Thanks for the reply.
Now no matter what mode I am in (TV vs Web) 4k movies will not direct play. So now I am looking for help
The Local Quality is set to Original. I had a bit of time to test this today and found some items in the logs that jump out at me. The first bunch below is from the PlexMediaPlayer.log and the other one is from the plexmediaplayer.conf that was in the Users…\PlexMediaPlayer folder.
Why and how is maxBitrate set to 8000?
Also my audio is now transcoding and before it wasn’t.
On another note, but because I am going through all my configs again I thought I may as well ask, is HDR working with Plex Media Player and how does Windows need to be set to get it working correctly?
Thanks for your time,
Seamus
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - ffmpeg: Mime-type: ‘video/x-matroska’
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - ffmpeg: Stream opened successfully.
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: Cache size set to 587000 KiB (75000 KiB backbuffer)
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - demux: Trying demuxers for level=normal.
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: Found the head…
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: + a segment…
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: |+ segment information…
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + muxing app: Lavf58.9.100
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + writing app: Lavf58.9.100
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + timecode scale: 1000000
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + duration: 8077.120s
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + segment uid 05 21 fc 7c ba 0d 50 5d d0 c2 36 2c cc 37 ee 55
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: |+ segment tracks…
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + a track…
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Track number: 1
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Track type: Video
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Video track
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Pixel width: 1920
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Pixel height: 1080
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Codec ID: V_MPEG4/ISO/AVC
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + CodecPrivate, length 41
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Language: und
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Default duration: 1.000ms ( = 1000.000 fps)
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Track number: 2
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Track type: Audio
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Audio track
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Sampling frequency: 48000.000000
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Bit depth: 32
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Channels: 8
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Codec ID: A_OPUS
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + CodecPrivate, length 29
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: | + Language: eng
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: |+ found cluster
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - mkv: All headers are parsed!
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - demux: Detected file format: Matroska
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - demux: Stream is not seekable.
2019-03-09 19:35:07 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: blocking for STREAM_CTRL 6
2019-03-09 19:35:08 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: Cache is not responding - slow/stuck network connection?
2019-03-09 19:35:13 [ INFO ] CodecsComponent.cpp @ 1260 - Using system audio decoders: true
2019-03-09 19:35:13 [ INFO ] CodecsComponent.cpp @ 1261 - Using system video decoders: false
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Opening done: https://192.168.188.100:32400/video/:/transcode/universal/start?hasMDE=1&path=%2Flibrary%2Fmetadata%2F109494&mediaIndex=0&partIndex=0&protocol=http&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&maxVideoBitrate=8000&directStreamAudio=1&mediaBufferSize=512000&session=gzjvgsdsfygypxjq1kagojem&offset=168&subtitles=auto©ts=1&Accept-Language=en&X-Plex-Session-Identifier=xxx&X-Plex-Client-Profile-Extra=append-transcode-target-codec(type%3DvideoProfile%26context%3Dstreaming%26protocol%3Dhttp%26videoCodec%3D*%26audioCodec%3D*)&X-Plex-Chunked=1&X-Plex-Client-Identifier=xxx&X-Plex-Device-Screen-Resolution=3840x2160%2C3840x2160&X-Plex-Version=3.90.1&X-Plex-Client-Capabilities=protocols%3Dshoutcast%2Chttp-video%3BvideoDecoders%3Dh264{profile%3Ahigh%26resolution%3A2160%26level%3A52}%3BaudioDecoders%3Dmp3%2Caac%2Cdts{bitrate%3A800000%26channels%3A8}%2Cac3{bitrate%3A800000%26channels%3A8}&X-Plex-Product=Plex%20Media%20Player&X-Plex-Platform=Konvergo&X-Plex-Platform-Version=2.29.1.961-bb236059&X-Plex-Device=Windows&X-Plex-Device-Name=MediaPC&X-Plex-Model=10&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx&X-Plex-Language=en&X-Plex-Client-Profile-Name=Konvergo
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - global: config path: ‘sub’ -/-> ‘C:/Users/mediauser.THEVERSE/AppData/Local/PlexMediaPlayer/sub’
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Running hook: main/on_preloaded
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: sid=“no” → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: aid=“1” → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: ad=“h264,opus” → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: vd=“h264,opus” → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Run command: hook-ack, flags=0, args=[on_preloaded]
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - cplayer: (+) Video --vid=1 () (h264 1920x1080 1000.000fps)
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - cplayer: (+) Audio --aid=1 --alang=eng () (opus 8ch 48000Hz)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vo/opengl-cb: Assuming 23.976023 FPS for display sync.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Container reported FPS: 1000.000000
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Codec list:
