This is not random. Plex always displays external subtitles below embedded ones.
Edit: huh, I see what you mean. Seems like a Plex bug
Iāve now realised that while the issue is fixed for formats that can be passed through to my receiver (AC3), itās still a problem with formats that canāt be passed through (E-AC3). Is there anything that can be done to make the audio start cleanly even when Kodi is having to decode it?
You can tell PM4K to force to AC3, which results in direct streaming from the PMS side of things, if necessary. Or play with refresh rate switching delay in kodi. Itās pretty much out of PM4Ks hands.
Edit: thereās a thread for the ideal kodi settings on the SHIELD, I canāt find it right now and the info might be old (you should be using omega), but worth a try as well
Edit 2: at least make sure dolby audio processing is disabled in the shield. You can also try sync playback to display in kodi (disables audio passthrough, though)
Edit 3: and, most importantly: Videoplayer cuts off about 500ms of audio at start of playback Ā· Issue #23535 Ā· xbmc/xbmc Ā· GitHub
0.7.9-beta18.1: script.plexmod.zip (2.8 MB)
Further CoreELEC stabilization, plex.direct fixes and additions.
Temporary Changelog:
Edit: This should finally be stable enough, so I can start finalizing and merging the huge 16:10 (smaller aspect ratios) branch, to get the 0.7.9 release on the way
Hi, I just learned of this add-on for the first time. Iāve been using PlexKodiConnect (PKC) for some time now, and Iām wondering whatās the difference between this and PKC. Iām open to switch to using this if it seems better for me. (Iām using Android TV (Shield), if that matters)
Also, in addition to what the differences are, is there some video somewhere to see what this setup looks like?
Thanks.
Can someone in the community advise if PM4K can be run on the same device as PKC without causing problems? Iāve never used PKC.
If so, my advice to @cat_person48 would be to read post 1 in this thread and then have a tryout on his/her device. Iād be surprised if doing so wouldnāt lead to switching to PM4K.
Depending on how heavy PKC is on your Kodi instance while it fetches library updates for example, it could lead to PM4K or playback lagging, as we donāt have any control over its behaviour.
Iād advise to simply disable PKC while testing out PM4K (addons in Kodi can be disabled via the addon manager/addon info screen).
PKC connects directly to the kodi database and uses it to make a kodi libraries so itās like a local library using the kodi gui.
PM4K is a TV UI frontend which loads its own UI on top of kodi and just uses the kodi video player.
PM4K is more of an app, everything is self-contained within.
PKC uses native Kodi interface, which allows skins to be used.
Iāve tried both, but PM4K is more robust for my relatively large setup (~250Tb). PKC would freeze/crash/etc.
Iāve never seen anything like this - did no one test this, or is it just stable for the CoreELEC guys now?
Dead silence ![]()
Skipping around movies is definitely better for me in beta 18.1 - so far I havenāt seen any instances of the player exiting unexpectedly (which was happening on the previous builds)
Thanks for going the extra mile for us CoreELEC folks ![]()
lol Been ātestingā on a coreelec box the last few hours, ran into a few issues and just as I was gonna report realized I wasnāt using the latest beta oops.
Guess I gotta go ātestā some more now.
Donāt know about anyone else but I am unable to resume a episode that has time left on it from the episode view. I press play and nothing happens. Only seen this bug a few times though, most of the time itās fine.
Edit: sorry that was meant to be in reply to @panni
Canāt say Iāve noticed that (in recent builds), but Iāll post back if it happens to me
Logs! (and device info)
This was because of the seek fix for CoreELEC, which was introduced in the previous beta(s). It fixed the resume issues (not resuming at all) but tended to double-seek the relative offset (e.g., resume point was at 1:20h, video length 2:10h, actually used, bad resume point at 2:40h), resulting in a seek beyond the video length, effectively closing the video player. This should be fixed with beta18.1.
To reiterate: All of those things are due to the original CoreELEC issue, that seeking is bugged compared to ānormalā Kodi instances, and leads to massive audio bugs/delay.
