I have no clue what is going on, I’ve been at this for hours, I was watching star wars and all of a sudden my plex server goes down and when i start the plexmediaserver service I get:
~$ sudo service plexmediaserver restart
Job for plexmediaserver.service failed because the control process exited with error code. See “systemctl status plexmediaserver.service” and “journalctl -xe” for details.
running “systemctl status plexmediaserver.service” gives me:
~ sudo systemctl status plexmediaserver.service ● plexmediaserver.service - Plex Media Server for Linux Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled) Active: inactive (dead) (Result: exit-code) since sön 2017-10-15 07:30:57 CEST; 46s ago Process: 13337 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}”
okt 15 07:30:52 Bulbasaur systemd[1]: Failed to start Plex Media Server for Linux.
okt 15 07:30:52 Bulbasaur systemd[1]: plexmediaserver.service: Unit entered failed state.
okt 15 07:30:52 Bulbasaur systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
okt 15 07:30:57 Bulbasaur systemd[1]: plexmediaserver.service: Service hold-off time over, scheduling restart.
okt 15 07:30:57 Bulbasaur systemd[1]: Stopped Plex Media Server for Linux.
okt 15 07:30:57 Bulbasaur systemd[1]: plexmediaserver.service: Start request repeated too quickly.
okt 15 07:30:57 Bulbasaur systemd[1]: Failed to start Plex Media Server for Linux.
I’ve tried reinstalling the server multiple times and the server seem to install good enough although it runs into an error when it starts it up.
It should be noted that I’ve recently moved my cache file to the dev/shm dir to use RAM for writing transcoded videos. but I suspect that this somehow crashed plex? because the folder that I added under dev/shm got deleted somehow and thus it could not locate the cache folder, this shouldn’t prevent the server from running though? I’ve also edited the xml to point back to the default Cache location.
this was the last thing the server was logging before faceplanting:
Oct 15, 2017 02:05:50.193 [0x7f539fffe700] DEBUG - HTTP requesting GET https://plex.tv/servers//access_tokens.xml?auth_token=xx$
Oct 15, 2017 02:05:50.193 [0x7f539fffe700] ERROR - Error issuing curl_easy_perform(handle): 6
Oct 15, 2017 02:05:50.193 [0x7f539fffe700] WARN - HTTP error requesting GET https://plex.tv/servers//access_tokens.xml?auth_tok$
Oct 15, 2017 02:05:50.193 [0x7f539fffe700] ERROR - Uncaught exception running threadpool task: boost::filesystem::create_directory: Permission denied: "/var/lib/plexme$
Oct 15, 2017 02:05:50.193 [0x7f53873fb700] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Oct 15, 2017 02:05:50.194 [0x7f53873fb700] DEBUG - HTTP requesting GET https://plex.tv/servers//access_tokens.xml?auth_token=xx$
Oct 15, 2017 02:05:50.194 [0x7f53873fb700] ERROR - Error issuing curl_easy_perform(handle): 6
Oct 15, 2017 02:05:50.194 [0x7f53873fb700] WARN - HTTP error requesting GET https://plex.tv/servers//access_tokens.xml?auth_tok$
Oct 15, 2017 02:05:50.194 [0x7f53873fb700] ERROR - Uncaught exception running threadpool task: boost::filesystem::create_directory: Permission denied: "/var/lib/plexme$
Oct 15, 2017 02:05:50.194 [0x7f53a87fd700] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Oct 15, 2017 02:05:50.194 [0x7f53a87fd700] DEBUG - HTTP requesting GET https://plex.tv/servers//access_tokens.xml?auth_token=xx$
Oct 15, 2017 02:05:50.255 [0x7f53c77fd700] WARN - Warning: ex: boost::filesystem::last_write_time: Permission denied: "/usr/lib/plexmediaserver/Resources/Plug-ins-9f65$
Oct 15, 2017 02:05:50.255 [0x7f53c77fd700] WARN - Warning: ex: boost::filesystem::last_write_time: Permission denied: "/var/lib/plexmediaserver/Library/Application Sup$
Oct 15, 2017 02:05:50.273 [0x7f53a87fd700] ERROR - Error issuing curl_easy_perform(handle): 77
Oct 15, 2017 02:05:50.273 [0x7f53a87fd700] WARN - HTTP error requesting GET https://plex.tv/servers//access_tokens.xml?auth_tok$
CAfile: /usr/lib/plexmediaserver/Resources/cacert.pem
CApath: none)
Oct 15, 2017 02:05:50.273 [0x7f53a87fd700] ERROR - Uncaught exception running threadpool task: boost::filesystem::create_directory: Permission denied: “/var/lib/plexme$
Oct 15, 2017 02:05:50.273 [0x7f53963ff700] DEBUG - Auth: Refreshing tokens inside the token-based authentication filter.
Oct 15, 2017 02:05:50.273 [0x7f53963ff700] DEBUG - HTTP requesting GET https://plex.tv/servers//access_tokens.xml?auth_token=xx$
Oct 15, 2017 02:05:50.348 [0x7f53963ff700] ERROR - Error issuing curl_easy_perform(handle): 77
Oct 15, 2017 02:05:50.348 [0x7f53963ff700] WARN - HTTP error requesting GET https://plex.tv/servers//access_tokens.xml?auth_tok$
CApath: none)
$plexmediaserver/Library/Application Support/Plex Media Server/Cache”
(I’ve removed some of the key)
please help, I’ll go and cry myself to slep now…
