I’ve wrapped PlexPy into an app for the WD NAS.
I tested only on a PR4100, but all WD platforms should be supported.
Let me know if you experience any bugs or if your platform is missing.
Thank You! Works great on PR2100.
Work like a charm.
I had a Docker version of PlexPY, it work, but I had some issue with launching the app at reboot. Your wrapped version works great, I even being able to relink to my old DB.
Thank you very much!
I updated my package to Tautulli, the new name of PlexPy.
I added instructions to import your existing config / database via SSH.
I installed your Tuatulli package for PR2100, but it’s still PlexPy v1.4.25. Is it normal?
Indeed, I’m using the stable branch.
I’m adding instructions for the beta in the tread.
I’ll have a look to create a beta package.
@TFL a new beta package for Tautulli v2 would be very welcomed, thank you!
@-TFL- said:
I’ve wrapped PlexPy into an app for the WD NAS.I tested only on a PR4100, but all WD platforms should be supported.
I’m grateful that you’ve done this with instructions too. I, however is a noob to this and really interested to set this up on my wd ex2100 and would appreciate some assistant in installing tautulli. I’ve installed the .bin file for my model but fazzy on what further settings I need to tweak to make it work. Are there further install I need to do?
like port forward - how i set this up (is this on my nas or network?)
Downloaded the program and installed on a PR4100. I changed the backup file locations, and it says the files have been created but there are no files.
