PlexKodiConnect: Kodi Plex Integration Done Right
I tried to watch Channels on PKC on Libreelec with my wetek play and I couldn’t. Even I couldn’t go in Settings for kino.pub channel. Also I couldn’t watch any film or TV live channel - there is Playback error
detailed log here is http://paste.debian.net/985451/
Thanks for the error report.
Is the Kino.pub channel official? I cannot install it directly within the PMS.
Looking at your log, the kino.pub communication is different than the stuff I have seen up till now. If not to say that their XML responses are simply malformed :disappointed: . Do other channels than kino.pub work?
The TV live channel issues will hopefully fixed with the next PKC beta release
Edit:
Fixed the one issue I could spot with your channels. Hopefully that’s it :wink:
no, it is not official channel. I can’t see neither TV live channels from it, nor films.
Looking at your log, the kino.pub communication is different than the stuff I have seen up till now. If not to say >that their XML responses are simply malformed :disappointed: . Do other channels than kino.pub work?
no. Edem channels also doesn’t work.
Edit:
thanks. But I could try only after release the package of PKC for Libreelec repo.
Edit:
The new PKC BETA version is online now, please try and report back
Does this plugin support multiple extras? Let’s say I have two trailers an a featuretote. Will all three be shown in Kodi?
I have honestly no idea - try it! :wink: Thinking of Kodi skins, do any of them support multiple trailers?
@SUPERBIF said:
@croneter said:
@SUPERBIF said:
Question or suggestions for this awesome plugin:
  1. Will it be possible somehow to have a watchlist for videos which can be synced with Kodi. So each time i add a movie in plex app or Kodi it will be synes?
  2. I have installed my rating on Kodi so each time i rate a movie it syncs to TMDB with my rating. Will it be possible to have it synced through PKC?
Thanks for your fantastic work on this plugin.
  1. A synching of Plex playlists to Kodi is currently not supported. But it has been requested frequently.
  2. I have no idea what you mean, sorry. Ratings are synced from Plex to Kodi and - I think - the other way around as well :lol:. Whatever else you do on the Kodi side of things is up to you and should “naturally” work
Okay thanks for the answer. The playlist thing would be excellent.
On 2. It doesn’t work for me. When I go into my library and vote it doesn’t get updated on plex app. Have i missed a setting?
Hi is it possible to get help with the rating, I have tried on 3 different clients. If I vote on 1 client I only see the vote on that machine not the others and not in Plex. Can you please help?
PKC does not yet support you rating something on the Kodi side of things, sorry
I guess no then, because every skin i use max. hast the trailer button which directly plays the first “extra”.
No possibility to select the second or third.
Or maybe someone here knows a skin which supports multiple extras?
Would be a great feature to make Kodi the best Plex client :wink:
Every official Plex client supports it.
Is there any way to get theme music in PKC?
croneter, although the number of posts in this thread show your plugin has its share of users, I just wanted to let you know I Love PKC! I started using plex as a primary backend specifically for your plugin, and have been using it for several months since then.
I have seen other plugins I use get abandoned in the past due to the dev not knowing there was any interest in their project, so i wanted to ensure you that your project is used regularly.
Keep up the great work pushing out those bug fixes!
I pushed the update to the stable version of PKC after not hearing any bad news from you guys. There were quite a few code changes to improve PKC. Let me know if something isn’t working…
Changelog
changes from 1.8.12 to 1.8.15:
  • Update translations
  • Greatly speed up displaying context menu
  • Fix IndexError e.g. for channels if stream info missing
  • Sleep a bit before marking item as fully watched
  • Don’t sleep before updating playstate to fully watched (if you watch on another Plex client)
  • Fix KeyError for TV live channels for getGeople
  • Background sync now picks up more PMS changes
  • Detect Plex item deletion more reliably
  • Fix changed Plex metadata not synced repeatedly
  • Detect (some, not all) changes to PKC settings and apply them on-the-fly
  • Fix resuming interrupted sync
  • PKC logging now uses Kodi log levels
  • Further code optimizations
Hi croneter !
Thx for your update but I have a New bug : now I cant changed subtitles when I saw a movie… Do you know why ?
Not with PKC. Maybe there are other Kodi add-ons that help
@agasi34 said:
Hi croneter !
You have to elaborate a bit. When can you not change subtitles? Are you using direct paths or add on paths? Does this always happen or just when you resume a video?
PKC only hands Kodi a list of subtitles apart from the ones Kodi discovers by itself. “changing” and displaying subtitles etc is all done by Kodi
Hello,
I haven’t tried yet this plugin. I’m still awaiting for my ODROID C2 and plan to use it with openPHT 1.8, but I would like to give a try to PKC on a different SD card, just to compare the ease of use.
So i plan to install libreElec + Kodi Krypton but I don’t understand the “sync” process between Plex and Kodi => My PMS is hosted on a dedicated NUC with several Go of data. Will these data remain on the NUC or should I get a very high capacity SD card because it will be copied ?
Thank you
@cyriltra said:
Hello,
Thank you
Hopefully you will be convinced that PKC is THE deal :wink:
The “Sync process” only syncs movie, TV show and music metadata from Plex to Kodi, which amounts to a couple of megabytes at most. PKC also syncs all Plex artwork (and a bit more if you enable additional artwork) to Kodi and caches that BEFORE you use it - this easily takes up a couple of gigabytes if you have a huge library. You can deactivate that in the PKC Settings, however, under Artwork, Force artwork caching
Hi Croneter,
thx for your quick answer.
You have to elaborate a bit. When can you not change subtitles? When i start a movie or when i’m in the osd, i try to change the subtitles but there is only the first subtitle which worked… When i try to change subtitles, nothing work (but i can change subtitle when i use plex app on my android phone so subtitles exist
Are you using direct paths or add on paths? Does this always happen or just when you resume a video?** i use direct paths and it always happen.**
PKC only hands Kodi a list of subtitles apart from the ones Kodi discovers by itself. “changing” and displaying subtitles etc is all done by Kodi____
@croneter thanks for your reply.
I dig more on your Github and is the bugs with PMS still on ? (https://forums.plex.tv/discussion/comment/1287014#Comment_1287014) I’m using PMS 1.9.
Thank you
Thank you
Yes, that’s still an issue. But you should NOT “feel” it as I programmed PKC around this PMS behavior, e.g. PKC will first sync new items, then it will silently sync changed items.
