So, my current MythTV setup allows me to record more than 2 shows at the same time with a 2 tuner HDHOMERUN. The reason is we have channels 10.1, 10.2, 10.3, 12.1, 12.2, 12.3. Myth allows me to use “multirec”, i.e., I can record 10.2, 10.2, and 10.3 at the same time using one tuner of the HDHOMERUN, and, 12.1, 12.2, and 12.3 on the other tuner, so, up to 6 shows at once. Does the Plex DVR allow this feature, or, is it limited to 1 recording per tuner (simultaneous)?HDHOMERUN certainly allows this to be done, just curious if Plex does.
Gotta be honest - I have no idea how you have that working. A single tuner can tune only a single signal at one time. There would be NO WAY to have it lock to multiple frequencies and be able to access that simultaneously.
Here’s some reading for you, works perfectly fine, several dvrs support this:
https://www.mythtv.org/wiki/record_multiple_channels_from_one_multiplex
Ah… I missed the part about recording from the same primary frequency and grabbing the multi-plex’ed (no pun intended) signals under it.
