LOL
Yea… I bet your inbox is FULL.
There is a lastviewedat timestamp it says “1484801985”
This is for the Futurama episode that re-showed up.
LOL
That would be “Thu, 19 Jan 2017 04:59:45 GMT”. So it definitely looks like it’s picking up an older watched status from before.
@“MovieFan.Plex”
I assumed that might be the case.
But that video was not ever removed. I just did a Fix incorrect match for that entire series.
So… unless fix incorrect match set the last watched date to current date… Why would it again display. It has not been viewed within the last 7 days (My Setting for on-deck)
It’s possible that, that specific episode was not matched properly. There have been TVDB outages lately. So if it couldn’t be matched, the old watched status stayed but the line item in the DB for that episode was removed. Fix incorrect match then rematched the episode properly but since that episode was already removed due to a bad match earlier, this episode will have a new AddedAt date, but an older Viewed Date. The Viewed Date isn’t used for anything, it’s just informative. The AddedAt date is what’s used for OnDeck so this being a “new” episode, it shows up.
That makes absolutely NO sense at all…
@ChuckPa
@“MovieFan.Plex”
Ok here it did it again.
Just going to the dashboard it all of a sudden showed a plethora of on-deck titles.
I had done nothing but go to a movie detail page and back
Going to another page and back home the on-deck went back to the original 4 as before.
Logs attached
MovieFan has more experience than I here. I will have to let him take over. If he can spot it, I can go digging. I just am not seeing where in the data it goes sideways.
I’m sorry, but did my explanation not make sense or was this a reaction to what PMS does?
I see in your logs where you OnDeck jumps from 4 items to more, then back. I’m not sure whats causing it but I believe it is just a glitch. The OnDeck with 4 items is correct. I will bring this up with the devs and see what they think. Thanks for the log.
