Does anyone know how to execute the "Plex New Transcoder" from the commandline ?
Exporting LD_LIBRARY_PATH didn't work, it keeps ending up with:
Shared object "libz.so.1" not found, required by "Plex New Transcoder"
(running PMS on FreeNAS 9.2.0)
Shared object "libz.so.1" not found, required by "Plex New Transcoder"(running PMS on FreeNAS 9.2.0)
This is how it is done on unbuntu, should be pretty similar.
sudo su - plex -c "export LD_LIBRARY_PATH="/usr/lib/plexmediaserver";/usr/lib/plexmediaserver/Resources/Plex\ New\ Transcoder"
