DNS Apple TV 3: 192.168.2.254
Changed to IP Synology: 192.168.2.9
Think I got it almost running, but…
PlexConnect: started: 14:39:54
PlexConnect: ***
PlexConnect: PlexConnect
PlexConnect: Press ENTER to shut down.
PlexConnect: ***
PlexConnect: IP_self: 192.168.2.9
PlexGDM: ***
PlexGDM: looking up Plex Media Server
PlexGDM: ***
PlexGDM: No servers discovered
PlexConnect: PMS: 192.168.178.10:32400
DNSServer: started: 14:39:55
DNSServer: ***
DNSServer: Starting up.
DNSServer: intercept trailers.apple.com: 192.168.2.9
DNSServer: forward other to higher level DNS: 192.168.2.254
DNSServer: ***
WebServer: started: 14:39:55
WebServer: ***
WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
WebServer: ***
Think I got it almost running, but...
PlexConnect: ***
PlexConnect: ***
PlexGDM: ***
PlexGDM: ***
DNSServer: ***
DNSServer: ***
WebServer: ***
WebServer: ***
hardcode the plex ip (I assume your synology) in the plexconnect folder under settings
Okay changed Settings.py to:
shoot sorry bro, that's about my limit for synology nas's, hopefully someone else can chime in here, if you are in a pinch and really want to test you could run plex connect on a desktop.
g_settings = { \'enable_plexgdm' :('True', 'False'), \'ip_pms' :('192.168.2.9',), \'port_pms' :('32400',), \\'enable_dnsserver':('True', 'False'), \'ip_dnsmaster' :('8.8.8.8',), \\'loglevel' :('Normal', 'High') \}No change:PlexConnect: PlexConnectPlexConnect: Press ENTER to shut down.PlexConnect: ***PlexConnect: started: 08:47:54PlexConnect: IP_self: 192.168.2.9PlexGDM: ***PlexGDM: looking up Plex Media ServerPlexGDM: ***PlexGDM: No servers discoveredPlexConnect: PMS: 192.168.2.9:32400DNSServer: started: 08:47:55DNSServer: ***DNSServer: Starting up.DNSServer: intercept trailers.apple.com: 192.168.2.9DNSServer: forward other to higher level DNS: 8.8.8.8DNSServer: ***WebServer: started: 08:47:56WebServer: ***WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.WebServer: ***
what is the actual issue now?
GDM hasn't worked, but it looks to have added your server manually just fine.
Okay I now got a error on the Apple TV 3 when I open the Trailers app. It says Trailers unavailable. Also YouTube and all other 'apps' doesn't work anymore. If I change the DNS back it works again.
you'll need to manually edit the DNS settings then too, replace 8.8.8.8 with whatever your network normall uses.
Still doesn;t work.
Still doesn;t work.
PlexConnect: started: 09:19:44PlexConnect: ***PlexConnect: PlexConnectPlexConnect: Press ENTER to shut down.PlexConnect: ***PlexConnect: started: 09:19:44PlexConnect: IP_self: 192.168.2.9PlexConnect: PMS: 192.168.2.9:32400WebServer: started: 09:19:44WebServer: ***WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.WebServer: ***Normal DNS Apple TV 3: 192.168.2.254 (changed to IP Synology)IP Synology: 192.168.2.9IP PMS: 192.168.2.9Port PMS: 32400
double check haven't messed up the formatting of the settings, the DNS server doesn't even look to be starting there...
you should be seeing this'
DNSServer: started: xx:xx:xxDNSServer: ***DNSServer: Starting up.DNSServer: intercept trailers.apple.com: 192.168.2.9DNSServer: forward other to higher level DNS: 192.168.2.254
Please... don't mess with "settings.py".
There is a "settings.cfg" file created for your innovations... and once .cfg is there, changes to the defaults in .py won't have any effect anyways.
PlexConnect: started: 09:34:46PlexConnect: ***PlexConnect: PlexConnectPlexConnect: Press ENTER to shut down.PlexConnect: ***PlexConnect: started: 09:34:46PlexConnect: IP_self: 192.168.2.9PlexGDM: ***PlexGDM: looking up Plex Media ServerPlexGDM: ***PlexGDM: No servers discoveredPlexConnect: PMS: 192.168.2.9:32400DNSServer: started: 09:34:47DNSServer: ***DNSServer: Starting up.DNSServer: intercept trailers.apple.com: 192.168.2.9DNSServer: forward other to higher level DNS: 192.168.2.254DNSServer: ***WebServer: started: 09:34:47WebServer: ***WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.WebServer: ***g_settings = { \'enable_plexgdm' :('True', 'False'), \'ip_pms' :('192.168.2.9',), \'port_pms' :('32400',), \\'enable_dnsserver':('True', 'False'), \'ip_dnsmaster' :('192.168.2.254',), \\'loglevel' :('Normal', 'High') \}
looks fine, as far as setup for PlexConnect, all done.
If you still get no icons on your ATV, i would check the firewall setup on your Syn to ensure it is allowing the DNS requests.
Stupid question: You have PMS running on Synology as well?
I don't mess with Settings.py
Settings.cfg:
The problem is that when I click Trailers on the Apple TV 3 nothing comes up except Trailers unavailable. Please try again later.
Yes PMS is running.
That was it Thank you so much. Got it running now. :)
What was wrong?
What was wrong?
Firewall in the Synology settings. So easy but I'm not that smart. :P
Dutch subtiltes (selected) not showing BTW. Is that normal?
Don't know... no chance to check - nobody of us developers is speaking Dutch... :-D
Dutch works just fine for me.
