Yes, but using the Pattern syntax requires you to know the whole file name pattern. I’m trying to do something generic that would work across many different series. I expect that it will be given a low priority.
Specifically, a lot of newer anime are showing up that are sometimes “Season 2” and sometimes “Season 1 Part 2” so they need an episode numbering fix to line up correctly depending on how they’re entered into TVDB. I’d rather not have to put in the exact naming pattern for every different series.
So… what exactly are you trying to achieve?
I can see the point of giving a hint about a file’s season/episode number not matching the selected episode order – and therefore allowing Plex to compensate for ash (without renaming the files themselves).
Just not sure what you’re trying to achieve by having a “generic instruction” to offset the episode number across multiple shows.
If you’re using a custom episode order – why not have a single plexmatch file with a single-line pattern as shared by DTR. That’s of course assuming your files follow some kind of naming schema across an entire series.
For when databases (in particular the one you choose and the one the source chooses) have conflicting opinions on whether the 2nd Part / Cour of a show is a continuation of a previous season or a new one.
I might use TVDB on Plex, and their call is that Cool Show - Awesome Arc - Part 2 starts as Season 02.
The source, on the other hand, might use TMDB to number their files, and TMDB made the call that entry is a continuation and starts from S01E13 instead.