Weāre really trying to make CE work for everyone, but all of those fixes are based on certain timing-related assumptions, which can vary from CE device to CE device. If you experience unexpected resume behaviour, please go to addonSettings of PM4K and increase the CoreELEC: Resume-fix wait for seek by 50ms at a time, and please tell us which delay works for you for which device. Our current default (200ms) was tested by 1-2 users with a specific Ugoos device.
Edit: Clarifications
ānothing happensā as in: doesnāt do anything? Thatās nothing to do with the latest CE fixes (probably). Please track back betas and post logs for each if you can.
As in the sub menu to resume or start from the beginning doesnāt appear.
Thanks @panni , I have a Ugoos AM6B+ and the default settings are working well for me on the latest beta. As I say there was a marked improvement in reliability (specifically relating to skipping around a movie/jumping to a chapter) going from 18.0 to 18.1. Iāll post back if I notice anything unexpected going on though.
Please create a ticket on Github, thanks!
I dont have a github account and havenāt seen it since. Will chalk it up to luck.
PM4K unable to play episodes without Internet. While the movies screen works fine without internet, only problem is with seekdialog.py
Error Received without Internet:
2024-08-12 13:40:04.058 T:15156 error <general>: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class 'AttributeError'>
Error Contents: 'NoneType' object has no attribute 'binge_mode'
Traceback (most recent call last):
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\windows\kodigui.py", line 144, in onInit
self._onInit()
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\windows\kodigui.py", line 209, in _onInit
self.onFirstInit()
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\windows\videoplayer.py", line 151, in onFirstInit
self.play(resume=self.resume)
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\windows\videoplayer.py", line 358, in play
player.PLAYER.playVideoPlaylist(self.playQueue, resume=self.resume, session_id=id(self), handler=handler)
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\player.py", line 1411, in playVideoPlaylist
self._playVideo(resume and self.video.viewOffset.asInt() or 0, seeking=handler and handler.SEEK_PLAYLIST or 0,
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\player.py", line 1261, in _playVideo
self.handler.setup(self.video.duration.asInt(), meta, offset, bifURL, title=self.video.grandparentTitle,
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\player.py", line 260, in setup
self.dialog.setup(self.duration, meta, int(self.baseOffset * 1000), self.bifURL, self.title, self.title2,
File "C:\Users\Administrator\AppData\Roaming\Kodi\addons\script.plexmod\lib\windows\seekdialog.py", line 499, in setup
self.bingeMode = pbs.binge_mode
AttributeError: 'NoneType' object has no attribute 'binge_mode'
-->End of Python script error report<--
try:
if self.player.video.type == 'episode':
pbs = self.player.video.playbackSettings
util.DEBUG_LOG("Playback settings for {}: {}", self.player.video.ratingKey, pbs)
self.handler.inBingeMode = self.bingeMode
# don't auto skip intro when on binge mode on the first episode of a season
firstEp = self.player.video.index == '1'
if self.isDirectPlay or util.getUserSetting('auto_skip_in_transcode', True):
self.autoSkipIntro = (self.bingeMode and not firstEp) or pbs.auto_skip_intro
self.autoSkipCredits = self.bingeMode or pbs.auto_skip_credits
self.showIntroSkipEarly = self.bingeMode or pbs.show_intro_skip_early
self.handler.skipPostPlay = self.skipPostPlay = (self.bingeMode or pbs.skip_post_play_tv)
# in transcoded scenarios, when seeking, keep previous marker states, as the video restarts
if not keepMarkerDef:
self.resetMarkerStates()
except IndexError:
self.doClose(delete=True)
raise util.NoDataException
self.showChapters = util.getUserSetting('show_chapters', True) and (
bool(chapters) or (util.getUserSetting('virtual_chapters', True) and bool(self.markers)))
self.setProperty('has.chapters', self.showChapters and '1' or '')
After removing the binge mode it works fine.
