Are there any plans to translate PlexConnect into local language (similar to Plex/Web) ? If yes, I can help with some translations, if necessary.
I've translated some text strings to Portuguese and I would like to test the final result. How can I do it ?
A very short todo is found inside PlexConnect/assets/locales/locales.txt...
Basically you have to add the correct directory with the PO file inside.
