PlexConnect v0.3 iMovie Theater
Now that PlexConnect v0.3 is out how do I go about using iMovie Theater instead of the Trailers app?
Thanks!
Thanks!
i'm 99 % sure there's a guide, search for it.
Short story long-you need to change all of the trailers.apple.com in the code the imovie theater's one .. And adding certs matchly ..
Anyway, if you have windows/Mac i hardly recommend that you'll wait to Plexify 1.1 Final, cause with it you'll be able to choose which app PlexConnect will use and Plexify will do anything it takes :)
https://forums.plexapp.com/index.php/topic/86012-how-to-use-imovie-theater-instead-of-the-trailers-app/
Thanks,
Huh?
Outdated?
There is a setting for that:
hosttointercept = trailers.apple.com
Huh?
Outdated?
Outdated, that's the word :)
Last time i checked this was the method ..Didn't know you made it easier :) So i guess it was easier then i think put that in Plexify :)
