Plexconnect with an apple tv on a different network?
I've been running my PMS for several years successfully, when I make the changes for PlexConnect I get a specific error.
19:44:54 DNSServer: started: 19:44:54
19:44:54 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
19:44:54 PlexConnect: DNSServer not alive. Shutting down.
19:44:54 PlexConnect: Shutting down.
19:44:54 PlexConnect: shutdown
I'm not mapping port 53 to anything and I tried disabling the DNSServer to no avail.
A little help would be greatly appreciated.
This thread may help:  http://forums.plexapp.com/index.php/topic/70169-failed-to-create-socket-on-udp-port-53-errno-48/
Quick question. What port do I need to open on my router incoming to let the connection from the WAN PlexConnect get back in?
I would think it would be 53 DNS, 80 Http, 443 https
Actually, I found out the answer. I thought i had deleted the post.
The only thing I had to open incoming was 32400. Everything else is handled by the PlexConnect.
Works great. 32400 was already open so I could get in via the web browser outside of the network.
Josh
most ISP's will not allow incoming DNS requests, I have posted another alternative that does work, you just host a version of plexconnect from the remote site and point it to your ports for plex along with adding in the remote IP so that it doesnt require authentication.  I will see if I can find it.
This is pretty much what I did.
I set up a PlexConnect at home and a PlexConnect at my moms house. I set the PC at my moms to point the the PMS at my house.
Seemed to work great. Surprisingly fast as well.
Sorry Josh, I had thought you did not want to have plexconnect running at her place, so I gave the ports I though an ATV needs to connect to a remote plex connect.  But happy its working for you.
I didn't. . :wub:  It was just easier to set it up. I set it up to run on her Mac in the background on startup. She'll never even know it's there and therefore can't delete it..
I appreciate the help.
