PMS crashes on daily basis
Server Version#: 1.30.2.6563
Recently formatted my 2011 Mac mini, reinstalled the OS (macOS 10.13.6), and reinstalled the server and copied the old ~/LIbrary/Application Support/Plex Media Server to the new machine.
It is working as it should, except the PMS crashes on more or less a daily basis. Restarting it works fine, but it should of course not crash. :slight_smile: Any help appreciated.
I don’t see how I can upload files, so crash logs and server logs can be found here: Dropbox - Plex logs.zip - Simplify your life
The logs are full of network related errors, such as the Mac losing its local IP address.
This repeats ~1500 times in the log files:
Jan 31, 2023 17:12:18.798 [0x7000076ce000] DEBUG - Detected primary interface: 0.0.0.0
Jan 31, 2023 17:12:18.798 [0x7000076ce000] DEBUG - Network interfaces:
Jan 31, 2023 17:12:18.798 [0x7000076ce000] DEBUG -  * 1 lo0 (127.0.0.1) (00-00-00-00-00-00) (loopback: 1)
Jan 31, 2023 17:12:18.798 [0x7000076ce000] DEBUG -  * 1 lo0 (::1) (00-00-00-00-00-00) (loopback: 1)
Verify the integrity of the network connection for the Mac.
Use a wired Ethernet connection if possible. If already on a wired connection try different Ethernet cables, router/switch ports, etc.
Make sure the Mac has a solid Internet connection and can communicate with plex.tv.
Drag the file into the message window. It will insert at the cursor location. Alternately, use the upload button.
Screenshot (1629)
Thanks a lot, that will give me something to work on. The machine is constantly being awakened for some reason (Which is why I reset it), so that could explain it.
