PlexIPTV
Hey guys,
I have create a new app for the DVR plex features. If you have an IPTV provider and would like that one to be on the DVR feature, you can try it out.
This app simulate a DVR device for Plex by providing a layer to any IPTV provider (that provide a m3u8 playlist).
I created that app for several reasons:
What it does?
It does:
  • pull remote m3u8 file to a local file
  • if remote file isn’t accessible it will fallback to the local file
  • settings can help to filter play list and remap the channels
  • proxy the IPTV stream so only the server will be seen as the “user”
  • allow multiple concurent views into the same channel even if the provider block it
Initially I create that for myself, but it can help other people or show Plex Team why not to integrate similar approach (without the DVR emulation) directly into Plex.
You can download it here: https://github.com/xiaodoudou/PlexIPTV
Cheers,
You have to provide instructions on how to use this. Do i just download and run it or what?
Instructions on how to upload and setup in plex, IN LAYMANS TERMS, would be helpful