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: h264_cuvid (h264) - Nvidia CUVID H264 decoder
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Opening video decoder h264
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Probing ‘d3d11va’…
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Trying hardware decoding.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: Using VO-supplied device 000001d9087c2e20.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Selected video codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ad: Codec list:
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ad: opus - Opus
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ad: Opening audio decoder opus
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ad: Requesting 1 threads for decoding.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ad: Selected audio codec: opus (Opus)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Starting playback…
2019-03-09 19:35:13 [ ERROR ] PlayerComponent.cpp @ 599 - cplayer: Cannot seek in this file.
2019-03-09 19:35:13 [ ERROR ] PlayerComponent.cpp @ 599 - cplayer: You can forcibly enable it with ‘–force-seekable=yes’.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Audio filter chain:
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [in] 48000Hz 7.1 8ch floatp
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [out] 48000Hz 7.1 8ch floatp
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [ao] 48000Hz 7.1 8ch floatp
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao: Trying audio driver ‘wasapi’
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: requested format: 48000 Hz, 7.1 channels, floatp
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: No device specified. Selecting default.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Window size: 3840x2160
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video source: 0x0 (0:0)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video display: (0, 0) 1x1 → (0, 0) 3840x2160
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video scale: 3840.000000/2160.000000
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: OSD borders: l=-1073739904 t=0 r=-1073739904 b=0
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video borders: l=0 t=0 r=0 b=0
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Selecting device ‘{4f736dbd-83e1-4652-a45a-ce24bfb1a604}’ (DENON-AVR (NVIDIA High Definition Audio))
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Monitoring changes in device {0.0.0.00000000}.{4f736dbd-83e1-4652-a45a-ce24bfb1a604}
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.1 float (32/32 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo float (32/32 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/32 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 44100hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 96000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 88200hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 192000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 176400hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 32000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 22050hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 11025hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 8000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 16000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 352800hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying stereo s32 (32/24 bits) @ 384000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 5.1 s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.1 s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 6.1 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying mono s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 2.1 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 4.0 s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 5.0 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 3.0 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 3.0(back) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying quad s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying quad(side) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 3.1 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 5.0(side) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 4.1 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 5.1(side) s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 6.0 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 6.0(front) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 6.1(front) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.0 s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.0(front) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.1(wide) s32 (32/24 bits) @ 48000hz (exclusive) → ok
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying 7.1(wide-side) s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying empty s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Trying octagonal s32 (32/24 bits) @ 48000hz (exclusive) → unsupported
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Channel layouts:
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - stereo
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - 5.1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - 7.1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - 4.0
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - quad
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - 5.1(side)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: - 7.1(wide)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: result: 7.1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Accepted as 7.1 s32 @ 48000hz → 7.1 s32 (32/24 bits) @ 48000hz (exclusive)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Device period: 10 ms
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: Buffer frame count: 480 (10 ms)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: IAudioClock::GetFrequency gave a frequency of 48000.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: device buffer: 480 samples.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ao/wasapi: using soft-buffer of 9600 samples.
