Server Version#: 1.18.6.2368
Player Version#: 3.0 preview
Windows 10 1909
AMD RX 480 20.1.3 drivers
Just wondering if anyone has run into this yet. I searched but didn’t find anything.
I loaded up the latest PMP Preview on my windows 10 box hooked up to an LG 3D TV to see if I could get 3D movies working since I haven’t been able to get them working using the PS4 app and the Xbox and Apple TV apps don’t support it.
The issue I’m running into is full screen mode, it just isn’t full screen. It’ll show up in the upper left hand corner of the TV thinking it’s full screen but really only using ~60% of the screen. I usually run 150% scaling in Windows 10 so I can read things from the couch but with that set, the player scales at 150% and because it’s in the upper left hand corner, you can only see part of it. Set scaling to 100% and I can see the entire player but it’s not full screen.
If I run in windowed mode, I can maximize the window and 3D movies work but they’re in a windows instead of being full screen. Is there some setting I need to tweak to get to run properly in full screen mode? It’s almost like it thinks it’s 720p resolution instead of 1080p the way full screen mode takes up about that portion of the screen.
