PlexDBEditor
Hello.
I think it is a very useful tool but I get error when I try to run.
Why can it be?
Tell me which error exactly it is and I'll see what I can do :)
Last update for Plex 0.8 series:
  • Added possibility to delete genres
  • CMD+V now works for all text fields
    Link again in the first post.
    @fanden: Sorry, support of Dvdpedia won’t be added. I don’t own that tool and don’t plan to buy it. And even if I had it, that would be much more work than I ever wanted to put into the PlexDBEditor
Looks like an awsome application, but when I run it nothing happens?
a big thx for this !
it works however the editor crashes everytime I delete a genre, needs to be reopen again everytime
but it works
Found the bug, it always crashes if the deleted genre was assigned to more than one movie. I made a quick fix, could you please try if it works?
How does this application work? do we need to do anything than run it???
There is no data in the dialog??
Just wanted to ask if "the dialog is empty" is what happens to you ;) That mean's the database can't be found. Actually a popup should appear, but there was a small bug... I just fixed that.
The editor is looking for the file **~/Library/Application Support/Plex/userdata/Database/MyVideos34.db**. Could you please check if that file exists in your case?
oups, unfortunately I can't try it anymore, I've cleaned it up already...464 movies :-)
deleted all the genres and put added the ones I wanted, in my language :-)
Thank you
The file exist, I'll try again...
Hm, consol returns this when I start the application.
10/01/10 14.34.36 CoreServicesUIAgent[462] kCGErrorIllegalArgument: CGSUnionRegionWithRect : Invalid region
10/01/10 14.34.36 CoreServicesUIAgent[462] kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10/01/10 14.34.36 CoreServicesUIAgent[462] kCGErrorIllegalArgument: CGSGetRegionBounds : Invalid region
10/01/10 14.34.36 com.apple.coreservices.uiagent[462] Sun Jan 10 14:34:36 mkh.local CoreServicesUIAgent[462] : kCGErrorIllegalArgument: CGSUnionRegionWithRect : Invalid region
10/01/10 14.34.36 com.apple.coreservices.uiagent[462] Sun Jan 10 14:34:36 mkh.local CoreServicesUIAgent[462] : kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10/01/10 14.34.37 kernel IOHIDSystem::relativePointerEventGated: VBL too high (35400988), capping to 20000000
10/01/10 14.34.42 PlexDBEditor[460] oi
10/01/10 14.34.42 PlexDBEditor[460] 1
Still empty, can i provide you any logs that might gives you a hint?
When I try to use the checkboxes thet cant be “checked”
/mkh
Gosh I feel SO SO stupid, found the “error” its called mkh :stuck_out_tongue:
forgot I moved all my movies to another machine… gosh
need sleep
I can not make the program work, not start.
Attached the error report
Thanks, this helped. I just uploaded a new version with the bugfix. Please give a short feedback if it works.
It's great.
Now it works.
Thank you very much, I'm testing.
This app is great! Thank you very much.
Do you think it is possible to also show/edit the tagline?
I think it is field c02 in the movie table.
Thanks again!
Does Plex use that information somewhere? I knew that it's stored in the database, but have no idea where it is displayed. So I thought it's not necessary...
Some skins can show it instead of the full summary (which will be shown when pressing i)
(for instance the Rapier skin)
PleaAeon shows it as well.
Okay, will be added in the next version. But that maybe will take a while, I don’t work on it until Plex 0.9 is out.
