unfortunately this is a recurring issue for some users. Always these two directories show with errors as above and need to have ownership / permissions changed
~/Library/Caches
~/Library/Logs
~/Library/Caches
~/Library/Logs
When running PMS from terminal:
Error: Unable to set up server: sqlite3_statement_backend::loadOne: database disk image is malformed (N4soci10soci_errorE)
That looks like a corrupted library file. Is this a new library or an old one?
This is a brand new library.
Seems odd that the db is in a disk image, rather than just a file. Sounds like a matter for a dev.
See what log files exist and may indicate when corruption first reported
For location of logs
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
To repair/restore db
See
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
I tried 4 different backup files, and they all resulted in:
Error: Unable to set up server: sqlite3_statement_backend::prepare: database disk image is malformed for SQL: PRAGMA cache_size=2000 (N4soci10soci_errorE)
Whoâs talking about Preview? And whoâs talking about a new system?
was spam bot. that account is deleted/banned
My frustration with this product has come to the point where I must declare that I would never have purchased a Plex pass had I known how consistently buggy this application is.
Since first installing Plex a couple of months ago, Iâve had to essentially wipe my library at least five times, approximately every two weeks.
Perhaps this is a little off-topic for this particular thread, but Iâve been plagued with:
I happen to be a web developer, so I have a bit more patience for debugging than the average user. I canât imagine how an average user would react to all of this (probably not well). Honestly, Iâm nearing the end of my rope. When I pay for a product, I expect to spend my time using it, not debugging it. Thatâs what Plex developers get paid for, right?
Iâm going to try one last-ditch effort - install PMS on Ubuntu to see if it yields any better results. If not, itâs probably goodbye.
Logs may have had clues - it is always the best way to investigate issues when they arise
Iâve uploaded logs to this thread: Mojave freezes with Plex server
I am having a similar issue. Plex 1.14.0.5470 crashes upon launch with Mojave. But when I downgrade to PMS 1.13.9.5456 it works okay, No logs in the Crash Logs folder. Plenty f folders for each version, but no files within. I turned off auto-updates for now.
What has happened to Plex?
Weâre seriously pushing server breaking bugs to the production version when itâs been reported here by numerous people?
Where can we download 1.13.9.5456 now that the both the PP version matches the non-beta?
EDIT: I answered my own question by digging into the links Plex posts. Thankfully they still have the old non-â â â â build posted on their servers:
There is a crash that is arising when network interfaces are multi-homed (more than 1 IP address) - ifconfig -a would identify this. Also with crash reporting enabled, the Plex Media Server logs would help identify the crash and confirm if it is this
Checked ifconfig and no Multihoming on either en0 nor en1. Which logs would you like? I can upload them.
Assuming you have not disabled crash reporting and not disabled debug logging in server settings general with show advanced, the logs would be zip of all the log files in the Logs directory
If you have access to the server through Plex Web then it would be settings / server / troubleshooting / download logs
otherwise copying out the Logs directory and zipping it
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
Thanks, just sent you the log files.
please can i have the output from ifconfig -a copied into a text file
thanks
It is probably loopback
