wondering if anyone can help me out… i’ve set up plexwmc channel and serverwmc on another computer… i can access the channel guide and recorded tv shows in the plexwmc channel… however when i go to stream/play the files it says ‘There was a problem playing this item’…
@chriswelstead - You can look through this forum post where some troubleshooting steps that have been done or setup that you may have missed will be documented. If you post here you will get more people involved who are using the channel as well that can help.
