Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): MD199FD/A Firmware 6.0(66646.65)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.1.21
The device and operating system (including version number) that PlexConnect is installed on: Mac Mini OS 10.9
The local IP address of the device that PlexConnect is installed on: 192.168.1.21
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Mac Mini OS 10.9
The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.8.17.282-c844f09
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.21
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. 02 January 2014 11:30 CET
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]port_pms = 32400port_webserver = 80ip_plexconnect = 0.0.0.0certfile = ./assets/certificates/trailers.pemip_dnsmaster = 192.168.1.1loglevel = Normalenable_dnsserver = Truelogpath = .enable_plexgdm = Falseip_pms = 192.168.1.21hosttointercept = trailers.apple.comport_ssl = 443enable_webserver_ssl = Trueprevent_atv_update = Trueport_dnsserver = 53enable_plexconnect_autodetect = True
Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
A detailed description of the issue (the clearer you can make this the better): When i turn on my local (192.168.1.21) Firewall (with IceFloor) then the PlexConnect can't find any PMS. If i turn it of, it would be found. Which port do i have to give free that PlexConnect will run? The System says
"PlexAPI: No Respons from Plex Media Server"
"PlexAPI: We failed to reach a server. Reason: timed out"
If i turn of the Firewall then all works fine.
32400 is the standard PMS port.
plus 32414 for PlexGDM. maybe others, too?
and
32410
32413
32414
assuming you want it to discovery the PMS.