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - cplayer: AO: [wasapi] 48000Hz 7.1 8ch s32
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: AO: Description: Windows WASAPI audio output (event mode)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Adding filter lavrresample
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Setting option ‘normalize’ = ‘yes’ (flags = 0)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Setting option ‘o’ = ‘surround_mix_level=1’ (flags = 0)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [lavrresample] 48000Hz 7.1 8ch s32 [a]
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [out] 48000Hz 7.1 8ch s32
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [ao] 48000Hz 7.1 8ch s32
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Inserting volume filter.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Adding filter volume
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Setting option ‘warn’ = ‘no’ (flags = 0)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: Removing filter lavrresample
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - af: [volume] “softvol” 48000Hz 7.1 8ch floatp
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - volume: volume gain: 0.729000
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Pixel formats supported by decoder: dxva2_vld d3d11va_vld yuv420p
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Codec profile: High (0x64)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {86695f12-340e-4f04-9fd3-9253dd327460} MPEG2and1_VLD NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {ee27417f-5e28-4e65-beea-1d26b508adc9} MPEG2_VLD NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {6f3ec719-3735-42cc-8063-65cc3cb36616} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {1b81bea4-a0c7-11d3-b984-00c04f2e73c5} VC1_D2010 NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {1b81bea3-a0c7-11d3-b984-00c04f2e73c5} VC1_D NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {32fcfe3f-de46-4a49-861b-ac71110649d5} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {d79be8da-0cf1-4c81-b82a-69a4e236f43d} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {f9aaccbb-c2b6-4cfc-8779-5707b1760552} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {1b81be68-a0c7-11d3-b984-00c04f2e73c5} H264_E NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {5b11d51b-2f4c-4452-bcc3-09f2a1160cc0} HEVC_VLD_Main NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {107af0e0-ef1a-4d19-aba8-67a163073d13} HEVC_VLD_Main10 NV12 P010
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {20bb8b0a-97aa-4571-8e99-64e60606c1a6} NV12 P010
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {15df9b21-06c4-47f1-841e-a67c97d7f312} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {efd64d74-c9e8-41d7-a5e9-e9b0e39fa319} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {ed418a9f-010d-4eda-9ae3-9a65358d8d2e} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {9947ec6f-689b-11dc-a320-0019dbbc4184} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {33fcfe41-de46-4a49-861b-ac71110649d5} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {463707f8-a1d0-4585-876d-83aa6d60b89e} VP9_VLD_Profile0 NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {a4c749ef-6ecf-48aa-8448-50a7a1165ff7} NV12 P010
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {dda19dc7-93b5-49f5-a9b3-2bda28a2ce6e} NV12 P010
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {6affd11e-1d96-42b1-a215-93a31f09a53d} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11va: {914c84a3-4078-4fa9-984c-e2f262cb5c9c} NV12
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Selecting {1b81be68-a0c7-11d3-b984-00c04f2e73c5} H264_E 103
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Requesting pixfmt ‘d3d11va_vld’ from decoder.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - ffmpeg/video: h264: Reinit context to 1920x1088, pix_fmt: d3d11va_vld
2019-03-09 19:35:13 [ INFO ] JS: [Metrics] Updating session last interaction time
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - vd: Using hardware decoding (d3d11va).
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Decoder format: 1920x1080 d3d11_nv12[nv12] auto/auto/auto/auto CL=mpeg2/4/h264
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vd: Using container aspect ratio.
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - vf: Using conversion filter.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vf: Video filter chain:
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vf: [in] 1920x1080 d3d11_nv12[nv12] bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vf: [d3d11vpp] 1920x1080 d3d11_rgb[rgb0] rgb/bt.709/bt.1886/full SP=1.000000 CL=mpeg2/4/h264 [a]
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - vf: [out] 1920x1080 d3d11_rgb[rgb0] rgb/bt.709/bt.1886/full SP=1.000000 CL=mpeg2/4/h264
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11vpp: Found 1 rate conversion caps. Looking for caps=0x2.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11vpp: - 0: 0x00000017
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - d3d11vpp: (matching)
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 595 - cplayer: VO: [opengl-cb] 1920x1080 d3d11_rgb[rgb0]
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: VO: Description: OpenGL Callbacks for libmpv
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: set video colors output-levels=0
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video source: 1920x1080 (1:1)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video display: (0, 0) 1920x1080 → (0, 0) 3840x2160
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Video scale: 2.000000/2.000000
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: OSD borders: l=0 t=0 r=0 b=0
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Testing FBO format rgba16f
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Create FBO: 16x16 (16x16)
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: Using FBO format rgba16f.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - opengl-cb: No advanced processing required. Enabling dumb mode.
