Pms 1.43.0.10162 Transcoder crash for Roku playback on specific video file
Server Version#:1.43.0.10162 windows
Player Version#:roku ultra 14.6 with plex app version 8.6
Transcoder crashes when starting playback for a specific video to a roku client. All other client playback is fine.
I can provide server debug logging in a PM if needed.
Sep 25, 2025 20:32:06.268 [100252] ERROR - [Req#1c9a4b/Transcode/ef8bd186-bc05-49ab-8d00-60786ac36d5d-37/2ce6783d-636e-45e7-a918-bf66621a1b80] Unrecognized option ‘segment_copyts’.
Sep 25, 2025 20:32:06.268 [100252] ERROR - [Req#1c9a4e/Transcode/ef8bd186-bc05-49ab-8d00-60786ac36d5d-37/2ce6783d-636e-45e7-a918-bf66621a1b80] Error splitting the argument list: Option not found
Sep 25, 2025 20:32:06.273 [86436] DEBUG - Jobs: ‘K:\Plex\Plex Media Server\Plex Transcoder.exe’ exit code for process 57568 is -1414549496 ()
Sep 25, 2025 20:32:06.273 [99876] DEBUG - Streaming Resource: Terminating session 0000013CD6F0B0A0:11298e4d31eee587bb722857bc31ff4d which is using 6324kbps of WAN bandwidth. Used is now 0kbps
Sep 25, 2025 20:32:06.273 [99876] DEBUG - Streaming Resource: Terminated session 0000013CD6F0B0A0:11298e4d31eee587bb722857bc31ff4d with reason Conversion failed. The transcoder process crashed.
Try installing Plex server into the default location for apps on drive C.
No, this will not cause the location of the plex data folder to change.
Sorry if I didn’t explain the issue clearly. With a specific video file attempting to playback on Roku I get a conversion failed. The transcoder process crashed. All other videos and playback clients have no issues so far.
Please.
What is your K: drive? Does it have enough space?
That drive has plenty of space on it. It is the install path of plex. I’ve been running it on that drive for many years. It’s just this one video file when playing back on roku gives me the transcoder crashed error. Playback of other files works just fine.
I’ve sent the logs and example file.
Posting here as well to say the same thing, 33% and crashes, transcoder has crashed. Doesn’t seem like it’s detecting the hardware transcoder of my iGPU.
Any file I seem to play that did work, now fails to work.
@The_Tall_Man Please download the zip of your PMS logs and share them here or via DM.
@Atomatth send you a DM as requested with the logs.
Got it thanks! :plexheart:
Yep. Same here on all rokus when I have subtitles on. If I tell it to burn subtitles, it works fine.
Sep 26, 2025 20:42:05.820 [139224583498552] DEBUG - [Req#e4d20/Transcode/370e75b3-5726-4337-b866-333ad4a095cc-2016/JobRunner] Jobs: Starting child process with pid 23350
Sep 26, 2025 20:42:05.824 [139224627448632] ERROR - [Req#e4d16/Transcode/370e75b3-5726-4337-b866-333ad4a095cc-2016/fd84728e-3aee-445c-84e7-0ab46f8d7f79] Unrecognized option ‘segment_copyts’.
Sep 26, 2025 20:42:05.824 [139224627448632] ERROR - [Req#e4d22/Transcode/370e75b3-5726-4337-b866-333ad4a095cc-2016/fd84728e-3aee-445c-84e7-0ab46f8d7f79] Error splitting the argument list: Option not found
That is interesting. It does show this in the logs above the previous lines I posted:
Sep 26, 2025 20:42:05.820 [139224583498552] DEBUG - [Req#e4d20/Transcode/370e75b3-5726-4337-b866-333ad4a095cc-2016] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Even though I have an igpu
I can confirm rolling back on version fixes the issue if that helps.
Does the build I posted here resolve the issue for you guys?
Can confirm this resolved the issue on Roku and the random pausing on Apple TVs. Thank you! Working good so far.
Yes this fixes my reported issue.
