PlexTV Desktop Live Stream Channels suddenly "offline"
Server Version#:
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: AsianCrush, ConTV, RetroCrush
Hi there! Sorry for this newb question. I mainly use the PlexTV on Google browser everyday, but all of a sudden the past weekend, some of the live stream channels that I watch just kept on “loading”. So I went to my server to check and see if it’s any different, it was the same. There was an error that says “This live stream channels appears to be offline” or something to that effect whenever I try clicking on it. This is my first time encountering this so I am clueless on what to do next. I decided to rollback my update from 1.31.3.6868 to 1.31.1.6733 since I saw a couple of threads saying that some issues could get fixed if you rollback your version. It was still the same.
Is there any workaround for this kind of issue? Or am I stuck waiting for a new update to come out?
Any tips or advice will be much appreciated!
have you tried a different browser?
Thank you for that very quick response! And yes, I tried to use Brave, and it was still the same.