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: first video frame after restart shown
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: starting audio playback
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: playback restart complete
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: video-unscaled=false → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: video-aspect="-1" → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: keepaspect=true → 1
2019-03-09 19:35:13 [ DEBUG ] PlayerComponent.cpp @ 593 - cplayer: Set property: panscan=0.000000 → 1
2019-03-09 19:35:13 [ INFO ] PlayerComponent.cpp @ 461 - Entering state: playing
2019-03-09 19:35:14 [ INFO ] JS: [Player] Timeline, {
“ratingKey”: “109494”,
“key”: “/library/metadata/109494”,
“playbackTime”: 0,
“playQueueItemID”: “10466458”,
“state”: “playing”,
“hasMDE”: 1,
“time”: 169000,
“duration”: 8077000
2019-03-09 19:35:14 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: Cache is not responding - slow/stuck network connection?
2019-03-09 19:35:14 [ INFO ] JS: [Player] Can play AUTOMATIC? true
2019-03-09 19:35:14 [ INFO ] JS: [Player] Can play DASH? false
2019-03-09 19:35:14 [ INFO ] JS: [Player] Can play HLS? true
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Augmented profile: {
“directPlay”: {
“mp4”: {
“video”: {
“maxBitrate”: 8000
“asf”: {
“video”: {
“maxBitrate”: 8000
“avi”: {
“video”: {
“maxBitrate”: 8000
“mkv”: {
“video”: {
“maxBitrate”: 8000
“mpeg”: {
“video”: {
“maxBitrate”: 8000
“mpegts”: {
“video”: {
“maxBitrate”: 8000
“3gpp”: {
“video”: {
“maxBitrate”: 8000
“wtv”: {
“video”: {
“maxBitrate”: 8000
“mov”: {
“video”: {
“maxBitrate”: 8000
“directStream”: {
“video”: {
“maxBitrate”: 8000
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Starting analysis of 4k (mkv, hevc, truehd, 153, main 10)
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Analyzing direct play
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Invalid profile property; bitrate: 45195 > 8000
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Cannot direct play: validateProfileProperty:maxBitrate
2019-03-09 19:35:14 [ INFO ] JS: [Player] Can direct stream? true (isAllowed: true)
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Analyzing video direct stream
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Analyzing audio direct stream
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Analyzing playability
2019-03-09 19:35:14 [ INFO ] JS: [MDE] Finished analysis of 4k (mkv, hevc, truehd, 153, main 10)
2019-03-09 19:35:14 [ INFO ] JS: canPlay: true
2019-03-09 19:35:14 [ INFO ] JS: canDirectPlay: false
2019-03-09 19:35:14 [ INFO ] JS: canDirectStreamVideo: false
2019-03-09 19:35:14 [ INFO ] JS: canDirectStreamAudio: true
2019-03-09 19:35:14 [ INFO ] JS: bitrate: 8000
2019-03-09 19:35:14 [ INFO ] JS: videoResolution: 2560
2019-03-09 19:35:14 [ INFO ] JS: console.groupEnd
2019-03-09 19:35:15 [ INFO ] JS: [Player] Timeline, {
“playbackTime”: 2004,
“state”: “playing”,
“hasMDE”: 1,
“time”: 170000,
“duration”: 8077000
2019-03-09 19:35:17 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: Cache is not responding - slow/stuck network connection?
2019-03-09 19:35:18 [ DEBUG ] UpdaterComponent.cpp @ 52 - It has gone 1044 seconds since last update check.
