple-TV-Resolution: 1080
X-Apple-TV-Version: 7.0.3
User-Agent: AppleTV/7.0.3 iOS/8.1.3 AppleTV/7.0.3 model/AppleTV3,2 build/12B466 (3; dt:12)
Cache-Control: max-age=259200
X-Forwarded-For: 10.0.0.1
X-Forwarded-Host: trailers.apple.com
X-Forwarded-Server: trailers.apple.com
Connection: Keep-Alive
15:09:14 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Loading%20at%20this%20time%3A%204970.790266666667
15:09:14 Localize: aTVLanguage: en
15:09:14 WebServer: pms address:
15:09:14 WebServer: cleaned path:
15:09:14 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Loading at this time: 4970.790266666667', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:09:14 WebServer: additional arguments:
15:09:14 ATVLogger: Player state: Loading at this time: 4970.790266666667
15:10:21 WebServer: http request header:
Accept: */*
15:10:21 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Playing%20at%20this%20time%3A%204970.814911957
15:10:21 Localize: aTVLanguage: en
15:10:21 WebServer: pms address:
15:10:21 WebServer: cleaned path:
15:10:21 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Playing at this time: 4970.814911957', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:10:21 WebServer: additional arguments:
15:10:21 ATVLogger: Player state: Playing at this time: 4970.814911957
15:10:35 WebServer: http request header:
Accept: */*
15:10:35 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Loading%20at%20this%20time%3A%204984.9311777777775
15:10:35 Localize: aTVLanguage: en
15:10:35 WebServer: pms address:
15:10:35 WebServer: cleaned path:
15:10:35 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Loading at this time: 4984.9311777777775', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:10:35 WebServer: additional arguments:
15:10:35 ATVLogger: Player state: Loading at this time: 4984.9311777777775
15:11:41 WebServer: http request header:
Accept: */*
15:11:41 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Playing%20at%20this%20time%3A%204984.943654791
15:11:41 Localize: aTVLanguage: en
15:11:41 WebServer: pms address:
15:11:41 WebServer: cleaned path:
15:11:41 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Playing at this time: 4984.943654791', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:11:41 WebServer: additional arguments:
15:11:41 ATVLogger: Player state: Playing at this time: 4984.943654791
15:19:34 WebServer: http request header:
Accept: */*
15:19:34 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Loading%20at%20this%20time%3A%205457.586288888889
15:19:34 Localize: aTVLanguage: en
15:19:34 WebServer: pms address:
15:19:34 WebServer: cleaned path:
15:19:34 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Loading at this time: 5457.586288888889', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:19:34 WebServer: additional arguments:
15:19:34 ATVLogger: Player state: Loading at this time: 5457.586288888889
15:19:39 WebServer: http request header:
Accept: */*
15:19:39 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Playing%20at%20this%20time%3A%205457.607926367
15:19:39 Localize: aTVLanguage: en
15:19:39 WebServer: pms address:
15:19:39 WebServer: cleaned path:
15:19:39 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Playing at this time: 5457.607926367', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:19:39 WebServer: additional arguments:
15:19:39 ATVLogger: Player state: Playing at this time: 5457.607926367
15:19:44 WebServer: http request header:
Accept: */*
15:19:44 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Loading%20at%20this%20time%3A%205462.859788888889
15:19:44 Localize: aTVLanguage: en
15:19:44 WebServer: pms address:
15:19:44 WebServer: cleaned path:
15:19:44 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Loading at this time: 5462.859788888889', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:19:44 WebServer: additional arguments:
15:19:44 ATVLogger: Player state: Loading at this time: 5462.859788888889
15:19:45 WebServer: http request header:
Accept: */*
15:19:45 WebServer: http request path:
/&PlexConnectATVLogLevel=1&PlexConnectLog=Player%20state%3A%20Playing%20at%20this%20time%3A%205462.878338428
15:19:45 Localize: aTVLanguage: en
15:19:45 WebServer: pms address:
15:19:45 WebServer: cleaned path:
15:19:45 WebServer: PlexConnect options:
{'aTVAddress': '10.0.0.1', 'aTVScreenResolution': '1080', 'PlexConnectATVLogLevel': '1', 'PlexConnectLog': 'Player state: Playing at this time: 5462.878338428', 'aTVFirmwareVersion': '7.0.3', 'aTVLanguage': 'en'}
15:19:45 WebServer: additional arguments:
15:19:45 ATVLogger: Player state: Playing at this time: 5462.878338428
</div>
</div>
</div>
</div>
<p> </p>
<p>Who can help me out? struggling with it for months...</p>
