No longer able to access personal added libraries?
Hi Guys
No longer able to access personal added libraries? It has worked fine for months but just started over past week. Libraries I have added no access but built in ones fine.
Before I go through the log routine wondered if anybody knew a quick fix to try.
Hi Guys
Log file here http://pastebin.com/k8w1XcqU
loglevel=High?
What do you mean with “built in” libraries? Did you update your PMS?
Hi baa
It was set to high
I have added a library called Video Tutoirals which I used to be able to access
Mt PMS is latest version
Not sure if it helps but I can access these libraries / folders on all my other devices and web. The only place I am blocked is PlexConnect, it even shows scrolling thumbnails when I click on the folder!
Hi Baa i have run it again with Setting set HIGH
Log as follows http://pastebin.com/wdMUUV2f
I am also running 0.5-Dev-020615
PMS 0.9.12.12.145949fe448
I have tried everything i have it set as Home Videos Scanner Plex Video Files Scanner
Agent Personal Media
Really could do with some help please
Looking at your log it looks like none of your media has valid durations in the xml, I’ve seen this problem before, try rescanning the media in Plex and it should fill in the durations. This really needs fixing in PlexConnect but I keep forgetting :frowning:
Hi Roidy
Just done a full rescan but it has not worked here is new log
http://pastebin.com/mwegMH7B ???
That log still doesn’t seem to be “loglevel=High”. It should give you much more information (like received XMLs), even the discovery process should be more informing… you got to restart PlexConnect after changing settings, right?
HI
I not only restarted Plex but rebooted the Apple TV this is my settings file
http://pastebin.com/1U4Pqm7Y
So confused,i can try again if you want
HI Baa
You were right the new log is huge see here https://dl.dropboxusercontent.com/u/92887/PlexConnect.log
I was struggling to get anything to list seem to take ages for libraries to load
Hope this helps
I am not quite sure what’s going on…
Are you running PlexConnect locally on your jailbroken aTV?
The first lines of your log…
18:17:31 WebServer: http request path:
/assets/com_apple_MobileAsset_AppleKeyServicesCRL/com_apple_MobileAsset_AppleKeyServicesCRL.xml
I have never seen something like this. What is apple doing/requesting there?
Hi Baa
Nothing funny i have PlecConnect on my JB ATV. No idea about Apple request is there anything more you can suggest. Or anything else you want me to do to try and track the issue down?
HI Guys
I tried a fresh install
I used
apt-get -y install git; rm -R /Applications/atvjailbreak; cd /Applications; git clone git://github.com/wahlmanj/atvjailbreak.git; cd /Applications/atvjailbreak; chmod +x installwahlmanj.bash; ./installwahlmanj.bash
From the Teminal Window
http://pastebin.com/yrw58LFj
I have tried again No Luck still not working here is the new log file https://dl.dropboxusercontent.com/u/92887/PlexConnect%2015%20Sep%202015.log
Thorrrr
Ok, the file aTV is looking for at Apple is…
http://mesu.apple.com/assets/com_apple_MobileAsset_AppleKeyServicesCRL/com_apple_MobileAsset_AppleKeyServicesCRL.xml
You can easily look at it, it’s some XML containing a Certificate. Don’t know what they do with it… I have never seen it, as it will only be caught on an aTV directly, kind of a side effect of canceling out the automatic updates. I don’t think we have to worry about it for now, unless we are concerned about the time consumed in the WebServer area.
For the main issue… your aTV seems a bit overloaded. The last PMS-XML is received at 09:17:36, printout done at 09:17:52, an error is logged 09:23:15, and at 09:23.59 the XMLConverter is still working. Shutting down logging might help a lot… but then we wouldn’t be able to investigate. :smiley:
Anyways, the root cause might be the following session:
  <Video addedAt="1441561045" art="/library/metadata/71616/art/1441566770" key="/library/metadata/71616" originallyAvailableAt="2007-08-22" ratingKey="71616" summary="" thumb="/library/metadata/71616/thumb/1441566770" title="02_07_Events" type="movie" updatedAt="1441566770" year="2007">
    <Media id="113738">
      <Part file="H:\ServerFolders\Videos\Tutorial Videos\Lynda com JavaScript Essential Training\02.Developer Essentials\02_07_Events.mov" id="115843" key="/library/parts/115843/file.mov" size="2" />
    </Media>
  </Video>
Normally there is a bunch of additional information provided at “Media id=…” like file size, resolution, duration. But for this media item nothing is disclosed. XMLConverter marks duration data as “((ERROR:durationToString))”, which might upset the aTV…
Please remove that offending file from your library, do a library refresh, and try again.
Hi Baa
Which file do you want me to delete ???
XMLConverter.py or XMLConverter.pyc
Neither of those… from you library: H:\ServerFolders\Videos\Tutorial Videos\Lynda com JavaScript Essential Training\02.Developer Essentials\02_07_Events.mov
Hi Baa
Not made any difference still not loading in PlexConnect but loading on all my other devices with no issue.
Any thoughts or do you need a new log ?
Thorrrr
Hi Baa
Thorrrr
Are you able to shrink your section to a lower number, e.g. divide those files into 4 different section to figure out if its every section or still depends on a couple of files? This would also make the log file leaner…