2019-03-09 19:35:25 [ INFO ] JS: [Player] Timeline, {
“playbackTime”: 12025,
“state”: “playing”,
“hasMDE”: 1,
“time”: 180000,
“duration”: 8077000
2019-03-09 19:35:26 [ DEBUG ] PlayerComponent.cpp @ 593 - cache: Cache is not responding - slow/stuck network connection?
“sections”: {
“appleremote”: {
“emulatepht”: true
“audio”: {
“allowAC3”: false,
“allowDCA”: false,
“allowEAC3”: false,
“audioBoost”: 100,
“channels”: “7.1,5.1,2.0”,
“device”: “auto”,
“devicetype”: “hdmi”,
“exclusive”: true,
“normalize”: true,
“passthrough.ac3”: true,
“passthrough.dts”: true,
“passthrough.dts-hd”: true,
“passthrough.eac3”: true,
“passthrough.truehd”: true
“cec”: {
“activatesource”: true,
“enable”: true,
“hdmiport”: 0,
“poweroffonstandby”: false,
“suspendonstandby”: false,
“usekeyupdown”: false,
“verbose_logging”: false
“main”: {
“allowHttpFallback”: “samenetwork”,
“alwaysOnTop”: true,
“autoLogin”: false,
“autoPostPlay”: false,
“automaticUpdates”: true,
“bgStyle”: “blur”,
“clientUUID”: “xxx”,
“clock”: “h:mm a”,
“collectUsageData”: true,
“companion”: true,
“disablemouse”: false,
“extrasPrefixCount”: 0,
“forceAlwaysFS”: false,
“forceFSScreen”: “”,
“fullscreen”: true,
“hdmi_poweron”: false,
“language”: “en”,
“layout”: “auto”,
“logLevel”: “debug”,
“manualUpdateCheck”: true,
“minimizeOnDefocus”: false,
“playThemeMusic”: true,
“preventSystemScreensaver”: false,
“remoteInspector”: false,
“sdlEnabled”: true,
“showPowerOptions”: true,
“sleepTime”: 600000,
“sounds”: true,
“updateChannel”: 0,
“useHelper”: true,
“useOpenGL”: false,
“useSystemVideoCodecs”: false,
“volume”: 100,
“webMode”: “tv”,
“webserverport”: 32433
“manualServers”: {
“ip1”: “”,
“ip2”: “”,
“port1”: “32400”,
“port2”: “32400”
“path”: {
“helperprogram”: “”,
“startupurl_desktop”: “bundled”,
“startupurl_tv”: “bundled”
“privacy”: {
“subtitles”: {
“color”: “#EEEEEE,#000000”,
“placement”: “center,bottom”,
“size”: 32
“system”: {
“lircd_enabled”: false,
“smbd_enabled”: false,
“sshd_enabled”: false,
“systemname”: “PlexMediaPlayer”
“video”: {
“allowDisplayModeSwitching”: false,
“allowHDR”: false,
“aspect”: “normal”,
“audio_delay.24hz”: 0,
“audio_delay.25hz”: 0,
“audio_delay.50hz”: 0,
“audio_delay.normal”: 0,
“cache”: 500,
“canSwitchDisplayMode”: false,
“canSwitchVideoPlayer”: false,
“channelQuality”: -1,
“debug.force_vo”: “”,
“deinterlace”: true,
“directPlay”: true,
“directStream”: true,
“h264Level”: -1,
“hardwareDecoding”: “enabled”,
“localQuality”: -1,
“refreshrate.auto_switch”: true,
“refreshrate.avoid_25hz_30hz”: false,
“refreshrate.delay”: 3,
“remoteQuality”: 8,
“subtitleColor”: “#ffffff”,
“subtitlePosition”: “bottom”,
“subtitleSize”: 100,
“subtitlesBurnLevel”: “always”,
“switchDisplayMode”: false,
“sync_mode”: “audio”,
“useAndroidMediaPlayer”: false
“version”: 4
