Transcoder Fails 100% - direct play works
Server Version#: latest public, latest beta (tried both)
Player Version#: latest
Transcoder fails to convert - direct play works
problem affects all files - not only one (type)
Conversion failed. The transcoder exited due to an error.
Errorcode: s1001 (Network)
what i tried
  • deleting Codecs did not work
/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs
  • conversion of a sample file with plex-transcoder CLI did work
  • all permissions checked (both file-location and transcoder path)
  • tried both; default transcode location and outside plex-library
Plex Media Server Logs_2021-04-04_18-24-48.zip (2.8 MB)
need help :frowning: thanks
From Plex Media Scanner.log
WARN - [FFMPEG] - Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libmp3_decoder.so: failed to map segment from shared object
Apr 04, 2021 18:20:48.644 [0x7f0458492780] WARN - [FFMPEG] - Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libvp6f_decoder.so: failed to map segment from shared object
Apr 04, 2021 18:20:48.644 [0x7f0458492780] WARN - [FFMPEG] - Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libwmv2_decoder.so: failed to map segment from shared object
Apr 04, 2021 18:20:48.644 [0x7f0458492780] WARN - [FFMPEG] - Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libhevc_decoder.so: failed to map segment from shared object
Apr 04, 2021 18:20:48.644 [0x7f0458492780] WARN - [FFMPEG] - Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libmp2_decoder.so: failed to map segment from shared object
It look very similar to this one https://forums.plex.tv/t/conversion-failed-the-transcoder-exited-due-to-an-error/652874/2
Did you move PMS to a network share or a non-root volume?
Error loading external lib: /mnt/PlexLibrary/plexmediaserver/Library/Application Support/Plex Media Server/Codecs/73e06c8-3759-linux-x86_64/libwmv1_decoder.so: failed to map segment from shared
The partition mounted does not have the exec option.
thank you! it was exactly that… mounted ssd without exec option :confused:
my bad …
thank you very much!
