PMS Crashing every night
Server Version#: Version 1.32.6.7468
Player Version#:N/A
Having issues every night since I updated to 1.32.6.7468. I’ve looked at the possible .dll issue and it doesn’t appear that is the case here.
That version was rolled back and replaced with 1.32.5.7516 or if running beta 1.32.6.7521 which has a lot of DVR fixes.
Thanks for the reply!
I tried updating but it’s nots detecting a new version. How can I update this?
You would have to uninstall and manually download/install the 1.32.5.7516 version or in Server Settings > General change the Server update Channel to “Beta” to pickup the 1.32.6.7521 version, changing back to public afterwards.
Thank you.
Here’s hoping it solves my issue!
FYI, PMS 64-bit on Windows permits direct downgrades. No need to uninstall. When the installer first launches, there is a window with “a newer version is already installed…” and it lists both versions. You can choose to proceed or cancel.
PMS 32-bit does not support direct downgrades. An uninstall is necessary before installing the desired version.
Thanks everyone for the knowledge and suggestions.
Unfortunately I’ve tried the downgrade and the beta version and it’s still happening.
I have discovered the Scheduled Tasks is culprit here causing Plex to crash.
Anyone have any possible remediation at this point?
