ATV3 Plexconnect sees PMS but no library
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV3 5.3(6105)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS):10.0.2.3
  • The local IP address of the device that PlexConnect is installed on: 10.0.2.3
  • The device and operating system (including version number) that PlexConnect is installed on: OSX Server 10.7.5
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: OSX Server 10.7.5
  • The Plex media server (PMS) version number you are running (do not put 'latest'):0.9.8.18
  • The local IP address of the device that the Plex media server (PMS) is installed on:10.0.2.3
  • The PlexConnect version number. 0.3.1+
  • The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = ./assets/certificates/trailers.pem
ip_dnsmaster = 8.8.8.8
loglevel = High
enable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
enable_webserver_ssl = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
hosttointercept = trailers.apple.com
  • detailed description of the issue (the clearer you can make this the better):
PlexConnect on ATV3 sees server in Settings>Discover>Plex Media Servers:1. But under Library> PlexConnect No Plex Library Sections Available.
System was working flawlessly (6 months) until OSX server had to be reset.
PMS set to "require authentication"?
PMS set to different port?
Thanks for the quick response Baa.
Where do I check those settings?
Baa! thank you so much.
Authentication on local networks was enabled in PMS settings.
Genius!
