PlexKodiConnect | Reset thumbnails, organize by folder
Hi, I have started using PlexKodiConnect on Kodi. Its great so far, keep up the good work guys. I have a couple of questions that I need some help with.
a) How do I reset the video thumbnails in the addon? It seems they got corrupted and show portions of the image only.
b) Is there any way to toggle folder filtering for home videos. I am using it to watch family camera footage but those tend to be great in numbers. Currenly they all show flat as video files and its really hard to navigate and find what you want there. I already have the organized in folders, but I dont see an option to browse with folders in the addon. The native plex client for fire tv allows folders.
Glad you like PKC :-D.
a) Ugh, probably best to quickly reset the Kodi db (the sync is much faster now). PKC Settings, Advanced, Reset Kodi database, then YES, YES, NO. That will also delete all the cached artwork
b) You are correct sir, that possibility is missing. Opened a Github issue: https://github.com/croneter/PlexKodiConnect/issues/167
Perfect, thanks!! the thumbnail problem got resolved.
