Upgraded from 0.9.8.10 to 0.9.8.14 and now PlexConnect won't work. Instead, the following message appears in the console:
API change perhaps?
API change perhaps?
working for me. did you download the latest plexconnect?
Yes, retained only my certificate and config file
On my side I cannot change the plex connect parameters anymore...
I updated and everything still works (had to update the firewall rules again though)
Sent from my iPhone using Tapatalk
I also experienced some hiccups but an update of PlexConnect, a restart of my machine running PMS and a restart of ATV everything is now back to normal.
What does that mean?
Which parameters?
Yes it's the same thing for me, i cannot change any settings on the Apple TV anymore with the latest version.
Maybe this is because of the Plex Server Update ??
A restart after the update and some time permitted for "warm-up", sorted it out.
