Server Version#: 1.13.8.5395
Player Version#: 1.13.8.5395
NOTE: the script works perfectly when running it manually.
Oct 06 12:16:31 macbookpro sh[3340]: ********************************************************
Oct 06 12:16:31 macbookpro sh[3340]: Starting Transcoding: Converting to H.264 w/ffmpeg @720p
Oct 06 12:16:35 macbookpro sh[3340]: ffmpeg: /usr/lib/plexmediaserver/libz.so.1: version `ZLIB_1.2.9’ not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
Oct 06 12:16:35 macbookpro sh[3340]: ERROR # 1 : Failed to convert using ffmepg
plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2018-10-06 10:48:43 EDT; 9h ago
Main PID: 3340 (sh)
Tasks: 53 (limit: 4915)
CGroup: /system.slice/plexmediaserver.service
├─3340 /bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver “/usr/lib/plexmediaserver/Plex Media Server”
├─3342 /usr/lib/plexmediaserver/Plex Media Server
├─3399 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-10d48da0d/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.13.8.5395-10d48da0d
└─3464 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.13.8.5395-10d48da0d 32600 /waitmutex
Oct 06 18:42:58 macbookpro sh[3340]: Auto selecting the PID.
Oct 06 18:42:58 macbookpro sh[3340]: Commercials were found.
Oct 06 18:43:24 macbookpro sh[3340]: ********************************************************
Oct 06 18:43:24 macbookpro sh[3340]: Starting Transcoding: Converting to H.264 w/ffmpeg @720p
Oct 06 18:43:24 macbookpro sh[3340]: ffmpeg: /usr/lib/plexmediaserver/libz.so.1: version `ZLIB_1.2.9’ not found (required by /usr/lib/x86_64-linux-gnu/libpng16.so.16)
Oct 06 18:43:24 macbookpro sh[3340]: ERROR # 1 : Failed to convert using ffmepg
Oct 06 18:43:29 macbookpro sh[3340]: GUI: Matching ‘The Goldbergs’
Oct 06 18:43:37 macbookpro sh[3340]: GUI: Score for ‘The Goldbergs’ (2013) is 104
Oct 06 18:43:37 macbookpro sh[3340]: GUI: Requesting metadata for ‘The Goldbergs’
Since you’re using his script, I can only refer you to his github for support.
Your use of ffmpeg is yours to resolve at this point since it’s clearly an LD_LIBRARY_PATH issue and/or you’ve got a 32 bit vs 64 bit issue (names look the same but still won’t resolve and load).
I was having the same problem as OP and I got it working for myself. The problem lies with this: export LD_LIBRARY_PATH=/usr/lib/plexmediaserver
The version of zlib in Plex’s library is not compatible the ffmpeg that I have installed. (Maybe one is newer than the other – I don’t know because I’m not going to look into it now that it is working)
I am loading my default library path for my system. This may be different for other people.
I’m wrapping most of the code inside parentheses, which creates a subshell because that will prevent the library setting from interfering with Plex’s parent process.
