I can try to help but I'm just trying to figure most of this out myself.
I would reference my plexWatch.log file. If you want you can post at least that portion of your config.pl file.
Cheers
This is the section
When looking at plex activity I see My PleXBMC Client
## Give a user a more friendly name. I.E. REAL_USER will now be Frank
## you may also specify the platform with user+platform
$user_display = {'My PleXBMC Client' => 'Family Home',
'phairfamily+iOS' => 'Vicks Ipad',
'Folks' => 'Folks TV',
'Folks+iOS' => 'Vee Ipad',
Cheers
is
the last one in the list of names?
If so you need to take out that last ","
It should be
here is what mine looks like and it works ok.
is
It should be
I really don't get it! It's still won't work
Can you post your PLexWatch.log or part of it?
Okay I’ve been looking at this wrong it does work as per the log
Wed Apr 29 19:21:36 2015: Family Home Watched: All Hail King Julien - King Me - s01e01 [D] [2014] [TV-PG] on My PleXBMC Client for 2 minutes [15%]
Yet I don’t see it in my notification. How can I correct this?
Phairfamily = Family Home
Thank you all for your help so far
The Plex client names aren’t something you can configure
Sent from my HTC One_M8 using Tapatalk
Okay I've been looking at this wrong it does work as per the log
Yet I don't see it in my notification. How can I correct this?
Yea that looks right. My Plex names appear correctly in my Push Bullet notifications though. Just as they do in the log.
AHHH... I see you were looking at Client names! "My PleXBMC Client" duhhh. I didn't put that together.
The Plex client names aren't something you can configure
Another correction on my part im using boxcar
I get everything aside from the user name i see
Plexwatch: Watched
Sorry to mess you about I appreciate the help
Plexwatch: Watched
Ahh, I use PushBullet on Android and it works great. Maybe it's the app?
Okay I'll try pushbullet
When asked for the apikey do I use the the access token?
I just wanted to say that this walk-through while not 100% explanatory was incredibly helpful.
I finally have PlexWatch and PlexWatchWeb up and running with PushBullet and secure (I think) external access. This is GREAT! Thank you sfnetwork for putting this together, the devs for these great 3rd party add-ons and all the people who documented their issues/solutions.
Yea, use the access token. and blank out the fields you're not using. Like if you dont have a channel set up just delete the data between the quotes. I left the data and it broke the push.
I have mine notify me of everything to every device using no channels.
Thanks that fixed it.
I still don't see the user I get the same as before...every but Grrr!
Did you leave the Title above the apikey as
'{user}',
Not sure if that's what that code controls..... ¯\_(ツ)_/¯
Thats odd because your log displays the user names.... Here is a screen shot of my Pushbullet page with some notifications I got. They appear the same way on all my devices with the exception of screen size.... So on my phone it may cut off some of the info but I still see the user name.
Mine says "plexWatch" when a new episode has been added.
It's always said plexwatch
